| virtual double * | GetPosition () |
| | Get/Set the position to use when AnyLocation is being used. More...
| virtual void | GetPosition (double &, double &) |
| virtual void | GetPosition (double [2]) |
| virtual void | SetPosition (double, double) |
| void | SetPosition (double [2]) |
| void | SetInteractivity (bool) |
| | Set the interactivity. More...
| void | SetTextProperty (vtkTextProperty *) |
| | Forwarded to vtkBlockItem. More...
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkChartTextRepresentation () |
| | ~vtkChartTextRepresentation () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
| enum | {
AnyLocation = 0,
LowerLeftCorner,
LowerRightCorner,
LowerCenter,
UpperLeftCorner,
UpperRightCorner,
UpperCenter
| void | SetLabelLocation (int location) |
