vtkFileSeriesReader Class Reference
meta-reader to read file series More...
#include <vtkFileSeriesReader.h>
Inheritance diagram for vtkFileSeriesReader:
Collaboration diagram for vtkFileSeriesReader:
typedef vtkMetaReader Superclass
- Public Types inherited from vtkMetaReader
enum  DesiredOutputPrecision
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
 All pipeline passes are forwarded to the internal reader. More...
virtual int CanReadFile (const char *filename)
 CanReadFile is forwarded to the internal reader if it supports it. More...
virtual void AddFileName (const char *fname)
 Adds names of files to be read. More...
virtual void RemoveAllFileNames ()
 Remove all file names. More...
virtual unsigned int GetNumberOfFileNames ()
 Returns the number of file names added by AddFileName. More...
virtual const char * GetFileName (unsigned int idx)
 Returns the name of a file with index idx. More...
const char * GetCurrentFileName ()
virtual int GetUseMetaFile ()
 If true, then use the meta file. More...
virtual void SetUseMetaFile (int)
virtual void UseMetaFileOn ()
virtual void UseMetaFileOff ()
virtual bool GetIgnoreReaderTime ()
 If true, then treat file series like it does not contain any time step values. More...
virtual void SetIgnoreReaderTime (bool)
virtual void IgnoreReaderTimeOn ()
virtual void IgnoreReaderTimeOff ()
- Public Member Functions inherited from vtkMetaReader
 vtkMetaReader ()
 ~vtkMetaReader () override
vtkMTimeType GetMTime () override
 Return the MTime when also considering the internal reader. More...
virtual void SetReader (vtkAlgorithm *)
 Set/get the internal reader. More...
virtual vtkAlgorithm * GetReader ()
void SetMetaFileName (const char *name)
 Get/set the filename for the meta-file. More...
char * GetMetaFileName ()
virtual vtkIdType * GetFileIndexRange ()
 Returns the available range of file indexes. More...
virtual void GetFileIndexRange (vtkIdType &, vtkIdType &)
virtual void GetFileIndexRange (vtkIdType [2])
vtkIdType GetFileIndex ()
 Get/set the index of the file to read. More...
void SetFileIndex (vtkIdType i)
virtual void SetFileNameMethod (const char *)
 Name of the method used to set the file name of the internal reader. More...
virtual char * GetFileNameMethod ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkFileSeriesReader * New ()
static vtkFileSeriesReader * SafeDownCast (vtkObject *o)
static vtkInformationIntegerKey * FILE_SERIES_NUMBER_OF_FILES ()
static vtkInformationIntegerKey * FILE_SERIES_CURRENT_FILE_NUMBER ()
static vtkInformationStringKey * FILE_SERIES_FIRST_FILENAME ()
- Static Public Member Functions inherited from vtkMetaReader
static vtkMetaReader * New ()
static vtkMetaReader * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkFileSeriesReader ()
 ~vtkFileSeriesReader () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
virtual int RequestInformationForInput (int index, vtkInformation *request=nullptr, vtkInformationVector *outputVector=nullptr)
 Make sure the reader's output is set to the given index and, if it changed, run RequestInformation on the reader. More...
virtual int ReadMetaDataFile (const char *metafilename, vtkStringArray *filesToRead, std::vector< double > &timeValues, int maxFilesToRead=VTK_INT_MAX)
 Reads a metadata file and returns a list of filenames (in filesToRead). More...
virtual void UpdateMetaData ()
 Re-reads information from the metadata file, if necessary. More...
void ResetTimeRanges ()
 Resets information about TimeRanges. More...
void RemoveAllFileNamesInternal ()
 Add/Remove filenames without changing the MTime. More...
void AddFileNameInternal (const char *)
virtual void RemoveAllRealFileNamesInternal ()
 Remove all real file names. More...
void CopyRealFileNamesFromFileNames ()
 Set the real filenames to those in the internal FileNames. More...
int ChooseInput (vtkInformation *)
- Protected Member Functions inherited from vtkMetaReader
virtual void Set_MetaFileName (const char *)
virtual char * Get_MetaFileName ()
virtual void Set_FileIndex (vtkIdType)
virtual vtkIdType Get_FileIndex ()
void ReaderSetFileName (const char *filename)
int ReaderCanReadFile (const char *filename)
std::string FromRelativeToMetaFile (const char *metaFileName, const char *fileName)
 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int UseMetaFile
 True if use a meta-file, false otherwise. More...
bool UseJsonMetaFile
 True if meta-file is of Json format, false otherwise. More...
bool IgnoreReaderTime
- Protected Attributes inherited from vtkMetaReader
vtkAlgorithm * Reader
vtkMTimeType FileNameMTime
vtkMTimeType BeforeFileNameMTime
char * FileNameMethod
vtkIdType _FileIndex
vtkMTimeType FileIndexMTime
vtkIdType FileIndexRange [2]
char * _MetaFileName
vtkMTimeType MetaFileNameMTime
vtkTimeStamp MetaFileReadTime
 Records the time when the meta-file was read. More...
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkFileSeriesReader is a meta-reader that can work with various readers to load file series. To the pipeline, it looks like a reader that supports time. It updates the file name to the internal reader whenever a different time step is requested.
If the reader already supports time, then this meta-filter will multiplex the time. It will union together all the times and forward time requests to the file with the correct time. Overlaps are handled by requesting data from the file with the upper range the farthest in the future.
There are three ways to specify a series of files. The first way is by adding the filenames one at a time with the AddFileName method.
The second way is by providing (with the AddFileName method) a meta file that specifies a list of files. This format allows the user to specify a time value in addition to a filename for each step. The format is as follows:
* "file-series-version" : "version",
* "files" : [
* { "name" : "filename1", "time" : timeValue1 },
* { "name" : "filename2", "time" : timeValue2 },
Here is an example:
* "file-series-version" : "1.0",
* "files" : [
* { "name" : "foo1.vtk", "time" : 0 },
* { "name" : "foo2.vtk", "time" : 5.5 },
* { "name" : "foo3.vtk", "time" : 11.2 }]
The current version is 1.0.
The third way is by providing a single meta file which is a simple text file that lists a file per line. The files can be relative to the meta file. This method is useful when the actual reader points to a set of files itself. The UseMetaFile enables this method of specifying the files. The filename is set with SetMetaFileName in this case. Do not use the AddFileName() method when using SetMetaFileName() as names set with AddFileName() will be ignored.
Definition at line 74 of file vtkFileSeriesReader.h.
Definition at line 78 of file vtkFileSeriesReader.h.
◆ vtkFileSeriesReader()
vtkFileSeriesReader::vtkFileSeriesReader ( )
◆ ~vtkFileSeriesReader()
vtkFileSeriesReader::~vtkFileSeriesReader ( )
static vtkFileSeriesReader* vtkFileSeriesReader::New ( )
virtual const char* vtkFileSeriesReader::GetClassName ( )
static int vtkFileSeriesReader::IsTypeOf ( const char *  type)
virtual int vtkFileSeriesReader::IsA ( const char *  type)
static vtkFileSeriesReader* vtkFileSeriesReader::SafeDownCast ( vtkObject *  o)
void vtkFileSeriesReader::PrintSelf ( ostream &  os,
◆ ProcessRequest()
int vtkFileSeriesReader::ProcessRequest ( vtkInformation *  ,
vtkInformationVector **  ,
The vtkFileSeriesReader reports time steps in RequestInformation. It updated the file name of the internal in RequestUpdateExtent based on the time step request.
Reimplemented in vtkImageFileSeriesReader.
◆ CanReadFile()
virtual int vtkFileSeriesReader::CanReadFile ( const char *  filename)
◆ AddFileName()
virtual void vtkFileSeriesReader::AddFileName ( const char *  fname)
The files are read in the order they are added.
◆ RemoveAllFileNames()
virtual void vtkFileSeriesReader::RemoveAllFileNames ( )
◆ GetNumberOfFileNames()
virtual unsigned int vtkFileSeriesReader::GetNumberOfFileNames ( )
◆ GetFileName()
virtual const char* vtkFileSeriesReader::GetFileName ( unsigned int  idx)
◆ GetCurrentFileName()
const char* vtkFileSeriesReader::GetCurrentFileName ( )
◆ GetUseMetaFile()
virtual int vtkFileSeriesReader::GetUseMetaFile ( )
False by default.
◆ SetUseMetaFile()
virtual void vtkFileSeriesReader::SetUseMetaFile ( int  )
False by default.
◆ UseMetaFileOn()
virtual void vtkFileSeriesReader::UseMetaFileOn ( )
False by default.
◆ UseMetaFileOff()
virtual void vtkFileSeriesReader::UseMetaFileOff ( )
False by default.
◆ GetIgnoreReaderTime()
virtual bool vtkFileSeriesReader::GetIgnoreReaderTime ( )
False by default.
◆ SetIgnoreReaderTime()
virtual void vtkFileSeriesReader::SetIgnoreReaderTime ( bool  )
False by default.
◆ IgnoreReaderTimeOn()
virtual void vtkFileSeriesReader::IgnoreReaderTimeOn ( )
False by default.
◆ IgnoreReaderTimeOff()
virtual void vtkFileSeriesReader::IgnoreReaderTimeOff ( )
False by default.
◆ FILE_SERIES_NUMBER_OF_FILES()
static vtkInformationIntegerKey* vtkFileSeriesReader::FILE_SERIES_NUMBER_OF_FILES ( )
◆ FILE_SERIES_CURRENT_FILE_NUMBER()
static vtkInformationIntegerKey* vtkFileSeriesReader::FILE_SERIES_CURRENT_FILE_NUMBER ( )
◆ FILE_SERIES_FIRST_FILENAME()
static vtkInformationStringKey* vtkFileSeriesReader::FILE_SERIES_FIRST_FILENAME ( )
◆ RequestInformation()
int vtkFileSeriesReader::RequestInformation ( vtkInformation *  request,
overrideprotectedvirtual
Reimplemented in vtkExodusFileSeriesReader.
◆ RequestUpdateExtent()
int vtkFileSeriesReader::RequestUpdateExtent ( vtkInformation *  ,
◆ RequestUpdateTime()
int vtkFileSeriesReader::RequestUpdateTime ( vtkInformation *  ,
inlineoverrideprotected
Definition at line 150 of file vtkFileSeriesReader.h.
◆ RequestUpdateTimeDependentInformation()
virtual int vtkFileSeriesReader::RequestUpdateTimeDependentInformation ( vtkInformation *  ,
inlineprotectedvirtual
Reimplemented in vtkAMRFileSeriesReader.
Definition at line 154 of file vtkFileSeriesReader.h.
◆ RequestData()
int vtkFileSeriesReader::RequestData ( vtkInformation *  request,
◆ FillOutputPortInformation()
int vtkFileSeriesReader::FillOutputPortInformation ( int  port,
vtkInformation *  info
◆ RequestInformationForInput()
virtual int vtkFileSeriesReader::RequestInformationForInput ( int  index,
vtkInformation *  request = nullptr,
vtkInformationVector *  outputVector = nullptr
protectedvirtual
◆ ReadMetaDataFile()
virtual int vtkFileSeriesReader::ReadMetaDataFile ( const char *  metafilename,
vtkStringArray *  filesToRead,
std::vector< double > &  timeValues,
int  maxFilesToRead = VTK_INT_MAX
protectedvirtual
If the file could not be read correctly, 0 is returned.
◆ UpdateMetaData()
virtual void vtkFileSeriesReader::UpdateMetaData ( )
protectedvirtual
◆ ResetTimeRanges()
void vtkFileSeriesReader::ResetTimeRanges ( )
Called in RequestInformation().
◆ RemoveAllFileNamesInternal()
void vtkFileSeriesReader::RemoveAllFileNamesInternal ( )
◆ AddFileNameInternal()
void vtkFileSeriesReader::AddFileNameInternal ( const char *  )
◆ RemoveAllRealFileNamesInternal()
virtual void vtkFileSeriesReader::RemoveAllRealFileNamesInternal ( )
protectedvirtual
◆ CopyRealFileNamesFromFileNames()
void vtkFileSeriesReader::CopyRealFileNamesFromFileNames ( )
◆ ChooseInput()
int vtkFileSeriesReader::ChooseInput ( vtkInformation *  )
◆ UseMetaFile
int vtkFileSeriesReader::UseMetaFile
Definition at line 181 of file vtkFileSeriesReader.h.
◆ UseJsonMetaFile
bool vtkFileSeriesReader::UseJsonMetaFile
Definition at line 186 of file vtkFileSeriesReader.h.
◆ IgnoreReaderTime
bool vtkFileSeriesReader::IgnoreReaderTime
Definition at line 214 of file vtkFileSeriesReader.h.
