vtkPVImageSliceMapper Class Reference
Mapper for vtkImageData that renders the image using a texture applied to a quad. More...
#include <vtkPVImageSliceMapper.h>
Inheritance diagram for vtkPVImageSliceMapper:
Collaboration diagram for vtkPVImageSliceMapper:
enum  { XY_PLANE = VTK_XY_PLANE, YZ_PLANE = VTK_YZ_PLANE, XZ_PLANE = VTK_XZ_PLANE }
typedef vtkMapper Superclass
- Public Types inherited from vtkMapper
typedef vtkAbstractMapper3D Superclass
- Public Types inherited from vtkAbstractMapper3D
typedef vtkAbstractMapper Superclass
enum  DesiredOutputPrecision
void Render (vtkRenderer *ren, vtkActor *act) override
 This calls RenderPiece (in a for loop is streaming is necessary). More...
void ReleaseGraphicsResources (vtkWindow *) override
void Update (int port) override
 Update that sets the update piece first. More...
void Update () override
int Update (int port, vtkInformationVector *requests) override
int Update (vtkInformation *requests) override
void ShallowCopy (vtkAbstractMapper *m) override
 Make a shallow copy of this mapper. More...
void SetPainter (vtkPainter *)
 Get/Set the painter that does the actual rendering. More...
virtual vtkPainter * GetPainter ()
void SetInputData (vtkImageData *in)
 Specify the input data to map. More...
virtual vtkImageData * GetInput ()
virtual void SetSlice (int)
 Set/Get the current X/Y or Z slice number. More...
virtual int GetSlice ()
virtual void SetSliceMode (int)
 Set/Get the current slice mode: XY, XZ or YZ plane. More...
virtual int GetSliceMode ()
void SetSliceModeToYZPlane ()
void SetSliceModeToXZPlane ()
void SetSliceModeToXYPlane ()
virtual void SetUseXYPlane (int)
 When set, the image slice is always rendered in the XY plane (Z==0) irrespective of the image bounds. More...
virtual void UseXYPlaneOn ()
virtual void UseXYPlaneOff ()
virtual int GetUseXYPlane ()
virtual void SetPiece (int)
 If you want only a part of the data, specify by setting the piece. More...
virtual int GetPiece ()
virtual void SetNumberOfPieces (int)
virtual int GetNumberOfPieces ()
virtual void SetNumberOfSubPieces (int)
virtual int GetNumberOfSubPieces ()
virtual void SetGhostLevel (int)
 Set the number of ghost cells to return. More...
virtual int GetGhostLevel ()
double * GetBounds () override
 Return bounding box (array of six doubles) of data expressed as (xmin,xmax, ymin,ymax, zmin,zmax). More...
void GetBounds (double bounds[6]) override
- Public Member Functions inherited from vtkMapper
vtkMapper * NewInstance () const
vtkMTimeType GetMTime ()
virtual void CreateDefaultLookupTable ()
const char * GetColorModeAsString ()
virtual void SetScalarMode (int)
virtual int GetScalarMode ()
void SetScalarModeToDefault ()
void SetScalarModeToUsePointData ()
void SetScalarModeToUseCellData ()
void SetScalarModeToUsePointFieldData ()
void SetScalarModeToUseCellFieldData ()
void SetScalarModeToUseFieldData ()
virtual void SetFieldDataTupleId (vtkIdType)
virtual vtkIdType GetFieldDataTupleId ()
const char * GetScalarModeAsString ()
vtkDataSet * GetInput ()
const char * GetScalarMaterialModeAsString ()
virtual bool GetIsOpaque ()
virtual int CanUseTextureMapForColoring (vtkDataObject *input)
void ClearInvertibleColor ()
void ClearColorArrays ()
vtkUnsignedCharArray * GetColorMapColors ()
vtkFloatArray * GetColorCoordinates ()
vtkImageData * GetColorTextureMap ()
void SetLookupTable (vtkScalarsToColors *lut)
vtkScalarsToColors * GetLookupTable ()
virtual void SetScalarVisibility (int)
virtual int GetScalarVisibility ()
virtual void ScalarVisibilityOn ()
virtual void ScalarVisibilityOff ()
virtual void SetStatic (int)
virtual int GetStatic ()
virtual void StaticOn ()
virtual void StaticOff ()
virtual void SetColorMode (int)
virtual int GetColorMode ()
void SetColorModeToDefault ()
void SetColorModeToMapScalars ()
void SetColorModeToDirectScalars ()
virtual void SetInterpolateScalarsBeforeMapping (int)
virtual int GetInterpolateScalarsBeforeMapping ()
virtual void InterpolateScalarsBeforeMappingOn ()
virtual void InterpolateScalarsBeforeMappingOff ()
virtual void SetUseLookupTableScalarRange (int)
virtual int GetUseLookupTableScalarRange ()
virtual void UseLookupTableScalarRangeOn ()
virtual void UseLookupTableScalarRangeOff ()
virtual void SetScalarRange (double, double)
void SetScalarRange (double[2])
virtual double * GetScalarRange ()
virtual void GetScalarRange (double data[2])
virtual void SetImmediateModeRendering (int)
virtual int GetImmediateModeRendering ()
virtual void ImmediateModeRenderingOn ()
virtual void ImmediateModeRenderingOff ()
virtual int GetForceCompileOnly ()
void SetForceCompileOnly (int value)
void SelectColorArray (int arrayNum)
void SelectColorArray (const char *arrayName)
void ColorByArrayComponent (int arrayNum, int component)
void ColorByArrayComponent (const char *arrayName, int component)
char * GetArrayName ()
int GetArrayId ()
int GetArrayAccessMode ()
int GetArrayComponent ()
void SetRelativeCoincidentTopologyPolygonOffsetParameters (double factor, double units)
void GetRelativeCoincidentTopologyPolygonOffsetParameters (double &factor, double &units)
void SetRelativeCoincidentTopologyLineOffsetParameters (double factor, double units)
void GetRelativeCoincidentTopologyLineOffsetParameters (double &factor, double &units)
void SetRelativeCoincidentTopologyPointOffsetParameter (double units)
void GetRelativeCoincidentTopologyPointOffsetParameter (double &units)
void GetCoincidentTopologyPolygonOffsetParameters (double &factor, double &units)
void GetCoincidentTopologyLineOffsetParameters (double &factor, double &units)
void GetCoincidentTopologyPointOffsetParameter (double &units)
void SetRenderTime (double time)
virtual double GetRenderTime ()
vtkDataSet * GetInputAsDataSet ()
virtual vtkUnsignedCharArray * MapScalars (double alpha)
virtual vtkUnsignedCharArray * MapScalars (double alpha, int &cellFlag)
virtual vtkUnsignedCharArray * MapScalars (vtkDataSet *input, double alpha)
virtual vtkUnsignedCharArray * MapScalars (vtkDataSet *input, double alpha, int &cellFlag)
virtual void SetScalarMaterialMode (int)
virtual int GetScalarMaterialMode ()
void SetScalarMaterialModeToDefault ()
void SetScalarMaterialModeToAmbient ()
void SetScalarMaterialModeToDiffuse ()
void SetScalarMaterialModeToAmbientAndDiffuse ()
virtual bool GetSupportsSelection ()
void UseInvertibleColorFor (int scalarMode, int arrayAccessMode, int arrayId, const char *arrayName, int arrayComponent, double *scalarRange)
int GetArrayId ()
- Public Member Functions inherited from vtkAbstractMapper3D
vtkAbstractMapper3D * NewInstance () const
double GetLength ()
int GetNumberOfClippingPlanes ()
double * GetCenter ()
void GetCenter (double center[3])
virtual int IsARayCastMapper ()
virtual int IsARenderIntoImageMapper ()
void GetClippingPlaneInDataCoords (vtkMatrix4x4 *propMatrix, int i, double planeEquation[4])
vtkAbstractMapper * NewInstance () const
void SetClippingPlanes (vtkPlanes *planes)
virtual double GetTimeToDraw ()
void AddClippingPlane (vtkPlane *plane)
void RemoveClippingPlane (vtkPlane *plane)
void RemoveAllClippingPlanes ()
virtual void SetClippingPlanes (vtkPlaneCollection *)
virtual vtkPlaneCollection * GetClippingPlanes ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual int ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo)
virtual double GetProgress ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVImageSliceMapper * New ()
static vtkPVImageSliceMapper * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMapper
static vtkMapper * SafeDownCast (vtkObjectBase *o)
static void SetGlobalImmediateModeRendering (int val)
static void GlobalImmediateModeRenderingOn ()
static void GlobalImmediateModeRenderingOff ()
static int GetGlobalImmediateModeRendering ()
static void SetResolveCoincidentTopology (int val)
static int GetResolveCoincidentTopology ()
static void SetResolveCoincidentTopologyToDefault ()
static void SetResolveCoincidentTopologyToOff ()
static void SetResolveCoincidentTopologyToPolygonOffset ()
static void SetResolveCoincidentTopologyToShiftZBuffer ()
static void SetResolveCoincidentTopologyPolygonOffsetParameters (double factor, double units)
static void GetResolveCoincidentTopologyPolygonOffsetParameters (double &factor, double &units)
static void SetResolveCoincidentTopologyLineOffsetParameters (double factor, double units)
static void GetResolveCoincidentTopologyLineOffsetParameters (double &factor, double &units)
static void SetResolveCoincidentTopologyPointOffsetParameter (double units)
static void GetResolveCoincidentTopologyPointOffsetParameter (double &units)
static void SetResolveCoincidentTopologyPolygonOffsetFaces (int faces)
static int GetResolveCoincidentTopologyPolygonOffsetFaces ()
static void SetResolveCoincidentTopologyZShift (double val)
static double GetResolveCoincidentTopologyZShift ()
static void ValueToColor (double value, double min, double scale, unsigned char *color)
static void ColorToValue (unsigned char *color, double min, double scale, double &value)
- Static Public Member Functions inherited from vtkAbstractMapper3D
static vtkAbstractMapper3D * SafeDownCast (vtkObjectBase *o)
static vtkAbstractMapper * SafeDownCast (vtkObjectBase *o)
static vtkDataArray * GetScalars (vtkDataSet *input, int scalarMode, int arrayAccessMode, int arrayId, const char *arrayName, int &cellFlag)
static vtkAbstractArray * GetAbstractScalars (vtkDataSet *input, int scalarMode, int arrayAccessMode, int arrayId, const char *arrayName, int &cellFlag)
static vtkAlgorithm * New ()
 vtkPVImageSliceMapper ()
 ~vtkPVImageSliceMapper () override
int FillInputPortInformation (int, vtkInformation *) override
virtual void RenderPiece (vtkRenderer *ren, vtkActor *act)
 Perform the actual rendering. More...
int SetupScalars (vtkImageData *)
void RenderInternal (vtkRenderer *ren, vtkActor *act)
- Protected Member Functions inherited from vtkMapper
 vtkMapper ()
 ~vtkMapper ()
void MapScalarsToTexture (vtkAbstractArray *scalars, double alpha)
void AcquireInvertibleLookupTable ()
- Protected Member Functions inherited from vtkAbstractMapper3D
 vtkAbstractMapper3D ()
 ~vtkAbstractMapper3D ()
 vtkAbstractMapper ()
 ~vtkAbstractMapper ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkOpenGLTexture * Texture
vtkTimeStamp UpdateTime
vtkActor * PolyDataActor
vtkPainter * Painter
int Piece
int NumberOfSubPieces
int NumberOfPieces
int GhostLevel
int SliceMode
int Slice
int UseXYPlane
- Protected Attributes inherited from vtkMapper
vtkUnsignedCharArray * Colors
int InterpolateScalarsBeforeMapping
vtkFloatArray * ColorCoordinates
vtkImageData * ColorTextureMap
bool UseInvertibleColors
vtkScalarsToColors * LookupTable
int ScalarVisibility
vtkTimeStamp BuildTime
double ScalarRange [2]
int UseLookupTableScalarRange
int ImmediateModeRendering
int ColorMode
int ScalarMode
int ScalarMaterialMode
double RenderTime
int ArrayId
char ArrayName [256]
int ArrayComponent
int ArrayAccessMode
vtkIdType FieldDataTupleId
int Static
int ForceCompileOnly
vtkAbstractArray * InvertibleScalars
double CoincidentPolygonFactor
double CoincidentPolygonOffset
double CoincidentLineFactor
double CoincidentLineOffset
double CoincidentPointOffset
- Protected Attributes inherited from vtkAbstractMapper3D
double Bounds [6]
double Center [3]
vtkTimerLog * Timer
double TimeToDraw
vtkWindow * LastWindow
vtkPlaneCollection * ClippingPlanes
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Attributes inherited from vtkMapper
static vtkScalarsToColors * InvertibleLookupTable
vtkPVImageSliceMapper is a mapper for vtkImageData that renders the image by loading the image as a texture and then applying it to a quad. For 3D images, this mapper only shows a single Z slice which can be chosen using SetZSlice. By default, the image data scalars are rendering, however, this mapper provides API to select another point or cell data array. Internally, this mapper uses painters similar to those employed by vtkPainterPolyDataMapper.
See also
Definition at line 33 of file vtkPVImageSliceMapper.h.
Definition at line 37 of file vtkPVImageSliceMapper.h.
◆ anonymous enum
anonymous enum
Enumerator
XY_PLANE
YZ_PLANE
XZ_PLANE
Definition at line 71 of file vtkPVImageSliceMapper.h.
◆ vtkPVImageSliceMapper()
vtkPVImageSliceMapper::vtkPVImageSliceMapper ( )
◆ ~vtkPVImageSliceMapper()
vtkPVImageSliceMapper::~vtkPVImageSliceMapper ( )
static vtkPVImageSliceMapper* vtkPVImageSliceMapper::New ( )
virtual const char* vtkPVImageSliceMapper::GetClassName ( )
static int vtkPVImageSliceMapper::IsTypeOf ( const char *  type)
virtual int vtkPVImageSliceMapper::IsA ( const char *  type)
Reimplemented from vtkMapper.
static vtkPVImageSliceMapper* vtkPVImageSliceMapper::SafeDownCast ( vtkObject *  o)
void vtkPVImageSliceMapper::PrintSelf ( ostream &  os,
◆ Render()
void vtkPVImageSliceMapper::Render ( vtkRenderer *  ren,
vtkActor *  act
Implements vtkMapper.
◆ ReleaseGraphicsResources()
void vtkPVImageSliceMapper::ReleaseGraphicsResources ( vtkWindow *  )
◆ SetPainter()
void vtkPVImageSliceMapper::SetPainter ( vtkPainter *  )
◆ GetPainter()
virtual vtkPainter* vtkPVImageSliceMapper::GetPainter ( )
◆ SetInputData()
void vtkPVImageSliceMapper::SetInputData ( vtkImageData *  in)
◆ GetInput()
virtual vtkImageData* vtkPVImageSliceMapper::GetInput ( )
◆ SetSlice()
virtual void vtkPVImageSliceMapper::SetSlice ( int  )
◆ GetSlice()
virtual int vtkPVImageSliceMapper::GetSlice ( )
◆ SetSliceMode()
virtual void vtkPVImageSliceMapper::SetSliceMode ( int  )
Note that this actually refers to the indices/extents, so a better name would be IJ, IK, or JK plane. The input image's DirectionMatrix can change the mapping to physical XYZ axes.
◆ GetSliceMode()
virtual int vtkPVImageSliceMapper::GetSliceMode ( )
◆ SetSliceModeToYZPlane()
void vtkPVImageSliceMapper::SetSliceModeToYZPlane ( )
inline
Definition at line 89 of file vtkPVImageSliceMapper.h.
◆ SetSliceModeToXZPlane()
void vtkPVImageSliceMapper::SetSliceModeToXZPlane ( )
inline
Definition at line 90 of file vtkPVImageSliceMapper.h.
◆ SetSliceModeToXYPlane()
void vtkPVImageSliceMapper::SetSliceModeToXYPlane ( )
inline
Definition at line 91 of file vtkPVImageSliceMapper.h.
◆ SetUseXYPlane()
virtual void vtkPVImageSliceMapper::SetUseXYPlane ( int  )
Default is Off.
◆ UseXYPlaneOn()
virtual void vtkPVImageSliceMapper::UseXYPlaneOn ( )
Default is Off.
◆ UseXYPlaneOff()
virtual void vtkPVImageSliceMapper::UseXYPlaneOff ( )
Default is Off.
◆ GetUseXYPlane()
virtual int vtkPVImageSliceMapper::GetUseXYPlane ( )
Default is Off.
◆ Update() [1/4]
void vtkPVImageSliceMapper::Update ( int  port)
◆ Update() [2/4]
void vtkPVImageSliceMapper::Update ( void  )
inlineoverridevirtual
Definition at line 108 of file vtkPVImageSliceMapper.h.
◆ Update() [3/4]
int vtkPVImageSliceMapper::Update ( int  port,
vtkInformationVector *  requests
Definition at line 109 of file vtkPVImageSliceMapper.h.
◆ Update() [4/4]
int vtkPVImageSliceMapper::Update ( vtkInformation *  requests)
Definition at line 113 of file vtkPVImageSliceMapper.h.
◆ SetPiece()
virtual void vtkPVImageSliceMapper::SetPiece ( int  )
◆ GetPiece()
virtual int vtkPVImageSliceMapper::GetPiece ( )
◆ SetNumberOfPieces()
virtual void vtkPVImageSliceMapper::SetNumberOfPieces ( int  )
◆ GetNumberOfPieces()
virtual int vtkPVImageSliceMapper::GetNumberOfPieces ( )
◆ SetNumberOfSubPieces()
virtual void vtkPVImageSliceMapper::SetNumberOfSubPieces ( int  )
◆ GetNumberOfSubPieces()
virtual int vtkPVImageSliceMapper::GetNumberOfSubPieces ( )
◆ SetGhostLevel()
virtual void vtkPVImageSliceMapper::SetGhostLevel ( int  )
◆ GetGhostLevel()
virtual int vtkPVImageSliceMapper::GetGhostLevel ( )
◆ GetBounds() [1/2]
double* vtkPVImageSliceMapper::GetBounds ( )
◆ GetBounds() [2/2]
void vtkPVImageSliceMapper::GetBounds ( double  bounds[6])
Definition at line 141 of file vtkPVImageSliceMapper.h.
◆ ShallowCopy()
void vtkPVImageSliceMapper::ShallowCopy ( vtkAbstractMapper *  m)
override
◆ FillInputPortInformation()
int vtkPVImageSliceMapper::FillInputPortInformation ( int  ,
vtkInformation *
overrideprotectedvirtual
◆ RenderPiece()
virtual void vtkPVImageSliceMapper::RenderPiece ( vtkRenderer *  ren,
vtkActor *  act
protectedvirtual
◆ SetupScalars()
int vtkPVImageSliceMapper::SetupScalars ( vtkImageData *  )
◆ RenderInternal()
void vtkPVImageSliceMapper::RenderInternal ( vtkRenderer *  ren,
vtkActor *  act
◆ Texture
vtkOpenGLTexture* vtkPVImageSliceMapper::Texture
Definition at line 161 of file vtkPVImageSliceMapper.h.
◆ UpdateTime
vtkTimeStamp vtkPVImageSliceMapper::UpdateTime
Definition at line 164 of file vtkPVImageSliceMapper.h.
◆ PolyDataActor
vtkActor* vtkPVImageSliceMapper::PolyDataActor
Definition at line 165 of file vtkPVImageSliceMapper.h.
◆ Painter
vtkPainter* vtkPVImageSliceMapper::Painter
Definition at line 167 of file vtkPVImageSliceMapper.h.
◆ Piece
int vtkPVImageSliceMapper::Piece
Definition at line 169 of file vtkPVImageSliceMapper.h.
◆ NumberOfSubPieces
int vtkPVImageSliceMapper::NumberOfSubPieces
Definition at line 170 of file vtkPVImageSliceMapper.h.
◆ NumberOfPieces
int vtkPVImageSliceMapper::NumberOfPieces
Definition at line 171 of file vtkPVImageSliceMapper.h.
◆ GhostLevel
int vtkPVImageSliceMapper::GhostLevel
Definition at line 172 of file vtkPVImageSliceMapper.h.
◆ SliceMode
int vtkPVImageSliceMapper::SliceMode
Definition at line 174 of file vtkPVImageSliceMapper.h.
◆ Slice
Definition at line 175 of file vtkPVImageSliceMapper.h.
◆ UseXYPlane
int vtkPVImageSliceMapper::UseXYPlane
Definition at line 176 of file vtkPVImageSliceMapper.h.
