vtkSISourceProxy Class Reference
vtkSISourceProxy is the server-side helper for a vtkSMSourceProxy. More...
#include <vtkSISourceProxy.h>
Inheritance diagram for vtkSISourceProxy:
Collaboration diagram for vtkSISourceProxy:
typedef vtkSIProxy Superclass
- Public Types inherited from vtkSIProxy
typedef vtkSIObject Superclass
- Public Types inherited from vtkSIObject
virtual vtkAlgorithmOutput * GetOutputPort (int port)
 Returns the vtkAlgorithmOutput for an output port, if valid. More...
void UpdatePipelineInformation () override
 Triggers UpdateInformation() on vtkObject if possible. More...
virtual void UpdatePipeline (int port, double time, bool doTime)
 Triggers UpdatePipeline(). More...
virtual void SetupSelectionProxy (int port, vtkSIProxy *extractSelection)
 setups extract selection proxies. More...
virtual void SetDisablePipelineExecution (bool value)
 Allow to shut down pipeline execution. More...
void RecreateVTKObjects () override
 Overridden to update the output ports. More...
- Public Member Functions inherited from vtkSIProxy
void AboutToDelete () override
 This method is called before the deletion of the SIObject. More...
void Push (vtkSMMessage *msg) override
 Push a new state to the underneath implementation. More...
void Pull (vtkSMMessage *msg) override
 Pull the current state of the underneath implementation. More...
vtkSIProperty * GetSIProperty (const char *name)
 Provides access to the property helper. More...
bool IsNullProxy ()
 Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More...
virtual bool ExtendDefinition (const char *xml)
 Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More...
vtkObjectBase * GetVTKObject ()
 Returns access to the VTKObject pointer, if any. More...
void SetVTKObject (vtkObjectBase *)
 Returns the VTKClassName. More...
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual void AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method)
 These methods are called to add/remove input connections by vtkSIInputProperty. More...
virtual void CleanInputs (const char *method)
- Public Member Functions inherited from vtkSIObject
virtual void Initialize (vtkPVSessionCore *session)
 Initializes the instance. More...
vtkClientServerInterpreter * GetInterpreter ()
 Provides access to the Interpreter. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid) const
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkObject subclass given its global id. More...
virtual void SetGlobalID (vtkTypeUInt32)
 Get/Set the global id for this object. More...
static vtkSISourceProxy * New ()
static vtkSISourceProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProxy
static vtkSIProxy * New ()
static vtkSIProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIObject
static vtkSIObject * New ()
static vtkSIObject * SafeDownCast (vtkObject *o)
 vtkSISourceProxy ()
 ~vtkSISourceProxy () override
bool CreateVTKObjects () override
 Overridden to setup the output ports and pipelines for the output ports. More...
bool ReadXMLAttributes (vtkPVXMLElement *element) override
 Read xml-attributes. More...
void OnCreateVTKObjects () override
 Called after CreateVTKObjects(). More...
virtual bool CreateOutputPorts ()
 Create the output ports and add post filters for each output port. More...
virtual void SetExecutiveName (const char *)
void MarkStartEvent ()
 Callbacks to add start/end events to the timer log. More...
void MarkEndEvent ()
- Protected Member Functions inherited from vtkSIProxy
 vtkSIProxy ()
 ~vtkSIProxy () override
virtual vtkObjectBase * NewVTKObject (const char *className)
 Create an instance of the class specified. More...
vtkSIProxy * GetSubSIProxy (const char *name)
 Returns the subproxy helper for the subproxy with the given name, if any. More...
vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Provides access to the vtkSIProxyDefinitionManager held by the session. More...
virtual void DeleteVTKObjects ()
 Called to delete VTK objects. More...
bool InitializeAndCreateVTKObjects (vtkSMMessage *message)
 Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More...
void AddSIProperty (const char *name, vtkSIProperty *)
 Adds a vtkSMProperty's server-implementation. More...
virtual void SetPostPush (const char *)
virtual void SetPostCreation (const char *)
virtual char * GetLogName ()
unsigned int GetNumberOfSubSIProxys ()
 API to iterate over subproxy helpers. More...
vtkSIProxy * GetSubSIProxy (unsigned int cc)
virtual bool ReadXMLProperty (vtkPVXMLElement *property_element)
 Parses the XML to create property/subproxy helpers. More...
virtual bool ReadXMLSubProxy (vtkPVXMLElement *subproxy_element)
- Protected Member Functions inherited from vtkSIObject
 vtkSIObject ()
 ~vtkSIObject () override
char * ExecutiveName
bool DisablePipelineExecution
- Protected Attributes inherited from vtkSIProxy
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLSubProxyName
char * PostPush
char * PostCreation
int NumberOfInputPorts
vtkSmartPointer< vtkObjectBase > VTKObject
bool ObjectsCreated
- Protected Attributes inherited from vtkSIObject
vtkWeakPointer< vtkClientServerInterpreter > Interpreter
vtkWeakPointer< vtkPVSessionCore > SessionCore
vtkSMMessage * LastPushedMessage
vtkTypeUInt32 GlobalID
Friends
class vtkSICompoundSourceProxy
It adds support to handle various vtkAlgorithm specific Invoke requests coming from the client. vtkSISourceProxy also inserts post-processing filters for each output port from the vtkAlgorithm. These post-processing filters deal with things like parallelizing the data etc.
Definition at line 23 of file vtkSISourceProxy.h.
Definition at line 27 of file vtkSISourceProxy.h.
◆ vtkSISourceProxy()
vtkSISourceProxy::vtkSISourceProxy ( )
◆ ~vtkSISourceProxy()
vtkSISourceProxy::~vtkSISourceProxy ( )
static vtkSISourceProxy* vtkSISourceProxy::New ( )
virtual const char* vtkSISourceProxy::GetClassName ( )
static int vtkSISourceProxy::IsTypeOf ( const char *  type)
virtual int vtkSISourceProxy::IsA ( const char *  type)
static vtkSISourceProxy* vtkSISourceProxy::SafeDownCast ( vtkObject *  o)
void vtkSISourceProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSIProxy.
Reimplemented in vtkSIPythonSourceProxy, vtkSIImageTextureProxy, and vtkSIWriterProxy.
◆ GetOutputPort()
virtual vtkAlgorithmOutput* vtkSISourceProxy::GetOutputPort ( int  port)
Reimplemented in vtkSICompoundSourceProxy.
◆ UpdatePipelineInformation()
void vtkSISourceProxy::UpdatePipelineInformation ( )
◆ UpdatePipeline()
virtual void vtkSISourceProxy::UpdatePipeline ( int  port,
double  time,
bool  doTime
Called from client.
◆ SetupSelectionProxy()
virtual void vtkSISourceProxy::SetupSelectionProxy ( int  port,
vtkSIProxy *  extractSelection
◆ SetDisablePipelineExecution()
virtual void vtkSISourceProxy::SetDisablePipelineExecution ( bool  value)
inlinevirtual
This is particularly useful for a Catalyst session that does not contains any real data.
Definition at line 55 of file vtkSISourceProxy.h.
◆ RecreateVTKObjects()
void vtkSISourceProxy::RecreateVTKObjects ( )
Reimplemented in vtkSIPythonSourceProxy.
◆ CreateVTKObjects()
bool vtkSISourceProxy::CreateVTKObjects ( )
overrideprotectedvirtual
◆ ReadXMLAttributes()
bool vtkSISourceProxy::ReadXMLAttributes ( vtkPVXMLElement *  element)
Reimplemented in vtkSIWriterProxy.
◆ OnCreateVTKObjects()
void vtkSISourceProxy::OnCreateVTKObjects ( )
The main difference for subclasses when overriding CreateVTKObjects() or OnCreateVTKObjects() is that CreateVTKObjects() is called before ReadXMLAttributes() is called, while OnCreateVTKObjects() is called after ReadXMLAttributes().
Reimplemented in vtkSIWriterProxy, and vtkSIImageTextureProxy.
◆ CreateOutputPorts()
virtual bool vtkSISourceProxy::CreateOutputPorts ( )
protectedvirtual
CreateOutputPorts is only called when an output-port is requested, i.e. GetOutputPort() is called.
◆ MarkStartEvent()
void vtkSISourceProxy::MarkStartEvent ( )
◆ MarkEndEvent()
void vtkSISourceProxy::MarkEndEvent ( )
◆ SetExecutiveName()
virtual void vtkSISourceProxy::SetExecutiveName ( const char *  )
protectedvirtual
◆ vtkSICompoundSourceProxy
friend class vtkSICompoundSourceProxy
friend
Definition at line 103 of file vtkSISourceProxy.h.
◆ ExecutiveName
char* vtkSISourceProxy::ExecutiveName
Definition at line 99 of file vtkSISourceProxy.h.
◆ DisablePipelineExecution
bool vtkSISourceProxy::DisablePipelineExecution
Definition at line 100 of file vtkSISourceProxy.h.
