vtkAMRFileSeriesReader Class Reference
#include <vtkAMRFileSeriesReader.h>
Inheritance diagram for vtkAMRFileSeriesReader:
Collaboration diagram for vtkAMRFileSeriesReader:
typedef vtkFileSeriesReader Superclass
- Public Types inherited from vtkFileSeriesReader
typedef vtkMetaReader Superclass
- Public Types inherited from vtkMetaReader
enum  DesiredOutputPrecision
- Public Member Functions inherited from vtkFileSeriesReader
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
 All pipeline passes are forwarded to the internal reader. More...
virtual int CanReadFile (const char *filename)
 CanReadFile is forwarded to the internal reader if it supports it. More...
virtual void AddFileName (const char *fname)
 Adds names of files to be read. More...
virtual void RemoveAllFileNames ()
 Remove all file names. More...
virtual unsigned int GetNumberOfFileNames ()
 Returns the number of file names added by AddFileName. More...
virtual const char * GetFileName (unsigned int idx)
 Returns the name of a file with index idx. More...
const char * GetCurrentFileName ()
virtual int GetUseMetaFile ()
 If true, then use the meta file. More...
virtual void SetUseMetaFile (int)
virtual void UseMetaFileOn ()
virtual void UseMetaFileOff ()
virtual bool GetIgnoreReaderTime ()
 If true, then treat file series like it does not contain any time step values. More...
virtual void SetIgnoreReaderTime (bool)
virtual void IgnoreReaderTimeOn ()
virtual void IgnoreReaderTimeOff ()
- Public Member Functions inherited from vtkMetaReader
 vtkMetaReader ()
 ~vtkMetaReader () override
vtkMTimeType GetMTime () override
 Return the MTime when also considering the internal reader. More...
virtual void SetReader (vtkAlgorithm *)
 Set/get the internal reader. More...
virtual vtkAlgorithm * GetReader ()
void SetMetaFileName (const char *name)
 Get/set the filename for the meta-file. More...
char * GetMetaFileName ()
virtual vtkIdType * GetFileIndexRange ()
 Returns the available range of file indexes. More...
virtual void GetFileIndexRange (vtkIdType &, vtkIdType &)
virtual void GetFileIndexRange (vtkIdType [2])
vtkIdType GetFileIndex ()
 Get/set the index of the file to read. More...
void SetFileIndex (vtkIdType i)
virtual void SetFileNameMethod (const char *)
 Name of the method used to set the file name of the internal reader. More...
virtual char * GetFileNameMethod ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAMRFileSeriesReader * New ()
static vtkAMRFileSeriesReader * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkFileSeriesReader
static vtkFileSeriesReader * New ()
static vtkFileSeriesReader * SafeDownCast (vtkObject *o)
static vtkInformationIntegerKey * FILE_SERIES_NUMBER_OF_FILES ()
static vtkInformationIntegerKey * FILE_SERIES_CURRENT_FILE_NUMBER ()
static vtkInformationStringKey * FILE_SERIES_FIRST_FILENAME ()
- Static Public Member Functions inherited from vtkMetaReader
static vtkMetaReader * New ()
static vtkMetaReader * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int RequestUpdateTimeDependentInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
- Protected Member Functions inherited from vtkFileSeriesReader
 vtkFileSeriesReader ()
 ~vtkFileSeriesReader () override
int RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
virtual int RequestInformationForInput (int index, vtkInformation *request=nullptr, vtkInformationVector *outputVector=nullptr)
 Make sure the reader's output is set to the given index and, if it changed, run RequestInformation on the reader. More...
virtual int ReadMetaDataFile (const char *metafilename, vtkStringArray *filesToRead, std::vector< double > &timeValues, int maxFilesToRead=VTK_INT_MAX)
 Reads a metadata file and returns a list of filenames (in filesToRead). More...
virtual void UpdateMetaData ()
 Re-reads information from the metadata file, if necessary. More...
void ResetTimeRanges ()
 Resets information about TimeRanges. More...
void RemoveAllFileNamesInternal ()
 Add/Remove filenames without changing the MTime. More...
void AddFileNameInternal (const char *)
virtual void RemoveAllRealFileNamesInternal ()
 Remove all real file names. More...
void CopyRealFileNamesFromFileNames ()
 Set the real filenames to those in the internal FileNames. More...
int ChooseInput (vtkInformation *)
- Protected Member Functions inherited from vtkMetaReader
virtual void Set_MetaFileName (const char *)
virtual char * Get_MetaFileName ()
virtual void Set_FileIndex (vtkIdType)
virtual vtkIdType Get_FileIndex ()
void ReaderSetFileName (const char *filename)
int ReaderCanReadFile (const char *filename)
std::string FromRelativeToMetaFile (const char *metaFileName, const char *fileName)
 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Attributes inherited from vtkFileSeriesReader
int UseMetaFile
 True if use a meta-file, false otherwise. More...
bool UseJsonMetaFile
 True if meta-file is of Json format, false otherwise. More...
bool IgnoreReaderTime
- Protected Attributes inherited from vtkMetaReader
vtkAlgorithm * Reader
vtkMTimeType FileNameMTime
vtkMTimeType BeforeFileNameMTime
char * FileNameMethod
vtkIdType _FileIndex
vtkMTimeType FileIndexMTime
vtkIdType FileIndexRange [2]
char * _MetaFileName
vtkMTimeType MetaFileNameMTime
vtkTimeStamp MetaFileReadTime
 Records the time when the meta-file was read. More...
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Definition at line 10 of file vtkAMRFileSeriesReader.h.
Definition at line 14 of file vtkAMRFileSeriesReader.h.
static vtkAMRFileSeriesReader* vtkAMRFileSeriesReader::New ( )
virtual const char* vtkAMRFileSeriesReader::GetClassName ( )
Reimplemented from vtkFileSeriesReader.
static int vtkAMRFileSeriesReader::IsTypeOf ( const char *  type)
virtual int vtkAMRFileSeriesReader::IsA ( const char *  type)
static vtkAMRFileSeriesReader* vtkAMRFileSeriesReader::SafeDownCast ( vtkObject *  o)
void vtkAMRFileSeriesReader::PrintSelf ( ostream &  os,
◆ RequestInformation()
int vtkAMRFileSeriesReader::RequestInformation ( vtkInformation *  request,
overrideprotectedvirtual
◆ RequestUpdateTime()
int vtkAMRFileSeriesReader::RequestUpdateTime ( vtkInformation *  ,
vtkInformationVector **  ,
◆ RequestUpdateTimeDependentInformation()
int vtkAMRFileSeriesReader::RequestUpdateTimeDependentInformation ( vtkInformation *  ,
