vtkPVMultiSliceView Class Reference
vtkPVMultiSliceView extends vtkPVRenderView but add meta-data information used by SliceRepresentation as a data model. More...
#include <vtkPVMultiSliceView.h>
Inheritance diagram for vtkPVMultiSliceView:
Collaboration diagram for vtkPVMultiSliceView:
typedef vtkPVRenderView Superclass
- Public Types inherited from vtkPVRenderView
enum  InteractionModes {
  INTERACTION_MODE_UNINTIALIZED = -1, INTERACTION_MODE_3D = 0, INTERACTION_MODE_2D, INTERACTION_MODE_SELECTION,
  INTERACTION_MODE_ZOOM, INTERACTION_MODE_POLYGON
enum  { DEFAULT_RENDERER = 0, NON_COMPOSITED_RENDERER = 1 }
 Defines various renderer types. More...
enum  BackgroundMode {
  DEFAULT, GRADIENT, IMAGE, SKYBOX,
  STEREO_SKYBOX
enum  GenericFilmicPresets { Custom = 0, Default = 1, Uncharted2 = 2 }
 Defines tone mapping generic filmic presets. More...
typedef vtkPVView Superclass
enum  { USE_BOUNDS_FOR_REDISTRIBUTION = 0x01, DATA_IS_REDISTRIBUTABLE = 0x02, USE_DATA_FOR_LOAD_BALANCING = 0x40 }
 OrderedCompositingConfiguration lets representations indicate to the view how the representation participates in data-redistribution necessary when ordered-compositing is being used. More...
- Public Types inherited from vtkPVView
typedef vtkView Superclass
- Public Types inherited from vtkView
void Update () override
void SetNumberOfXSlices (unsigned int count)
void SetXSlices (const double *values)
void SetNumberOfYSlices (unsigned int count)
void SetYSlices (const double *values)
void SetNumberOfZSlices (unsigned int count)
void SetZSlices (const double *values)
const std::vector< double > & GetSlices (int axis) const
const std::vector< double > & GetXSlices () const
const std::vector< double > & GetYSlices () const
const std::vector< double > & GetZSlices () const
void GetDataBounds (double bounds[6]) const
const char * GetXAxisLabel () const
const char * GetYAxisLabel () const
const char * GetZAxisLabel () const
const vtkClientServerStream & GetAxisLabels () const
void SetModelTransformationMatrix (vtkMatrix4x4 *)
- Public Member Functions inherited from vtkPVRenderView
virtual vtkRenderer * GetRenderer (int rendererType=DEFAULT_RENDERER)
 Returns the renderer given an int identifying its type. More...
vtkRenderWindowInteractor * GetInteractor ()
 Returns the interactor. More...
virtual void SetupInteractor (vtkRenderWindowInteractor *)
 Set the interactor. More...
void StillRender () override
 Triggers a high-resolution render. More...
void InteractiveRender () override
 Triggers a interactive render. More...
void ConfigureCompressor (const char *configuration)
 Passes the compressor configuration to the client-server synchronizer, if any. More...
virtual void ResetCameraClippingRange ()
 Resets the clipping range. More...
void InvalidateCachedSelection ()
 Invalidates cached selection. More...
void SetMaxClipBounds (double bds[6])
 Used by Cinema to enforce a consistent depth scaling. More...
virtual void SetGridAxes3DActor (vtkPVGridAxes3DActor *)
 Set the vtkPVGridAxes3DActor to use for the view. More...
virtual void SetLegendGridActor (vtkLegendScaleActor *)
 Set the vtkLegendScaleActor to use for the view. More...
virtual void SetPolarGridActor (vtkPolarAxesActor2D *)
 Set the vtkPolarAxesActor to use for the view. More...
virtual void SetCenterAxesVisibility (bool)
 Forwarded to center axes. More...
void SetParallelProjection (int mode)
 Forward to vtkCamera. More...
virtual void SynchronizeGeometryBounds ()
 Synchronizes bounds information on all nodes and reset camera clipping planes. More...
 Overridden to synchronize information among processes whenever data changes. More...
virtual void UpdateLOD ()
 Asks representations to update their LOD geometries. More...
int GetDataDistributionMode (bool low_res)
 Returns the data distribution mode to use. More...
void Deliver (int use_lod, unsigned int size, unsigned int *representation_ids) override
 Called on all processes to request data-delivery for the list of representations. More...
bool GetUseOrderedCompositing ()
 Returns true when ordered compositing is needed on the current group of processes. More...
bool GetRenderEmptyImages ()
 Returns true when the compositor should not use the empty images optimization. More...
void CopyViewUpdateOptions (vtkPVRenderView *otherView)
 Copy internal fields that are used for rendering decision such as remote/local rendering, composite and so on. More...
bool GetOSPRayContinueStreaming ()
 Has OSPRay reached the max frames? More...
void SetOSPRayRendererType (std::string)
 Set the OSPRay renderer to use. More...
virtual void SetMaterialLibrary (vtkPVMaterialLibrary *)
 For OSPRay, set the library of materials. More...
void SetViewTime (double value) override
 Get/Set the time this view is showing. More...
virtual vtkRenderViewBase * GetRenderView ()
void ScaleRendererViewports (const double viewport[4]) override
 Overridden to scale the OrientationWidget appropriately. More...
void SynchronizeMaximumIds (vtkIdType *maxPointId, vtkIdType *maxCellId)
 This is used by vtkPVHardwareSelector to synchronize element ids between all ranks involved in selection. More...
void SetHardwareSelector (vtkPVHardwareSelector *selector)
virtual void SetInteractionMode (int mode)
 Get/Set the interaction mode. More...
virtual int GetInteractionMode ()
void SetSize (int, int) override
 Overridden to call InvalidateCachedSelection() whenever the render window parameters change. More...
void SetPosition (int, int) override
virtual vtkRenderer * GetNonCompositedRenderer ()
 Gets the non-composited renderer for this view. More...
vtkCamera * GetActiveCamera ()
 Get/Set the active camera. More...
virtual void SetActiveCamera (vtkCamera *)
virtual vtkPVInteractorStyle * GetInteractorStyle ()
 Returns the interactor style. More...
void ResetCamera ()
 Resets the active camera using collective prop-bounds. More...
void ResetCamera (double bounds[6])
void ResetCameraScreenSpace (double offsetRatio=0.9)
void ResetCameraScreenSpace (double *bounds, double offsetRatio=0.9)
virtual void SetSuppressRendering (bool)
 SuppressRendering can be used to suppress the render within a StillRender or InteractiveRender. More...
virtual bool GetSuppressRendering ()
virtual void SuppressRenderingOn ()
virtual void SuppressRenderingOff ()
virtual void SetStillRenderImageReductionFactor (int)
 Get/Set the reduction-factor to use when for StillRender(). More...
virtual int GetStillRenderImageReductionFactor ()
virtual void SetInteractiveRenderImageReductionFactor (int)
 Get/Set the reduction-factor to use when for InteractiveRender(). More...
virtual int GetInteractiveRenderImageReductionFactor ()
virtual void SetRemoteRenderingThreshold (double)
 Get/Set the data-size in megabytes above which remote-rendering should be used, if possible. More...
virtual double GetRemoteRenderingThreshold ()
virtual void SetLODRenderingThreshold (double)
 Get/Set the data-size in megabytes above which LOD rendering should be used, if possible. More...
virtual double GetLODRenderingThreshold ()
virtual void SetLODResolution (double)
 Get/Set the LOD resolution. More...
virtual double GetLODResolution ()
virtual void SetUseOutlineForLODRendering (bool)
 When set to true, instead of using simplified geometry for LOD rendering, uses outline, if possible. More...
virtual bool GetUseOutlineForLODRendering ()
void SetUseLightKit (bool enable)
 Enable/Disable light kit. More...
virtual bool GetUseLightKit ()
virtual void UseLightKitOn ()
virtual void UseLightKitOff ()
void StreamingUpdate (const double view_planes[24])
void DeliverStreamedPieces (unsigned int size, unsigned int *representation_ids)
void SelectCells (int region[4], const char *array=nullptr)
 Make a selection. More...
void SelectCells (int region0, int region1, int region2, int region3, const char *array=nullptr)
void SelectPoints (int region[4], const char *array=nullptr)
void SelectPoints (int region0, int region1, int region2, int region3, const char *array=nullptr)
void Select (int field_association, int region[4], const char *array=nullptr)
void SelectPolygonPoints (int *polygon2DArray, vtkIdType arrayLen)
 Make a selection with a polygon. More...
void SelectPolygonCells (int *polygon2DArray, vtkIdType arrayLen)
void SelectPolygon (int field_association, int *polygon2DArray, vtkIdType arrayLen)
virtual vtkSelection * GetLastSelection ()
 Provides access to the last selection. More...
virtual void SetUseInteractiveRenderingForScreenshots (bool)
 Set or get whether capture should be done as StillRender or InteractiveRender when capturing screenshots. More...
virtual void UseInteractiveRenderingForScreenshotsOn ()
virtual void UseInteractiveRenderingForScreenshotsOff ()
virtual bool GetUseInteractiveRenderingForScreenshots ()
virtual bool GetRemoteRenderingAvailable ()
 Returns if remote-rendering is possible on the current group of processes. More...
void RemoteRenderingAvailableOff ()
void NVPipeAvailableOn ()
 Determine if NVPipe is an available compressor option. More...
void NVPipeAvailableOff ()
virtual bool GetUsedLODForLastRender ()
 Returns true if the most recent render used LOD. More...
void SetLockBounds (bool nv)
 Used by Cinema to enforce a consistent viewpoint and depth scaling. More...
virtual bool GetLockBounds ()
int RegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop)
 Representations that support hardware (render-buffer based) selection, should register the prop that they use for selection rendering. More...
void UnRegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop)
void SetShowAnnotation (bool val)
 Enable/disable showing of annotation for developers. More...
virtual void SetUpdateAnnotation (bool)
void SetAnnotationColor (double r, double g, double b)
 Set color of annotation text for developers. More...
virtual void SetOrientationAxesInteractivity (bool)
 Forwarded to orientation axes widget. More...
virtual void SetOrientationAxesVisibility (bool)
void SetOrientationAxesLabelColor (double r, double g, double b)
void SetOrientationAxesOutlineColor (double r, double g, double b)
void SetOrientationAxesXColor (double r, double g, double b)
void SetOrientationAxesYColor (double r, double g, double b)
void SetOrientationAxesZColor (double r, double g, double b)
void SetOrientationAxesXVisibility (bool vis)
void SetOrientationAxesYVisibility (bool vis)
void SetOrientationAxesZVisibility (bool vis)
void SetOrientationAxesXLabelText (const char *text)
void SetOrientationAxesYLabelText (const char *text)
void SetOrientationAxesZLabelText (const char *text)
void SetCameraOrientationWidgetVisibility (bool visible)
 Forwarded to camera orientation widget. More...
void SetCameraOrientationWidgetSize (int size)
void SetCameraOrientationWidgetPadding (int padding[2])
void SetCameraOrientationWidgetAnchor (int anchor)
virtual void SetCenterOfRotation (double x, double y, double z)
 Forward to vtkPVInteractorStyle instances. More...
virtual void SetRotationFactor (double factor)
void SetKeyLightWarmth (double val)
 Forward to vtkLightKit. More...
void SetKeyLightIntensity (double val)
void SetKeyLightElevation (double val)
void SetKeyLightAzimuth (double val)
void SetFillLightWarmth (double val)
void SetKeyToFillRatio (double val)
void SetFillLightElevation (double val)
void SetFillLightAzimuth (double val)
void SetBackLightWarmth (double val)
void SetKeyToBackRatio (double val)
void SetBackLightElevation (double val)
void SetBackLightAzimuth (double val)
void SetHeadLightWarmth (double val)
void SetKeyToHeadRatio (double val)
void SetMaintainLuminance (int val)
virtual void SetUseHiddenLineRemoval (bool)
 Forward to 3D renderer. More...
virtual void SetUseDepthPeeling (int val)
virtual void SetUseDepthPeelingForVolumes (bool val)
virtual void SetMaximumNumberOfPeels (int val)
virtual void SetBackgroundTexture (vtkTexture *val)
virtual void SetUseRenderViewSettingsForBackground (bool)
 When set, background color and mode will be obtained from vtkPVRenderViewSettings. More...
virtual bool GetUseRenderViewSettingsForBackground ()
virtual void SetBackgroundColorMode (int)
 API for background color selection. More...
virtual void SetBackground (double, double, double)
virtual void SetBackground (double [3])
virtual double * GetBackground ()
virtual void GetBackground (double &, double &, double &)
virtual void GetBackground (double [3])
virtual void SetBackground2 (double, double, double)
virtual void SetBackground2 (double [3])
virtual double * GetBackground2 ()
virtual void GetBackground2 (double &, double &, double &)
virtual void GetBackground2 (double [3])
virtual void SetUseEnvironmentLighting (bool)
virtual void SetEnvironmentalBG (double r, double g, double b)
 Entry point for environmental backgrounds. More...
virtual void SetEnvironmentalBG2 (double r, double g, double b)
virtual void SetEnvironmentalBGTexture (vtkTexture *val)
virtual void SetGradientEnvironmentalBG (int val)
virtual void SetTexturedEnvironmentalBG (int val)
virtual void SetBackgroundMode (int val)
void AddLight (vtkLight *)
 Entry point for dynamic lights. More...
void RemoveLight (vtkLight *)
void SetStereoCapableWindow (int val)
 Forward to vtkRenderWindow. More...
void SetStereoRender (int val)
virtual void SetStereoType (int)
virtual void SetServerStereoType (int)
void SetMultiSamples (int val)
void SetAlphaBitPlanes (int val)
void SetStencilCapable (int val)
virtual void SetCamera2DManipulators (const int manipulators[9])
 Forwarded to vtkPVInteractorStyle if present on local processes. More...
virtual void SetCamera3DManipulators (const int manipulators[9])
void SetCameraManipulators (vtkPVInteractorStyle *style, const int manipulators[9])
virtual void SetReverseMouseWheelZoomDirection (bool reverse)
virtual void SetMouseWheelZoomsToCursor (bool value)
virtual void SetCamera2DMouseWheelMotionFactor (double factor)
virtual void SetCamera3DMouseWheelMotionFactor (double factor)
virtual bool GetUseLODForInteractiveRender ()
 Returns whether the view will use LOD rendering for the next InteractiveRender() call based on the geometry sizes determined by the most recent call to Update(). More...
virtual bool GetUseDistributedRenderingForRender ()
 Returns whether the view will use distributed rendering for the next full-resolution render. More...
virtual bool GetUseDistributedRenderingForLODRender ()
 Returns whether the view will use distributed rendering for the next low-resolution render. More...
virtual vtkTypeUInt32 GetStillRenderProcesses ()
 Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next StillRender() call based on the decisions made during the most recent Update(). More...
virtual vtkTypeUInt32 GetInteractiveRenderProcesses ()
 Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next InteractiveRender() call based on the decisions made during the most recent Update() and UpdateLOD(). More...
virtual void SetUseFXAA (bool)
 Enable/disable FXAA antialiasing. More...
virtual bool GetUseFXAA ()
void SetFXAARelativeContrastThreshold (double val)
 FXAA tunable parameters. More...
void SetFXAAHardContrastThreshold (double val)
void SetFXAASubpixelBlendLimit (double val)
void SetFXAASubpixelContrastThreshold (double val)
void SetFXAAUseHighQualityEndpoints (bool val)
void SetFXAAEndpointSearchIterations (int val)
void SetUseToneMapping (bool v)
 Tone Mapping options. More...
virtual bool GetUseToneMapping ()
void SetToneMappingType (int)
void SetExposure (double)
void SetContrast (double)
void SetShoulder (double)
void SetMidIn (double)
void SetMidOut (double)
void SetHdrMax (double)
void SetUseACES (bool)
void SetGenericFilmicPresets (int t)
virtual void SetUseSSAO (bool)
 SSAO options. More...
virtual bool GetUseSSAO ()
virtual void SetUseSSAODefaultPresets (bool)
virtual void SetRadius (double)
virtual void SetKernelSize (int)
virtual void SetBias (double)
virtual void SetBlur (bool)
void AddPropToRenderer (vtkProp *prop)
 Add props directly to the view. More...
void RemovePropFromRenderer (vtkProp *prop)
bool BeginValuePassForRendering (int fieldAssociation, const char *arrayName, int component)
 Experimental API to grab re-colorable images. More...
void EndValuePassForRendering ()
vtkSmartPointer< vtkFloatArray > GrabValuePassResult ()
void CaptureZBuffer ()
 Access to the Z buffer. More...
vtkFloatArray * GetCapturedZBuffer ()
void SetEnableOSPRay (bool)
 Switches between rasterization and ray tracing. More...
bool GetEnableOSPRay ()
void SetShadows (bool)
 Controls whether OSPRay sends casts shadow rays or not. More...
bool GetShadows ()
void SetAmbientOcclusionSamples (int)
 Sets the number of occlusion query rays that OSPRay sends at each intersection. More...
int GetAmbientOcclusionSamples ()
void SetRouletteDepth (int)
 Sets the depth of monte carlo samples on the path tracer. More...
int GetRouletteDepth ()
void SetSamplesPerPixel (int)
 Set the number of primary rays that OSPRay shoots per pixel. More...
int GetSamplesPerPixel ()
void SetMaxFrames (int)
 Set the number of render passes OSPRay takes to accumulate subsampled color results. More...
int GetMaxFrames ()
void SetDenoise (bool)
 Controls whether to use image denoising to improve appearance. More...
bool GetDenoise ()
void SetLightScale (double)
 Dimish or Amplify all lights in the scene. More...
double GetLightScale ()
void SetBackgroundNorth (double x, double y, double z)
 Control of background orientation for OSPRay. More...
void SetBackgroundEast (double x, double y, double z)
void SetTimeCacheSize (int)
 Set the size of OSPRay's temporal cache. More...
int GetTimeCacheSize ()
double * ComputeVisibleBounds (vtkPVDataRepresentation *pvrepr) VTK_SIZEHINT(6)
 Compute and reduce the visible bounds of the provided representation. More...
bool IsForceDataDistributionModeSet () const
 This is an temporary/experimental option and may be removed without notice. More...
int GetForceDataDistributionMode () const
- Public Member Functions inherited from vtkPVView
virtual void SetPPI (int)
 Description: Set the screen PPI. More...
virtual int GetPPI ()
virtual bool GetViewTimeValid ()
 Get ViewTimeValid. More...
 Overridden to not call Update() directly on the input representations, instead use ProcessViewRequest() for all vtkPVDataRepresentations. More...
bool InTileDisplayMode ()
 Returns true if the application is currently in tile display mode. More...
bool InCaveDisplayMode ()
 Returns true if the application is currently in cave/immersive display mode. More...
bool GetLocalProcessSupportsInteraction ()
 Returns true if the local process can support interaction. More...
vtkRenderWindow * GetRenderWindow ()
 If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More...
vtkMTimeType GetUpdateTimeStamp ()
 Provides access to the time when Update() was last called. More...
virtual bool IsCached (vtkPVDataRepresentation *)
 Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More...
virtual void ClearCache (vtkPVDataRepresentation *)
 Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More...
virtual int * GetPosition ()
 Set the position on this view in the multiview configuration. More...
virtual void GetPosition (int &, int &)
virtual void GetPosition (int [2])
virtual int * GetSize ()
 Set the size of this view in the multiview configuration. More...
virtual void GetSize (int &, int &)
virtual void GetSize (int [2])
virtual double GetViewTime ()
virtual void SetCacheKey (double)
 Get/Set the cache key. More...
virtual double GetCacheKey ()
virtual void SetUseCache (bool)
 Get/Set whether caching is enabled. More...
virtual bool GetUseCache ()
virtual void PrepareForScreenshot ()
 These methods are used to setup the view for capturing screen shots. More...
virtual void CleanupAfterScreenshot ()
void SetTileScale (int x, int y)
 When saving screenshots with tiling, these methods get called. More...
void SetTileViewport (double x0, double y0, double x1, double y1)
void SetDeliveryManager (vtkPVDataDeliveryManager *)
 Provides access to data delivery & cache manager for this view. More...
virtual vtkPVDataDeliveryManager * GetDeliveryManager ()
- Public Member Functions inherited from vtkView
vtkView * NewInstance () const
void AddRepresentation (vtkDataRepresentation *rep)
void SetRepresentation (vtkDataRepresentation *rep)
vtkDataRepresentation * AddRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentation * SetRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentation * AddRepresentationFromInput (vtkDataObject *input)
vtkDataRepresentation * SetRepresentationFromInput (vtkDataObject *input)
void RemoveRepresentation (vtkDataRepresentation *rep)
void RemoveRepresentation (vtkAlgorithmOutput *rep)
void RemoveAllRepresentations ()
int GetNumberOfRepresentations ()
vtkDataRepresentation * GetRepresentation (int index=0)
bool IsRepresentationPresent (vtkDataRepresentation *rep)
vtkCommand * GetObserver ()
void RegisterProgress (vtkObject *algorithm, const char *message=NULL)
void UnRegisterProgress (vtkObject *algorithm)
static vtkPVMultiSliceView * New ()
static vtkPVMultiSliceView * SafeDownCast (vtkObject *o)
static void SetAxisTitle (vtkInformation *info, int axis, const char *title)
static void SetDataBounds (vtkInformation *info, const double bounds[6])
- Static Public Member Functions inherited from vtkPVRenderView
static vtkPVRenderView * New ()
static vtkPVRenderView * SafeDownCast (vtkObject *o)
static vtkInformationIntegerKey * USE_LOD ()
 USE_LOD indicates if LOD is being used for the current render/update. More...
static vtkInformationDoubleKey * LOD_RESOLUTION ()
 Indicates the LOD resolution in REQUEST_UPDATE_LOD() pass. More...
static vtkInformationIntegerKey * USE_OUTLINE_FOR_LOD ()
 Indicates the LOD must use outline if possible in REQUEST_UPDATE_LOD() pass. More...
static vtkInformationIntegerKey * RENDER_EMPTY_IMAGES ()
 Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs to disable IceT's empty image optimization. More...
static vtkInformationIntegerKey * NEED_ORDERED_COMPOSITING ()
 Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs ordered compositing. More...
static vtkInformationDoubleVectorKey * VIEW_PLANES ()
 Key used to pass meta-data about the view frustum in REQUEST_STREAMING_UPDATE() pass. More...
static vtkInformationRequestKey * REQUEST_STREAMING_UPDATE ()
 Streaming pass request. More...
static vtkInformationRequestKey * REQUEST_PROCESS_STREAMED_PIECE ()
 Pass to relay the streamed "piece" to the representations. More...
static void SetDeliverToAllProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool clone)
 Requests the view to deliver the pieces produced by the repr to all processes after a gather to the root node to merge the datasets generated by each process. More...
static void SetDeliverToClientAndRenderingProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool deliver_to_client, bool gather_before_delivery, int port=0)
 Requests the view to deliver the data to the client always. More...
static vtkAlgorithmOutput * GetPieceProducer (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
 Convenience methods used by representations to pass represented data. More...
static vtkAlgorithmOutput * GetPieceProducerLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetRedistributionMode (vtkInformation *info, vtkPVDataRepresentation *repr, int mode, int port=0)
static void SetRedistributionModeToSplitBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetRedistributionModeToDuplicateBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetRedistributionModeToUniquelyAssignBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetGeometryBounds (vtkInformation *info, vtkPVDataRepresentation *repr, const double bounds[6], vtkMatrix4x4 *transform=nullptr, int port=0)
static void SetStreamable (vtkInformation *info, vtkPVDataRepresentation *repr, bool streamable)
static void SetNextStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *piece)
static vtkDataObject * GetCurrentStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr)
static void SetRequiresDistributedRendering (vtkInformation *info, vtkPVDataRepresentation *repr, bool value, bool for_lod=false)
 Some representation only work when remote rendering or local rendering. More...
static void SetRequiresDistributedRenderingLOD (vtkInformation *info, vtkPVDataRepresentation *repr, bool value)
static vtkPVCameraCollection * GetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr)
 DiscreteCameras are a collection of cameras when specified, forces the view to only interact to a camera in the collection. More...
static void SetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr, vtkPVCameraCollection *style)
static void SetOrderedCompositingConfiguration (vtkInformation *info, vtkPVDataRepresentation *repr, int config, const double *bounds=nullptr, int port=0)
static void SetForceDataDistributionMode (vtkInformation *info, int flag)
- Static Public Member Functions inherited from vtkPVView
static vtkPVView * SafeDownCast (vtkObject *o)
static void SetEnableStreaming (bool)
static bool GetEnableStreaming ()
static vtkInformationObjectBaseKey * VIEW ()
 Key used to pass the vtkPVView pointer to the representation during any of the view passes such as REQUEST_UPDATE(), REQUEST_UPDATE_LOD(), REQUEST_RENDER(), etc. More...
static vtkInformationRequestKey * REQUEST_UPDATE ()
 This is a Update-Data pass. More...
static vtkInformationRequestKey * REQUEST_UPDATE_LOD ()
 This is a Update-LOD-Data pass. More...
static vtkInformationRequestKey * REQUEST_RENDER ()
 This is a render pass. More...
static void SetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObject * GetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObject * GetDeliveredPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObject * GetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObject * GetDeliveredPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetUseGenericOpenGLRenderWindow (bool val)
 Use this to indicate that the process should use vtkGenericOpenGLRenderWindow rather than vtkRenderWindow when creating an new render window. More...
static bool GetUseGenericOpenGLRenderWindow ()
- Static Public Member Functions inherited from vtkView
static vtkView * New ()
static vtkView * SafeDownCast (vtkObjectBase *o)
 vtkPVMultiSliceView ()
 ~vtkPVMultiSliceView () override
void AboutToRenderOnLocalProcess (bool interactive) override
 Called just before the local process renders. More...
void SetNumberOfSlices (int type, unsigned int count)
void SetSlices (int type, const double *values)
const char * GetAxisLabel (int axis) const
- Protected Member Functions inherited from vtkPVRenderView
 vtkPVRenderView ()
 ~vtkPVRenderView () override
virtual void Render (bool interactive, bool skip_rendering)
 Actual render method. More...
bool ShouldUseDistributedRendering (double geometry_size, bool using_lod)
 Returns true if distributed rendering should be used based on the geometry size. More...
bool ShouldUseLODRendering (double geometry)
 Returns true if LOD rendering should be used based on the geometry size. More...
bool IsProcessRenderingGeometriesForCompositing (bool using_distributed_rendering)
 Returns true if the local process is invovled in rendering composited geometry i.e. More...
void SetLastSelection (vtkSelection *)
 Set the last selection object. More...
virtual void UpdateCenterAxes ()
 UpdateCenterAxes(). More...
bool GetLocalProcessDoesRendering (bool using_distributed_rendering)
 Returns true if the local process is doing to do actual render or displaying an image in a viewport. More...
bool TestCollaborationCounter ()
 In multi-clients mode, ensures that all processes are in the same "state" as far as the view is concerned. More...
void SynchronizeForCollaboration ()
 Synchronizes remote-rendering related parameters for collaborative rendering in multi-clients mode. More...
virtual void BuildAnnotationText (ostream &str)
 Method to build annotation text to annotate the view with runtime information. More...
virtual bool PrepareSelect (int fieldAssociation, const char *array=nullptr)
 Prepare for selection. More...
virtual void PostSelect (vtkSelection *sel, const char *array=nullptr)
 Post process after selection. More...
virtual void UpdateBackground (vtkRenderer *renderer=nullptr)
 Updates background color. More...
void ConfigureTexture (vtkTexture *texture)
 Configure texture based on scalar type. More...
virtual void SetupAndSetRenderer (vtkRenderer *ren)
 Set the 3D renderer to use within the render view. More...
virtual unsigned int GetSynchronizationCounter ()
 SynchronizationCounter is used in multi-clients mode to ensure that the views on two different clients are in the same state as the server side. More...
virtual bool GetMakingSelection ()
 Returns true is currently generating a selection. More...
- Protected Member Functions inherited from vtkPVView
 vtkPVView (bool create_render_window=true)
 ~vtkPVView () override
vtkRenderWindow * NewRenderWindow ()
 Subclasses should use this method to create new render windows instead of directly creating a new one. More...
void SetRenderWindow (vtkRenderWindow *)
 Subclasses can use this method to set the render window created for this view. More...
void AllReduce (const vtkBoundingBox &source, vtkBoundingBox &dest)
 Reduce bounding box between all participating processes. More...
void AllReduce (vtkTypeUInt64 source, vtkTypeUInt64 &dest, int operation, bool skip_data_server=false)
 Reduce between all participating processes using the operation (vtkCommunicator::StandardOperations) specified. More...
vtkPVSession * GetSession ()
virtual bool GetInCaptureScreenshot ()
 Flag set to true between calls to PrepareForScreenshot and CleanupAfterScreenshot. More...
void SynchronizeRepresentationTemporalPipelineStates ()
 Called in Update() to sync HasTemporalPipeline flags between representations on all processes. More...
void AddRepresentationInternal (vtkDataRepresentation *rep) override
 Overridden to assign IDs to each representation. More...
void RemoveRepresentationInternal (vtkDataRepresentation *rep) override
int CallProcessViewRequest (vtkInformationRequestKey *passType, vtkInformation *request, vtkInformationVector *reply)
 Subclasses can use this method to trigger a pass on all representations. More...
- Protected Member Functions inherited from vtkView
 vtkView ()
 ~vtkView ()
virtual vtkDataRepresentation * CreateDefaultRepresentation (vtkAlgorithmOutput *conn)
virtual void AddRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void RemoveRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void SetReuseSingleRepresentation (bool)
virtual bool GetReuseSingleRepresentation ()
virtual void ReuseSingleRepresentationOn ()
virtual void ReuseSingleRepresentationOff ()
vtkNew< vtkMatrix4x4 > ModelTransformationMatrix
vtkTimeStamp ModelTransformationMatrixUpdateTime
- Protected Attributes inherited from vtkPVRenderView
vtkLightKit * LightKit
vtkRenderViewBase * RenderView
vtkRenderer * NonCompositedRenderer
vtkPVSynchronizedRenderer * SynchronizedRenderers
vtkSmartPointer< vtkRenderWindowInteractor > Interactor
vtkInteractorStyleRubberBand3D * RubberBandStyle
vtkInteractorStyleRubberBandZoom * RubberBandZoom
vtkInteractorStyleDrawPolygon * PolygonStyle
vtkPVCenterAxesActor * CenterAxes
vtkPVAxesWidget * OrientationWidget
vtkSmartPointer< vtkPVHardwareSelector > Selector
vtkSelection * LastSelection
vtkSmartPointer< vtkPVGridAxes3DActor > GridAxes3DActor
vtkSmartPointer< vtkLegendScaleActor > LegendGridActor
vtkSmartPointer< vtkPolarAxesActor2D > PolarAxesActor
vtkNew< vtkSkybox > Skybox
vtkNew< vtkCameraOrientationWidget > CameraOrientationWidget
int StillRenderImageReductionFactor
int InteractiveRenderImageReductionFactor
int InteractionMode
bool ShowAnnotation
bool UpdateAnnotation
bool SuppressRendering
vtkPVInteractorStyle * TwoDInteractorStyle
vtkPVInteractorStyle * ThreeDInteractorStyle
bool ReverseMouseWheelZoomDirection = false
vtkPVInteractorStyle * InteractorStyle
vtkWeakPointer< vtkPVCameraCollection > DiscreteCameras
unsigned int SynchronizationCounter
double RemoteRenderingThreshold
double LODRenderingThreshold
vtkBoundingBox GeometryBounds
bool UseInteractiveRenderingForScreenshots
bool NeedsOrderedCompositing
bool RenderEmptyImages
bool UseFXAA
vtkNew< vtkFXAAOptions > FXAAOptions
bool UseToneMapping
bool UseSSAO
bool UseSSAODefaultPresets
double Radius
int KernelSize
double Bias
bool Blur
double LODResolution
bool UseLightKit
bool UsedLODForLastRender
bool UseLODForInteractiveRender
bool UseOutlineForLODRendering
bool UseDistributedRenderingForRender
bool UseDistributedRenderingForLODRender
vtkTypeUInt32 StillRenderProcesses
vtkTypeUInt32 InteractiveRenderProcesses
vtkTimeStamp PriorityQueueBuildTimeStamp
 Keeps track of the time when the priority-queue for streaming was generated. More...
bool LockBounds
- Protected Attributes inherited from vtkPVView
double ViewTime
double CacheKey
bool UseCache
int Size [2]
int Position [2]
int PPI
vtkTimeStamp UpdateTimeStamp
 Keeps track of the time when vtkPVRenderView::Update() was called. More...
vtkInformation * RequestInformation
 These are passed as arguments to vtkDataRepresentation::ProcessViewRequest(). More...
vtkInformationVector * ReplyInformationVector
- Protected Attributes inherited from vtkView
bool ReuseSingleRepresentation
- Public Attributes inherited from vtkPVRenderView
double LastRepresentationVisibleBounds [6]
- Static Protected Member Functions inherited from vtkPVView
static vtkPVDataDeliveryManager * GetDeliveryManager (vtkInformation *info)
Definition at line 21 of file vtkPVMultiSliceView.h.
Definition at line 25 of file vtkPVMultiSliceView.h.
◆ vtkPVMultiSliceView()
vtkPVMultiSliceView::vtkPVMultiSliceView ( )
◆ ~vtkPVMultiSliceView()
vtkPVMultiSliceView::~vtkPVMultiSliceView ( )
static vtkPVMultiSliceView* vtkPVMultiSliceView::New ( )
virtual const char* vtkPVMultiSliceView::GetClassName ( )
Reimplemented from vtkPVRenderView.
Reimplemented in vtkPVOrthographicSliceView.
static int vtkPVMultiSliceView::IsTypeOf ( const char *  type)
virtual int vtkPVMultiSliceView::IsA ( const char *  type)
static vtkPVMultiSliceView* vtkPVMultiSliceView::SafeDownCast ( vtkObject *  o)
void vtkPVMultiSliceView::PrintSelf ( ostream &  os,
Reimplemented from vtkView.
◆ Update()
void vtkPVMultiSliceView::Update ( )
◆ SetNumberOfXSlices()
void vtkPVMultiSliceView::SetNumberOfXSlices ( unsigned int  count)
inline
Definition at line 30 of file vtkPVMultiSliceView.h.
◆ SetXSlices()
void vtkPVMultiSliceView::SetXSlices ( const double *  values)
inline
Definition at line 31 of file vtkPVMultiSliceView.h.
◆ SetNumberOfYSlices()
void vtkPVMultiSliceView::SetNumberOfYSlices ( unsigned int  count)
inline
Definition at line 32 of file vtkPVMultiSliceView.h.
◆ SetYSlices()
void vtkPVMultiSliceView::SetYSlices ( const double *  values)
inline
Definition at line 33 of file vtkPVMultiSliceView.h.
◆ SetNumberOfZSlices()
void vtkPVMultiSliceView::SetNumberOfZSlices ( unsigned int  count)
inline
Definition at line 34 of file vtkPVMultiSliceView.h.
◆ SetZSlices()
void vtkPVMultiSliceView::SetZSlices ( const double *  values)
inline
Definition at line 35 of file vtkPVMultiSliceView.h.
◆ GetSlices()
const std::vector<double>& vtkPVMultiSliceView::GetSlices ( int  axis) const
◆ GetXSlices()
const std::vector<double>& vtkPVMultiSliceView::GetXSlices ( ) const
inline
Definition at line 38 of file vtkPVMultiSliceView.h.
◆ GetYSlices()
const std::vector<double>& vtkPVMultiSliceView::GetYSlices ( ) const
inline
Definition at line 39 of file vtkPVMultiSliceView.h.
◆ GetZSlices()
const std::vector<double>& vtkPVMultiSliceView::GetZSlices ( ) const
inline
Definition at line 40 of file vtkPVMultiSliceView.h.
◆ GetDataBounds()
void vtkPVMultiSliceView::GetDataBounds ( double  bounds[6]) const
◆ GetXAxisLabel()
const char* vtkPVMultiSliceView::GetXAxisLabel ( ) const
inline
Definition at line 45 of file vtkPVMultiSliceView.h.
◆ GetYAxisLabel()
const char* vtkPVMultiSliceView::GetYAxisLabel ( ) const
inline
Definition at line 46 of file vtkPVMultiSliceView.h.
◆ GetZAxisLabel()
const char* vtkPVMultiSliceView::GetZAxisLabel ( ) const
inline
Definition at line 47 of file vtkPVMultiSliceView.h.
◆ GetAxisLabels()
const vtkClientServerStream& vtkPVMultiSliceView::GetAxisLabels ( ) const
◆ SetAxisTitle()
static void vtkPVMultiSliceView::SetAxisTitle ( vtkInformation *  info,
int  axis,
const char *  title
◆ SetDataBounds()
static void vtkPVMultiSliceView::SetDataBounds ( vtkInformation *  info,
◆ SetModelTransformationMatrix()
void vtkPVMultiSliceView::SetModelTransformationMatrix ( vtkMatrix4x4 *  )
◆ AboutToRenderOnLocalProcess()
void vtkPVMultiSliceView::AboutToRenderOnLocalProcess ( bool  interactive)
overrideprotectedvirtual
This is only called on the nodes where the rendering is going to happen.
◆ SetNumberOfSlices()
void vtkPVMultiSliceView::SetNumberOfSlices ( int  type,
unsigned int  count
◆ SetSlices()
void vtkPVMultiSliceView::SetSlices ( int  type,
◆ GetAxisLabel()
const char* vtkPVMultiSliceView::GetAxisLabel ( int  axis) const
◆ ModelTransformationMatrix
vtkNew<vtkMatrix4x4> vtkPVMultiSliceView::ModelTransformationMatrix
Definition at line 70 of file vtkPVMultiSliceView.h.
◆ ModelTransformationMatrixUpdateTime
vtkTimeStamp vtkPVMultiSliceView::ModelTransformationMatrixUpdateTime
Definition at line 72 of file vtkPVMultiSliceView.h.
