vtkSIMetaReaderProxy Class Reference
vtkSISourceProxy is the server-side helper for a vtkSMSourceProxy. More...
#include <vtkSIMetaReaderProxy.h>
Inheritance diagram for vtkSIMetaReaderProxy:
Collaboration diagram for vtkSIMetaReaderProxy:
typedef vtkSISourceProxy Superclass
- Public Types inherited from vtkSISourceProxy
typedef vtkSIProxy Superclass
- Public Types inherited from vtkSIProxy
typedef vtkSIObject Superclass
- Public Types inherited from vtkSIObject
- Public Member Functions inherited from vtkSISourceProxy
virtual vtkAlgorithmOutput * GetOutputPort (int port)
 Returns the vtkAlgorithmOutput for an output port, if valid. More...
void UpdatePipelineInformation () override
 Triggers UpdateInformation() on vtkObject if possible. More...
virtual void UpdatePipeline (int port, double time, bool doTime)
 Triggers UpdatePipeline(). More...
virtual void SetupSelectionProxy (int port, vtkSIProxy *extractSelection)
 setups extract selection proxies. More...
virtual void SetDisablePipelineExecution (bool value)
 Allow to shut down pipeline execution. More...
void RecreateVTKObjects () override
 Overridden to update the output ports. More...
- Public Member Functions inherited from vtkSIProxy
void AboutToDelete () override
 This method is called before the deletion of the SIObject. More...
void Push (vtkSMMessage *msg) override
 Push a new state to the underneath implementation. More...
void Pull (vtkSMMessage *msg) override
 Pull the current state of the underneath implementation. More...
vtkSIProperty * GetSIProperty (const char *name)
 Provides access to the property helper. More...
bool IsNullProxy ()
 Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More...
virtual bool ExtendDefinition (const char *xml)
 Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More...
vtkObjectBase * GetVTKObject ()
 Returns access to the VTKObject pointer, if any. More...
void SetVTKObject (vtkObjectBase *)
 Returns the VTKClassName. More...
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual void AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method)
 These methods are called to add/remove input connections by vtkSIInputProperty. More...
virtual void CleanInputs (const char *method)
- Public Member Functions inherited from vtkSIObject
virtual void Initialize (vtkPVSessionCore *session)
 Initializes the instance. More...
vtkClientServerInterpreter * GetInterpreter ()
 Provides access to the Interpreter. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid) const
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkObject subclass given its global id. More...
virtual void SetGlobalID (vtkTypeUInt32)
 Get/Set the global id for this object. More...
static vtkSIMetaReaderProxy * New ()
static vtkSIMetaReaderProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSISourceProxy
static vtkSISourceProxy * New ()
static vtkSISourceProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProxy
static vtkSIProxy * New ()
static vtkSIProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIObject
static vtkSIObject * New ()
static vtkSIObject * SafeDownCast (vtkObject *o)
 vtkSIMetaReaderProxy ()
 ~vtkSIMetaReaderProxy () override
void OnCreateVTKObjects () override
 Called after CreateVTKObjects(). More...
bool ReadXMLAttributes (vtkPVXMLElement *element) override
 Read xml-attributes. More...
virtual void SetFileNameMethod (const char *)
virtual char * GetFileNameMethod ()
- Protected Member Functions inherited from vtkSISourceProxy
 vtkSISourceProxy ()
 ~vtkSISourceProxy () override
bool CreateVTKObjects () override
 Overridden to setup the output ports and pipelines for the output ports. More...
virtual bool CreateOutputPorts ()
 Create the output ports and add post filters for each output port. More...
virtual void SetExecutiveName (const char *)
void MarkStartEvent ()
 Callbacks to add start/end events to the timer log. More...
void MarkEndEvent ()
- Protected Member Functions inherited from vtkSIProxy
 vtkSIProxy ()
 ~vtkSIProxy () override
virtual vtkObjectBase * NewVTKObject (const char *className)
 Create an instance of the class specified. More...
vtkSIProxy * GetSubSIProxy (const char *name)
 Returns the subproxy helper for the subproxy with the given name, if any. More...
vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Provides access to the vtkSIProxyDefinitionManager held by the session. More...
virtual void DeleteVTKObjects ()
 Called to delete VTK objects. More...
bool InitializeAndCreateVTKObjects (vtkSMMessage *message)
 Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More...
void AddSIProperty (const char *name, vtkSIProperty *)
 Adds a vtkSMProperty's server-implementation. More...
virtual void SetPostPush (const char *)
virtual void SetPostCreation (const char *)
virtual char * GetLogName ()
unsigned int GetNumberOfSubSIProxys ()
 API to iterate over subproxy helpers. More...
vtkSIProxy * GetSubSIProxy (unsigned int cc)
virtual bool ReadXMLProperty (vtkPVXMLElement *property_element)
 Parses the XML to create property/subproxy helpers. More...
virtual bool ReadXMLSubProxy (vtkPVXMLElement *subproxy_element)
- Protected Member Functions inherited from vtkSIObject
 vtkSIObject ()
 ~vtkSIObject () override
char * FileNameMethod
- Protected Attributes inherited from vtkSISourceProxy
char * ExecutiveName
bool DisablePipelineExecution
- Protected Attributes inherited from vtkSIProxy
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLSubProxyName
char * PostPush
char * PostCreation
int NumberOfInputPorts
vtkSmartPointer< vtkObjectBase > VTKObject
bool ObjectsCreated
- Protected Attributes inherited from vtkSIObject
vtkWeakPointer< vtkClientServerInterpreter > Interpreter
vtkWeakPointer< vtkPVSessionCore > SessionCore
vtkSMMessage * LastPushedMessage
vtkTypeUInt32 GlobalID
It adds support to handle various vtkAlgorithm specific Invoke requests coming from the client. vtkSISourceProxy also inserts post-processing filters for each output port from the vtkAlgorithm. These post-processing filters deal with things like parallelizing the data etc.
Definition at line 21 of file vtkSIMetaReaderProxy.h.
Definition at line 25 of file vtkSIMetaReaderProxy.h.
◆ vtkSIMetaReaderProxy()
vtkSIMetaReaderProxy::vtkSIMetaReaderProxy ( )
◆ ~vtkSIMetaReaderProxy()
vtkSIMetaReaderProxy::~vtkSIMetaReaderProxy ( )
static vtkSIMetaReaderProxy* vtkSIMetaReaderProxy::New ( )
virtual const char* vtkSIMetaReaderProxy::GetClassName ( )
Reimplemented from vtkSISourceProxy.
static int vtkSIMetaReaderProxy::IsTypeOf ( const char *  type)
virtual int vtkSIMetaReaderProxy::IsA ( const char *  type)
static vtkSIMetaReaderProxy* vtkSIMetaReaderProxy::SafeDownCast ( vtkObject *  o)
void vtkSIMetaReaderProxy::PrintSelf ( ostream &  os,
◆ OnCreateVTKObjects()
void vtkSIMetaReaderProxy::OnCreateVTKObjects ( )
overrideprotectedvirtual
The main difference for subclasses when overriding CreateVTKObjects() or OnCreateVTKObjects() is that CreateVTKObjects() is called before ReadXMLAttributes() is called, while OnCreateVTKObjects() is called after ReadXMLAttributes().
Reimplemented from vtkSIProxy.
◆ ReadXMLAttributes()
bool vtkSIMetaReaderProxy::ReadXMLAttributes ( vtkPVXMLElement *  element)
◆ SetFileNameMethod()
virtual void vtkSIMetaReaderProxy::SetFileNameMethod ( const char *  )
protectedvirtual
◆ GetFileNameMethod()
virtual char* vtkSIMetaReaderProxy::GetFileNameMethod ( )
protectedvirtual
◆ FileNameMethod
char* vtkSIMetaReaderProxy::FileNameMethod
Definition at line 42 of file vtkSIMetaReaderProxy.h.
