Public Member Functions | List of all members
pqPauseLiveSourcePropertyWidget Class Reference
widget to pause current live source More...
#include <pqPauseLiveSourcePropertyWidget.h>
Inheritance diagram for pqPauseLiveSourcePropertyWidget:
Collaboration diagram for pqPauseLiveSourcePropertyWidget:
 pqPauseLiveSourcePropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqPauseLiveSourcePropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqPauseLiveSourcePropertyWidget can be added to a property on any source that is a "live source" i.e. has the <LiveSource> XML hint. This will add a button to the UI that allows the user to pause the current live source.
If the <LiveSource> hint has emulated_time attribute, this widget also add controls for emulated time, such as play/pause timer and reset timer to start. Note that these controls will impact all emulated time algorithms.
Definition at line 24 of file pqPauseLiveSourcePropertyWidget.h.
◆ pqPauseLiveSourcePropertyWidget()
pqPauseLiveSourcePropertyWidget::pqPauseLiveSourcePropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqPauseLiveSourcePropertyWidget()
pqPauseLiveSourcePropertyWidget::~pqPauseLiveSourcePropertyWidget ( )
override
