pqInteractivePropertyWidget is an abstract pqPropertyWidget subclass designed to serve as the superclass for all pqPropertyWidget types that have interactive widget (also called 3D Widgets) associated with them. More...
#include <pqInteractivePropertyWidget.h>
| pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqInteractivePropertyWidget () override | |
| vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| Returns the proxy for the 3D interactive widget. More... | |
Public Member Functions inherited from pqInteractivePropertyWidgetAbstract | |
| pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqInteractivePropertyWidgetAbstract () override | |
| void | reset () override |
| Overridden to call this->render() to ensure that the widget is redrawn. More... | |
| void | setView (pqView *view) override |
| Overridden to show the widget proxy in the new view. More... | |
| bool | isWidgetVisible () const |
| Returns the interactive widget's visibility. More... | |
| vtkSMProxy * | dataSource () const |
| Returns the data source. More... | |
| vtkBoundingBox | dataBounds (bool visibleOnly=false) const |
| Returns bounds from the dataSource, if possible. More... | |
| vtkSMPropertyGroup * | propertyGroup () const |
| Returns the vtkSMPropertyGroup pass to the constructor. More... | |
| void | hideEvent (QHideEvent *) override |
| Overriden in order to hide the VTK widget. More... | |
| void | showEvent (QShowEvent *) override |
| Overriden in order to show the VTK widget. More... | |
| void | select () override |
| In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More... | |
| void | deselect () override |
| void | selectPort (int portIndex) final |
| virtual void | apply () |
| pqView * | view () const |
| bool | showLabel () const |
| vtkSMNewWidgetRepresentationProxyAbstract * | internalWidgetProxy () final |
| Get the internal instance of the widget proxy. More... | |
Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract | |
| void | setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy) |
| Setup all the links and events for the given widget and SM property group. More... | |
| void | setupUserObserver (vtkSMProxy *smproxy) |
Public Slots inherited from pqInteractivePropertyWidgetAbstract | |
| virtual void | setWidgetVisible (bool val) |
| Toggle the interactive widget's visibility. More... | |
| void | setDataSource (vtkSMProxy *dataSource) |
| DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More... | |
Signals inherited from pqInteractivePropertyWidgetAbstract | |
| void | widgetVisibilityToggled (bool) |
| Fired whenever setWidgetVisible() changes the widget's visibility. More... | |
| void | widgetVisibilityUpdated (bool) |
| Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More... | |
| void | startInteraction () |
| Fired by the underlying interactive widget representation proxy, for each respective events. More... | |
| void | interaction () |
| void | endInteraction () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Protected Slots inherited from pqInteractivePropertyWidgetAbstract | |
| virtual void | placeWidget ()=0 |
| Places the interactive widget using current data source information. More... | |
| void | render () |
| Safe call render on the view. More... | |
| virtual void | updateWidgetVisibility () |
| This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More... | |
Protected Attributes inherited from pqInteractivePropertyWidgetAbstract | |
| bool | VisibleState = true |
| bool | WidgetVisibility = false |
| int | LinkedPortIndex = -1 |
Properties inherited from pqInteractivePropertyWidgetAbstract | |
| pqSMProxy | dataSource |
pqInteractivePropertyWidget is intended to provide a Qt widget (along with an interactive widget in the active view) for controlling properties on the proxy identified by a vtkSMPropertyGroup passed to the constructor. Subclasses are free to determine which interactive widget to create and how to setup the UI for it.
Definition at line 29 of file pqInteractivePropertyWidget.h.
| pqInteractivePropertyWidget::pqInteractivePropertyWidget | ( | const char * | widget_smgroup, |
| const char * | widget_smname, | ||
| vtkSMProxy * | proxy, | ||
| vtkSMPropertyGroup * | smgroup, | ||
Definition at line 43 of file pqInteractivePropertyWidget.h.
inlinefinalprotectedvirtual |
Implements pqInteractivePropertyWidgetAbstract.
Definition at line 49 of file pqInteractivePropertyWidget.h.
