Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | Static Protected Attributes | List of all members
vtkSMChartSeriesSelectionDomain Class Reference
extends vtkSMChartSeriesListDomain to add logic to better handle default values suitable for series-parameter type properties such as SeriesVisibility, SeriesLabel, etc. More...
#include <vtkSMChartSeriesSelectionDomain.h>
Inheritance diagram for vtkSMChartSeriesSelectionDomain:
Collaboration diagram for vtkSMChartSeriesSelectionDomain:
enum  DefaultModes {
  UNDEFINED, VISIBILITY, LABEL, COLOR,
  VALUE
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Set the property's default value based on the domain. More...
virtual void SetDefaultValue (const char *)
virtual int GetDefaultMode ()
 Get the default-mode that controls how SetDefaultValues() behaves. More...
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
 A vtkSMProperty is often defined with a default value in the XML itself. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMChartSeriesSelectionDomain * New ()
static vtkSMChartSeriesSelectionDomain * SafeDownCast (vtkObject *o)
static void SetLoadNoChartVariables (bool choice)
 Global flag to toggle between (a) the default behavior and (b) setting default visibility to off. More...
static bool GetLoadNoChartVariables ()
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMChartSeriesSelectionDomain ()
 ~vtkSMChartSeriesSelectionDomain () override
vtkPVDataInformation * GetInputInformation ()
 Returns the datainformation from the current input, if possible. More...
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
 Process any specific XML definition tags. More...
virtual bool GetDefaultSeriesVisibility (const char *)
 Returns the default visibility for a series given its name. More...
virtual std::vector< std::string > GetDefaultValue (const char *series)
 Get the default value that will be used for the series with the given name by this domain. More...
virtual void PopulateAvailableArrays (const std::string &blockName, std::vector< std::string > &strings, vtkPVDataInformation *dataInfo, int fieldAssociation, bool flattenTable)
 Build up the domain with available series names. More...
virtual void PopulateArrayComponents (vtkChartRepresentation *chartRepr, const std::string &blockName, std::vector< std::string > &strings, std::set< std::string > &unique_strings, vtkPVArrayInformation *dataInfo, bool flattenTable)
 Build up the domain with provided array. More...
virtual void SetDefaultVisibilityOverride (const std::string &arrayname, bool visibility)
 Call this method in PopulateAvailableArrays() to override a specific array's default visibility. More...
- Protected Member Functions inherited from vtkSMStringListDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int DefaultMode
bool FlattenTable
 Specify if table components should be split. More...
bool HidePartialArrays
 Specify if Partial Arrays should be hidden. More...
char * DefaultValue
 Value used when DefaultMode==VALUE. More...
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
static bool LoadNoVariables
vtkSMChartSeriesSelectionDomain extends vtkSMChartSeriesListDomain to add logic to better handle default values suitable for series-parameter type properties such as SeriesVisibility, SeriesLabel, etc.
This domain also supports an experimental feature (we can generalize this to vtkSMDomain is found useful in other places). Generally, a vtkSMProperty never changes unless the application/user updates it. However for things like series parameters, it is useful if the property is updated to handle changed/newly added series consistently in the Qt application and the Python. To support that, this domain resets the property value to default every time the domain changes preserving status for existing series i.e. it won't affect the state for any series that already set on the property. Thus, it's not a true "reset", but more like "update".
Supported XML attributes
Definition at line 41 of file vtkSMChartSeriesSelectionDomain.h.
Definition at line 45 of file vtkSMChartSeriesSelectionDomain.h.
◆ DefaultModes
Enumerator
UNDEFINED
VISIBILITY
LABEL
COLOR
VALUE
Definition at line 54 of file vtkSMChartSeriesSelectionDomain.h.
◆ vtkSMChartSeriesSelectionDomain()
vtkSMChartSeriesSelectionDomain::vtkSMChartSeriesSelectionDomain ( )
◆ ~vtkSMChartSeriesSelectionDomain()
vtkSMChartSeriesSelectionDomain::~vtkSMChartSeriesSelectionDomain ( )
static vtkSMChartSeriesSelectionDomain* vtkSMChartSeriesSelectionDomain::New ( )
virtual const char* vtkSMChartSeriesSelectionDomain::GetClassName ( )
Reimplemented from vtkSMStringListDomain.
static int vtkSMChartSeriesSelectionDomain::IsTypeOf ( const char *  type)
virtual int vtkSMChartSeriesSelectionDomain::IsA ( const char *  type)
static vtkSMChartSeriesSelectionDomain* vtkSMChartSeriesSelectionDomain::SafeDownCast ( vtkObject *  o)
void vtkSMChartSeriesSelectionDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMChartSeriesSelectionDomain::Update ( vtkSMProperty *  )
◆ SetDefaultValues()
int vtkSMChartSeriesSelectionDomain::SetDefaultValues ( vtkSMProperty *  ,
override
How the value is determined using the range is controlled by DefaultMode.
◆ GetDefaultMode()
virtual int vtkSMChartSeriesSelectionDomain::GetDefaultMode ( )
◆ SetLoadNoChartVariables()
static void vtkSMChartSeriesSelectionDomain::SetLoadNoChartVariables ( bool  choice)
inlinestatic
Definition at line 80 of file vtkSMChartSeriesSelectionDomain.h.
◆ GetLoadNoChartVariables()
static bool vtkSMChartSeriesSelectionDomain::GetLoadNoChartVariables ( )
inlinestatic
Definition at line 84 of file vtkSMChartSeriesSelectionDomain.h.
◆ SetDefaultValue()
virtual void vtkSMChartSeriesSelectionDomain::SetDefaultValue ( const char *  )
◆ GetInputInformation()
vtkPVDataInformation* vtkSMChartSeriesSelectionDomain::GetInputInformation ( )
◆ ReadXMLAttributes()
int vtkSMChartSeriesSelectionDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ GetDefaultSeriesVisibility()
virtual bool vtkSMChartSeriesSelectionDomain::GetDefaultSeriesVisibility ( const char *  )
protectedvirtual
◆ GetDefaultValue()
virtual std::vector<std::string> vtkSMChartSeriesSelectionDomain::GetDefaultValue ( const char *  series)
protectedvirtual
◆ PopulateAvailableArrays()
virtual void vtkSMChartSeriesSelectionDomain::PopulateAvailableArrays ( const std::string &  blockName,
std::vector< std::string > &  strings,
vtkPVDataInformation *  dataInfo,
bool  flattenTable
protectedvirtual
Add arrays from dataInfo to strings. If blockName is non-empty, then it's used to "uniquify" the array names.
◆ PopulateArrayComponents()
virtual void vtkSMChartSeriesSelectionDomain::PopulateArrayComponents ( vtkChartRepresentation *  chartRepr,
std::set< std::string > &  unique_strings,
vtkPVArrayInformation *  dataInfo,
bool  flattenTable
protectedvirtual
Add array component from dataArray to strings. If blockName is non-empty, then it's used to "uniquify" the array names.
◆ SetDefaultVisibilityOverride()
virtual void vtkSMChartSeriesSelectionDomain::SetDefaultVisibilityOverride ( const std::string &  arrayname,
bool  visibility
protectedvirtual
Used for hiding array components, by default, for example.
◆ DefaultMode
int vtkSMChartSeriesSelectionDomain::DefaultMode
Definition at line 138 of file vtkSMChartSeriesSelectionDomain.h.
◆ DefaultValue
char* vtkSMChartSeriesSelectionDomain::DefaultValue
Definition at line 144 of file vtkSMChartSeriesSelectionDomain.h.
◆ FlattenTable
bool vtkSMChartSeriesSelectionDomain::FlattenTable
Definition at line 150 of file vtkSMChartSeriesSelectionDomain.h.
◆ HidePartialArrays
bool vtkSMChartSeriesSelectionDomain::HidePartialArrays
Definition at line 155 of file vtkSMChartSeriesSelectionDomain.h.
◆ LoadNoVariables
bool vtkSMChartSeriesSelectionDomain::LoadNoVariables
staticprotected
Definition at line 157 of file vtkSMChartSeriesSelectionDomain.h.
