| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | All pipeline passes are forwarded to the internal reader. More...
| virtual int | CanReadFile (const char *filename) |
| | CanReadFile is forwarded to the internal reader if it supports it. More...
| virtual void | AddFileName (const char *fname) |
| | Adds names of files to be read. More...
| virtual void | RemoveAllFileNames () |
| | Remove all file names. More...
| virtual unsigned int | GetNumberOfFileNames () |
| | Returns the number of file names added by AddFileName. More...
| virtual const char * | GetFileName (unsigned int idx) |
| | Returns the name of a file with index idx. More...
| const char * | GetCurrentFileName () |
| virtual int | GetUseMetaFile () |
| | If true, then use the meta file. More...
| virtual void | SetUseMetaFile (int) |
| virtual void | UseMetaFileOn () |
| virtual void | UseMetaFileOff () |
| virtual bool | GetIgnoreReaderTime () |
| | If true, then treat file series like it does not contain any time step values. More...
| virtual void | SetIgnoreReaderTime (bool) |
| virtual void | IgnoreReaderTimeOn () |
| virtual void | IgnoreReaderTimeOff () |
| | vtkMetaReader () |
| | ~vtkMetaReader () override |
| vtkMTimeType | GetMTime () override |
| | Return the MTime when also considering the internal reader. More...
| virtual void | SetReader (vtkAlgorithm *) |
| | Set/get the internal reader. More...
| virtual vtkAlgorithm * | GetReader () |
| void | SetMetaFileName (const char *name) |
| | Get/set the filename for the meta-file. More...
| char * | GetMetaFileName () |
| virtual vtkIdType * | GetFileIndexRange () |
| | Returns the available range of file indexes. More...
| virtual void | GetFileIndexRange (vtkIdType &, vtkIdType &) |
| virtual void | GetFileIndexRange (vtkIdType [2]) |
| vtkIdType | GetFileIndex () |
| | Get/set the index of the file to read. More...
| void | SetFileIndex (vtkIdType i) |
| virtual void | SetFileNameMethod (const char *) |
| | Name of the method used to set the file name of the internal reader. More...
| virtual char * | GetFileNameMethod () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkFileSeriesReader () |
| | ~vtkFileSeriesReader () override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| virtual int | RequestInformationForInput (int index, vtkInformation *request=NULL, vtkInformationVector *outputVector=NULL) |
| | Make sure the reader's output is set to the given index and, if it changed, run RequestInformation on the reader. More...
| virtual int | ReadMetaDataFile (const char *metafilename, vtkStringArray *filesToRead, std::vector< double > &timeValues, int maxFilesToRead=VTK_INT_MAX) |
| | Reads a metadata file and returns a list of filenames (in filesToRead). More...
| virtual void | UpdateMetaData () |
| | Re-reads information from the metadata file, if necessary. More...
| void | ResetTimeRanges () |
| | Resets information about TimeRanges. More...
| void | RemoveAllFileNamesInternal () |
| | Add/Remove filenames without changing the MTime. More...
| void | AddFileNameInternal (const char *) |
| virtual void | RemoveAllRealFileNamesInternal () |
| | Remove all real file names. More...
| void | CopyRealFileNamesFromFileNames () |
| | Set the real filenames to those in the internal FileNames. More...
| int | ChooseInput (vtkInformation *) |
| virtual void | Set_MetaFileName (const char *) |
| virtual char * | Get_MetaFileName () |
| virtual void | Set_FileIndex (vtkIdType) |
| virtual vtkIdType | Get_FileIndex () |
| void | ReaderSetFileName (const char *filename) |
| int | ReaderCanReadFile (const char *filename) |
| std::string | FromRelativeToMetaFile (const char *metaFileName, const char *fileName) |
| | 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
meta-reader to read file series
vtkFileSeriesReader is a meta-reader that can work with various readers to load file series. To the pipeline, it looks like a reader that supports time. It updates the file name to the internal reader whenever a different time step is requested.
If the reader already supports time, then this meta-filter will multiplex the time. It will union together all the times and forward time requests to the file with the correct time. Overlaps are handled by requesting data from the file with the upper range the farthest in the future.
There are three ways to specify a series of files. The first way is by adding the filenames one at a time with the AddFileName method.
The second way is by providing (with the AddFileName method) a meta file that specifies a list of files. This format allows the user to specify a time value in addition to a filename for each step. The format is as follows:
* "file-series-version" : "version",
* "files" : [
* { "name" : "filename1", "time" : timeValue1 },
* { "name" : "filename2", "time" : timeValue2 },
* Here is an example:
* "file-series-version" : "1.0",
* "files" : [
* { "name" : "foo1.vtk", "time" : 0 },
* { "name" : "foo2.vtk", "time" : 5.5 },
* { "name" : "foo3.vtk", "time" : 11.2 }]
* The current version is 1.0.
The third way is by providing a single meta file which is a simple text file that lists a file per line. The files can be relative to the meta file. This method is useful when the actual reader points to a set of files itself. The UseMetaFile enables this method of specifying the files. The filename is set with SetMetaFileName in this case. Do not use the AddFileName() method when using SetMetaFileName() as names set with AddFileName() will be ignored.
Definition at line 94 of file vtkFileSeriesReader.h.
