Helper class to process file series. More...
#include <vtkFileSeriesHelper.h>
| class | vtkTimeInformation |
| typedef bool(* | FileNameFunctorType) (vtkAlgorithm *reader, const std::string &filename) |
| unsigned int | GetNumberOfFiles () const |
| Get the number of files in the series. More... | |
| virtual bool | ReadMetaFile (const char *metafilename) |
| Setup file names in the series using a meta-file. More... | |
| virtual bool | UpdateInformation (vtkAlgorithm *reader, const FileNameFunctorType &ftor) |
| vtkFileSeriesHelper needs to collect information about the nature of the fileseries. More... | |
| virtual vtkMTimeType | GetUpdateInformationTime () |
The time stamp for the most recent UpdateInformation call that did some work to update the file series. More... | |
| const std::vector< double > & | GetTimeSteps () const |
| Returns the timesteps determined. More... | |
| const std::pair< double, double > & | GetTimeRange (bool *isvalid=NULL) const |
| Returns the time range determined. More... | |
| void | FillTimeInformation (vtkInformation *info) const |
| Fills up info with information about timesteps and timerange. More... | |
| virtual bool | GetPartitionedFiles () |
| Returns true if the file series is a series of partitions rather than a series of timesteps. More... | |
| std::vector< std::string > | GetActiveFiles (vtkInformation *outInfo) const |
| Returns the list of files to read on current rank to satisfy the request. More... | |
| void | RemoveAllFileNames () |
| Specify the set of files that comprise the series. More... | |
| void | AddFileName (const char *fname) |
| void | SetFileNames (const std::vector< std::string > &filenames) |
| void | SetController (vtkMultiProcessController *) |
| Get/Set the parallel controller. More... | |
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetIgnoreReaderTime (bool) |
| In vtkFileSeriesHelper::UpdateInformation, vtkFileSeriesHelper tries to determine time information from the reader by making it read each of the files and then collecting the timesteps provided by each. More... | |
| virtual bool | GetIgnoreReaderTime () |
| virtual void | IgnoreReaderTimeOn () |
| virtual void | IgnoreReaderTimeOff () |
| static vtkFileSeriesHelper * | New () |
| static vtkFileSeriesHelper * | SafeDownCast (vtkObject *o) |
| vtkFileSeriesHelper () | |
| ~vtkFileSeriesHelper () override | |
Protected Attributes | |
| vtkMultiProcessController * | Controller |
| std::vector< std::string > | FileNames |
| bool | IgnoreReaderTime |
| bool | PartitionedFiles |
| std::vector< vtkTimeInformation > | Information |
vtkFileSeriesHelper is intended to be a helper class that processes file series. File series encountered in ParaView are of two types: temporal or spatial. This class encapsulates logic to determine which form it is in.
Currently, this is used by vtkCGNSFileSeriesReader. Eventually, we should be able to refactor vtkFileSeriesReader to use this class.
Definition at line 43 of file vtkFileSeriesHelper.h.
Definition at line 47 of file vtkFileSeriesHelper.h.
| typedef bool(* vtkFileSeriesHelper::FileNameFunctorType) (vtkAlgorithm *reader, const std::string &filename) |
Definition at line 50 of file vtkFileSeriesHelper.h.
| void vtkFileSeriesHelper::RemoveAllFileNames | ( | ) |
| void vtkFileSeriesHelper::AddFileName | ( | const char * | fname | ) |
| void vtkFileSeriesHelper::SetFileNames | ( | const std::vector< std::string > & | filenames | ) |
| unsigned int vtkFileSeriesHelper::GetNumberOfFiles | ( | ) | const |
The meta-file is simply lists the names of the files in the series sequentially in an ASCII file. All files in the file are relative to the location of the meta-file or absolute paths.
This will remove an preexisting files added to the helper irrespective of whether reading of the meta-file succeeded or not.
| void vtkFileSeriesHelper::SetController | ( | vtkMultiProcessController * | ) |
By default vtkMultiProcessController::GetGlobalController() will be used.
Sometimes, however, the time steps in the files in the fileseries are invalid (or same) in which case one may want to to simply use the time-step index as the time value. For that case, one should set IgnoreReaderTime to true (default: false).
This method should be called to collect this information.
This method has any effect only when the filenames (or any ivar that could affect the times e.g. IgnoreReaderTime) have changed, hence calling this repeatedly is acceptable.
When this method does any work, it updates this->UpdateInformationTime. One can use GetUpdateInformationTime to check if the file series has potentially been changed.
| [in] | reader | pointer to the single file reader to use. |
| [in] | ftor | callback to set the filename on the reader. |
This method will return valid values only after a successful call to UpdateInformation.
Definition at line 132 of file vtkFileSeriesHelper.h.
Definition at line 137 of file vtkFileSeriesHelper.h.
| void vtkFileSeriesHelper::FillTimeInformation | ( | vtkInformation * | info | ) | const |
| std::vector<std::string> vtkFileSeriesHelper::GetActiveFiles | ( | vtkInformation * | outInfo | ) | const |
Requested time and piece information is obtained from outInfo. If outInfo has not piece information, however, than this->Controller is used.
| outInfo | vtkInformation object with UPDATE_* keys that indicate the requested time and piece information. |
Definition at line 195 of file vtkFileSeriesHelper.h.
Definition at line 196 of file vtkFileSeriesHelper.h.
Definition at line 197 of file vtkFileSeriesHelper.h.
Definition at line 198 of file vtkFileSeriesHelper.h.
Definition at line 199 of file vtkFileSeriesHelper.h.
