vtkRawImageFileSeriesReader Class Reference
adds support for optionally reading raw image stacks. More...
#include <vtkRawImageFileSeriesReader.h>
Inheritance diagram for vtkRawImageFileSeriesReader:
Collaboration diagram for vtkRawImageFileSeriesReader:
typedef vtkImageFileSeriesReader Superclass
- Public Types inherited from vtkImageFileSeriesReader
typedef vtkFileSeriesReader Superclass
- Public Types inherited from vtkFileSeriesReader
typedef vtkMetaReader Superclass
- Public Types inherited from vtkMetaReader
enum  DesiredOutputPrecision
virtual void SetFileDimensionality (int)
 The number of dimensions stored in a file. More...
virtual int GetFileDimensionality ()
virtual void SetDataExtent (int, int, int, int, int, int)
 Get/Set the extent of the data on disk. More...
virtual void SetDataExtent (int [6])
virtual int * GetDataExtent ()
virtual void GetDataExtent (int &, int &, int &, int &, int &, int &)
virtual void GetDataExtent (int [6])
- Public Member Functions inherited from vtkImageFileSeriesReader
virtual void SetReadAsImageStack (bool)
virtual bool GetReadAsImageStack ()
virtual void ReadAsImageStackOn ()
virtual void ReadAsImageStackOff ()
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
 Overridden to directly call the internal reader after passing it the correct filenames when ReadAsImageStack is true. More...
- Public Member Functions inherited from vtkFileSeriesReader
virtual int CanReadFile (const char *filename)
 CanReadFile is forwarded to the internal reader if it supports it. More...
virtual void AddFileName (const char *fname)
 Adds names of files to be read. More...
virtual void RemoveAllFileNames ()
 Remove all file names. More...
virtual unsigned int GetNumberOfFileNames ()
 Returns the number of file names added by AddFileName. More...
virtual const char * GetFileName (unsigned int idx)
 Returns the name of a file with index idx. More...
const char * GetCurrentFileName ()
virtual int GetUseMetaFile ()
 If true, then use the meta file. More...
virtual void SetUseMetaFile (int)
virtual void UseMetaFileOn ()
virtual void UseMetaFileOff ()
virtual bool GetIgnoreReaderTime ()
 If true, then treat file series like it does not contain any time step values. More...
virtual void SetIgnoreReaderTime (bool)
virtual void IgnoreReaderTimeOn ()
virtual void IgnoreReaderTimeOff ()
- Public Member Functions inherited from vtkMetaReader
 vtkMetaReader ()
 ~vtkMetaReader () override
vtkMTimeType GetMTime () override
 Return the MTime when also considering the internal reader. More...
virtual void SetReader (vtkAlgorithm *)
 Set/get the internal reader. More...
virtual vtkAlgorithm * GetReader ()
void SetMetaFileName (const char *name)
 Get/set the filename for the meta-file. More...
char * GetMetaFileName ()
virtual vtkIdType * GetFileIndexRange ()
 Returns the available range of file indexes. More...
virtual void GetFileIndexRange (vtkIdType &, vtkIdType &)
virtual void GetFileIndexRange (vtkIdType [2])
vtkIdType GetFileIndex ()
 Get/set the index of the file to read. More...
void SetFileIndex (vtkIdType i)
virtual void SetFileNameMethod (const char *)
 Name of the method used to set the file name of the internal reader. More...
virtual char * GetFileNameMethod ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkRawImageFileSeriesReader * New ()
static vtkRawImageFileSeriesReader * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkImageFileSeriesReader
static vtkImageFileSeriesReader * New ()
static vtkImageFileSeriesReader * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkFileSeriesReader
static vtkFileSeriesReader * New ()
static vtkFileSeriesReader * SafeDownCast (vtkObject *o)
static vtkInformationIntegerKey * FILE_SERIES_NUMBER_OF_FILES ()
static vtkInformationIntegerKey * FILE_SERIES_CURRENT_FILE_NUMBER ()
static vtkInformationStringKey * FILE_SERIES_FIRST_FILENAME ()
- Static Public Member Functions inherited from vtkMetaReader
static vtkMetaReader * New ()
static vtkMetaReader * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkRawImageFileSeriesReader ()
 ~vtkRawImageFileSeriesReader () override
void UpdateReaderDataExtent () override
 Update the reader extent if the image file format does not know what it is (e.g. More...
- Protected Member Functions inherited from vtkImageFileSeriesReader
 vtkImageFileSeriesReader ()
 ~vtkImageFileSeriesReader () override
void UpdateFileNames ()
- Protected Member Functions inherited from vtkFileSeriesReader
 vtkFileSeriesReader ()
 ~vtkFileSeriesReader () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
virtual int RequestInformationForInput (int index, vtkInformation *request=nullptr, vtkInformationVector *outputVector=nullptr)
 Make sure the reader's output is set to the given index and, if it changed, run RequestInformation on the reader. More...
virtual int ReadMetaDataFile (const char *metafilename, vtkStringArray *filesToRead, std::vector< double > &timeValues, int maxFilesToRead=VTK_INT_MAX)
 Reads a metadata file and returns a list of filenames (in filesToRead). More...
virtual void UpdateMetaData ()
 Re-reads information from the metadata file, if necessary. More...
void ResetTimeRanges ()
 Resets information about TimeRanges. More...
void RemoveAllFileNamesInternal ()
 Add/Remove filenames without changing the MTime. More...
void AddFileNameInternal (const char *)
virtual void RemoveAllRealFileNamesInternal ()
 Remove all real file names. More...
void CopyRealFileNamesFromFileNames ()
 Set the real filenames to those in the internal FileNames. More...
int ChooseInput (vtkInformation *)
- Protected Member Functions inherited from vtkMetaReader
virtual void Set_MetaFileName (const char *)
virtual char * Get_MetaFileName ()
virtual void Set_FileIndex (vtkIdType)
virtual vtkIdType Get_FileIndex ()
void ReaderSetFileName (const char *filename)
int ReaderCanReadFile (const char *filename)
std::string FromRelativeToMetaFile (const char *metaFileName, const char *fileName)
 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int DataExtent [6]
 Raw files don't have any extent information in them and are required to be set by the user. More...
int FileDimensionality
 The dimensionality that we pass to the actual image reader. More...
- Protected Attributes inherited from vtkImageFileSeriesReader
bool ReadAsImageStack
- Protected Attributes inherited from vtkFileSeriesReader
int UseMetaFile
 True if use a meta-file, false otherwise. More...
bool UseJsonMetaFile
 True if meta-file is of Json format, false otherwise. More...
bool IgnoreReaderTime
- Protected Attributes inherited from vtkMetaReader
vtkAlgorithm * Reader
vtkMTimeType FileNameMTime
vtkMTimeType BeforeFileNameMTime
char * FileNameMethod
vtkIdType _FileIndex
vtkMTimeType FileIndexMTime
vtkIdType FileIndexRange [2]
char * _MetaFileName
vtkMTimeType MetaFileNameMTime
vtkTimeStamp MetaFileReadTime
 Records the time when the meta-file was read. More...
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkRawImageFileSeriesReader is designed to read in raw files. The issue with raw files is that the extents are not known and must be passed to vtkImageReader2 and subclasses.
Definition at line 18 of file vtkRawImageFileSeriesReader.h.
Definition at line 22 of file vtkRawImageFileSeriesReader.h.
◆ vtkRawImageFileSeriesReader()
vtkRawImageFileSeriesReader::vtkRawImageFileSeriesReader ( )
◆ ~vtkRawImageFileSeriesReader()
vtkRawImageFileSeriesReader::~vtkRawImageFileSeriesReader ( )
static vtkRawImageFileSeriesReader* vtkRawImageFileSeriesReader::New ( )
virtual const char* vtkRawImageFileSeriesReader::GetClassName ( )
Reimplemented from vtkImageFileSeriesReader.
static int vtkRawImageFileSeriesReader::IsTypeOf ( const char *  type)
virtual int vtkRawImageFileSeriesReader::IsA ( const char *  type)
static vtkRawImageFileSeriesReader* vtkRawImageFileSeriesReader::SafeDownCast ( vtkObject *  o)
void vtkRawImageFileSeriesReader::PrintSelf ( ostream &  os,
◆ SetFileDimensionality()
virtual void vtkRawImageFileSeriesReader::SetFileDimensionality ( int  )
This defaults to two.
◆ GetFileDimensionality()
virtual int vtkRawImageFileSeriesReader::GetFileDimensionality ( )
◆ SetDataExtent() [1/2]
virtual void vtkRawImageFileSeriesReader::SetDataExtent ( int  ,
int  ,
int  ,
int  ,
int  ,
int
◆ SetDataExtent() [2/2]
virtual void vtkRawImageFileSeriesReader::SetDataExtent ( int  [6])
◆ GetDataExtent() [1/3]
virtual int* vtkRawImageFileSeriesReader::GetDataExtent ( )
◆ GetDataExtent() [2/3]
virtual void vtkRawImageFileSeriesReader::GetDataExtent ( int &  ,
int &  ,
int &  ,
int &  ,
int &  ,
int &
◆ GetDataExtent() [3/3]
virtual void vtkRawImageFileSeriesReader::GetDataExtent ( int  [6])
◆ UpdateReaderDataExtent()
void vtkRawImageFileSeriesReader::UpdateReaderDataExtent ( )
overrideprotectedvirtual
the raw format). Here we pass in values set by the user.
◆ DataExtent
int vtkRawImageFileSeriesReader::DataExtent[6]
If we are reading a 2D raw image as a stack we fill in the 3rd extent automatically for the reader actually reading the files and ignore the 3rd extent here. We do need to keep that extent in case the user switches between reading as a stack or reading as a time series.
Definition at line 62 of file vtkRawImageFileSeriesReader.h.
◆ FileDimensionality
int vtkRawImageFileSeriesReader::FileDimensionality
Default is 2.
Definition at line 70 of file vtkRawImageFileSeriesReader.h.
