| | pqEqualizerPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| | ~pqEqualizerPropertyWidget () override |
| | pqInteractiveProperty2DWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| | ~pqInteractiveProperty2DWidget () override |
| vtkSMNew2DWidgetRepresentationProxy * | widgetProxy () const |
| | Returns the proxy for the interactive 2D widget. More...
| | pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| | ~pqInteractivePropertyWidgetAbstract () override |
| void | reset () override |
| | Overridden to call this->render() to ensure that the widget is redrawn. More...
| void | setView (pqView *view) override |
| | Overridden to show the widget proxy in the new view. More...
| bool | isWidgetVisible () const |
| | Returns the interactive widget's visibility. More...
| vtkSMProxy * | dataSource () const |
| | Returns the data source. More...
| vtkBoundingBox | dataBounds (bool visibleOnly=false) const |
| | Returns bounds from the dataSource, if possible. More...
| vtkSMPropertyGroup * | propertyGroup () const |
| | Returns the vtkSMPropertyGroup pass to the constructor. More...
| void | hideEvent (QHideEvent *) override |
| | Overriden in order to hide the VTK widget. More...
| void | showEvent (QShowEvent *) override |
| | Overriden in order to show the VTK widget. More...
| void | select () override |
| | In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
| void | deselect () override |
| void | selectPort (int portIndex) final |
| | pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) |
| | ~pqPropertyWidget () override |
| virtual void | apply () |
| pqView * | view () const |
| | Forward calls to vtkSMProperty. More...
| | Determines if the PropertyWidget must be constructed using a single row. More...
| bool | showLabel () const |
| | Provides access to the decorators for this widget. More...
| | These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More...
| virtual void | setWidgetVisible (bool val) |
| | Toggle the interactive widget's visibility. More...
| void | setDataSource (vtkSMProxy *dataSource) |
| | DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
| void | widgetVisibilityToggled (bool) |
| | Fired whenever setWidgetVisible() changes the widget's visibility. More...
| void | widgetVisibilityUpdated (bool) |
| | Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
| void | startInteraction () |
| | Fired by the underlying interactive widget representation proxy, for each respective events. More...
| void | interaction () |
| void | endInteraction () |
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
| | Parse a XML element as a list of label to use for this widget. More...
| vtkSMNewWidgetRepresentationProxyAbstract * | internalWidgetProxy () final |
| | Get the internal instance of the widget proxy. More...
| void | setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy) |
| | Setup all the links and events for the given widget and SM property group. More...
| void | setupUserObserver (vtkSMProxy *smproxy) |
| bool | VisibleState = true |
| bool | WidgetVisibility = false |
| int | LinkedPortIndex = -1 |
| pqSMProxy | dataSource |
The pqEqualizerPropertyWidget class.
To use this widget for a property group (vtkSMPropertyGroup), use "EqualizerPropertyWidget" as the "panel_widget" in the XML configuration for the proxy. It controls the "EqualizerPoints" function of the given property group. It is also possible to give an optional function "SamplingFrequency" that will be used for initializing the placement of the widget.
Definition at line 21 of file pqEqualizerPropertyWidget.h.
