| int | CanReadFile (const char *filename) |
| | Test a file for readability. More...
| const char * | GetCurrentFileName () const |
| | Returns the filename being used for current timesteps. More...
| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | Overridden to setup the Reader and then forward the pass to the reader. More...
| void | SetController (vtkMultiProcessController *controller) |
| | Get/Set the controller. More...
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetReader (vtkCGNSReader *reader) |
| | Get/Set the reader. More...
| virtual vtkCGNSReader * | GetReader () |
| void | AddFileName (const char *fname) |
| | Add/remove files names in the file series. More...
| void | RemoveAllFileNames () |
| virtual bool | GetIgnoreReaderTime () |
| | If true, then treat file series like it does not contain any time step values. More...
| virtual void | SetIgnoreReaderTime (bool) |
| virtual void | IgnoreReaderTimeOn () |
| virtual void | IgnoreReaderTimeOff () |
| vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
| vtkMultiBlockDataSet * | GetOutput () |
| vtkMultiBlockDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkCGNSFileSeriesReader () |
| | ~vtkCGNSFileSeriesReader () override |
| | Handles the RequestData pass. More...
| bool | UpdateActiveFileSet (vtkInformation *info) |
| | Update this->ActiveFiles, a collection of files to be read to satisfy the current request. More...
| void | ChooseActiveFile (int index) |
| | Select the file from this->ActiveFiles at the given index and set that on this->Reader. More...
| | vtkMultiBlockDataSetAlgorithm () |
| | ~vtkMultiBlockDataSetAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Adds support for reading temporal or partitioned CGNS files.
vtkCGNSFileSeriesReader is a meta-reader that add support for reading CGNS file series using vtkCGNSReader. We encounter two types of file series with CGNS:
- 1. temporal file series - where each file is simply a single timestep.
- 2. partitioned file series - where each file corresponds to data dumped out from a rank but has all timesteps.
vtkCGNSFileSeriesReader determines the nature of the file series encountered and reads the files accordingly. For partitioned files, the files are distributed among data-processing ranks, while for temporal file series, blocks are distributed among data-processing ranks (using logic in vtkCGNSReader itself).
- See also
- vtkFileSeriesHelper
Definition at line 50 of file vtkCGNSFileSeriesReader.h.
