Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqDataRepresentation Class Reference
pqDataRepresentation is the superclass for a display for a pqPipelineSource i.e. More...
#include <pqDataRepresentation.h>
Inheritance diagram for pqDataRepresentation:
Collaboration diagram for pqDataRepresentation:
Public Slots
virtual void updateLookupTable ()
 Slot to update the lookup table if the application setting to reset it on visibility changes is on. More...
virtual void resetAllTransferFunctionRangesUsingCurrentData ()
void onVisibilityChanged () override
 Overridden to set the VisibilityChangedSinceLastUpdate flag. More...
- Public Slots inherited from pqRepresentation
void renderView (bool force)
 Renders the view to which this representation has been added if any. More...
void renderViewEventually ()
 Simply calls renderView(false);. More...
Signals
void dataUpdated ()
 Fired when the representation proxy fires the vtkCommand::UpdateDataEvent. More...
void attrArrayNameModified ()
 Signal fired to indicate that the rendering attribute arrays properties (Normals, TCoords, Tangents) were modified. More...
void representationTypeModified ()
 Signal fired to indicate the representation type has changed. More...
void useSeparateOpacityArrayModified ()
 Signal fired to indicate the use separate opacity array property has changed. More...
void useTransfer2DModified ()
 Signal fired to indicate the use 2D transfer function property has changed. More...
void colorTransferFunctionModified ()
 Fired to indicate that the "LookupTable" property (if any) on the representation was modified. More...
void blockColorTransferFunctionModified ()
void colorArrayNameModified ()
 Signal fired to indicate that the "ColorArrayName" property (if any) on the representation was modified. More...
void blockColorArrayNameModified ()
- Signals inherited from pqRepresentation
void visibilityChanged (bool visible)
 Fired when the visibility property of the underlying display changes. More...
void updated ()
 Fired whenever Update() is called on the underlying display proxy. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
 pqDataRepresentation (const QString &group, const QString &name, vtkSMProxy *display, pqServer *server, QObject *parent=nullptr)
 ~pqDataRepresentation () override
pqPipelineSource * getInput () const
 Get the source/filter of which this is a display. More...
pqOutputPort * getOutputPortFromInput () const
 Returns the input pqPipelineSource's output port to which this representation is connected. More...
vtkPVDataInformation * getInputDataInformation () const
 Returns the data information for the data coming into the representation as input. More...
vtkPVTemporalDataInformation * getInputTemporalDataInformation () const
 Returns the temporal data information for the input. More...
vtkPVDataInformation * getInputRankDataInformation (int rank) const
 Returns rank-specific data information from input. More...
vtkPVDataInformation * getRepresentedDataInformation (bool update=true) const
 Returns the represented data information. More...
bool getDataBounds (double bounds[6])
 Get the data bounds for the input of this display. More...
virtual pqScalarsToColors * getLookupTable (int selectedPropertiesType=0) const
 Returns the pqScalarsToColors object for the lookup table proxy if any. More...
unsigned long getFullResMemorySize ()
 Returns the data size for the full-res data. More...
pqDataRepresentation * getRepresentationForUpstreamSource () const
 This is convenience method to return first representation for the upstream stream filter/source in the same view as this representation. More...
virtual std::vector< vtkSMProxy * > getLookupTableProxies (int selectedPropertiesType=0) const
 Returns the lookuptable proxy, if any. More...
virtual vtkSMProxy * getLookupTableProxy (int selectedPropertiesType=0) const
- Public Member Functions inherited from pqRepresentation
 pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=nullptr)
 ~pqRepresentation () override
virtual bool isVisible () const
 Returns if the status of the visbility property of this display. More...
virtual void setVisible (bool visible)
 Set the visibility. More...
pqView * getView () const
 Returns the view to which this representation has been added, if any. More...
vtkSMViewProxy * getViewProxy () const
 Returns the view proxy to which this representation has been added, if any. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServer * getServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxy * getProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElement * getHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * proxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
Protected Slots
virtual void onInputChanged ()
 called when input property on display changes. More...
- Protected Slots inherited from pqRepresentation
virtual void onVisibilityChanged ()
 called when the display visibility property changes. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
void initialize () override
 Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
- Protected Member Functions inherited from pqRepresentation
 Called by pqView when this representation gets added to / removed from the view. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnect * getConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Static Public Member Functions inherited from pqProxy
static pqProxy * findProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
the input for this display proxy is a pqPiplineSource. This class manages the linking between the pqPiplineSource and pqDataRepresentation.
Definition at line 24 of file pqDataRepresentation.h.
◆ pqDataRepresentation()
pqDataRepresentation::pqDataRepresentation ( const QString &  group,
const QString &  name,
vtkSMProxy *  display,
pqServer *  server,
QObject *  parent = nullptr
◆ ~pqDataRepresentation()
pqDataRepresentation::~pqDataRepresentation ( )
override
◆ getInput()
pqPipelineSource* pqDataRepresentation::getInput ( ) const
◆ getOutputPortFromInput()
pqOutputPort* pqDataRepresentation::getOutputPortFromInput ( ) const
◆ getInputDataInformation()
vtkPVDataInformation* pqDataRepresentation::getInputDataInformation ( ) const
◆ getInputTemporalDataInformation()
vtkPVTemporalDataInformation* pqDataRepresentation::getInputTemporalDataInformation ( ) const
This can be a very slow process. Use with extreme caution!!!
◆ getInputRankDataInformation()
vtkPVDataInformation* pqDataRepresentation::getInputRankDataInformation ( int  rank) const
◆ getRepresentedDataInformation()
vtkPVDataInformation* pqDataRepresentation::getRepresentedDataInformation ( bool  update = true) const
Depending on the representation this may differ from the input data information eg. if the representation shows an outline of the data, the this method will return the information about the polydata forming the outline not the input dataset.
◆ getDataBounds()
bool pqDataRepresentation::getDataBounds ( double  bounds[6])
Returns if the operation was successful.
◆ getLookupTableProxies()
virtual std::vector<vtkSMProxy*> pqDataRepresentation::getLookupTableProxies ( int  selectedPropertiesType = 0) const
Most consumer displays take a lookup table. This method provides access to the Lookup table, if one exists.
Note
the singular form of this method returns the first lookup table proxy
◆ getLookupTableProxy()
virtual vtkSMProxy* pqDataRepresentation::getLookupTableProxy ( int  selectedPropertiesType = 0) const
Note
◆ getLookupTable()
virtual pqScalarsToColors* pqDataRepresentation::getLookupTable ( int  selectedPropertiesType = 0) const
Note
◆ getFullResMemorySize()
unsigned long pqDataRepresentation::getFullResMemorySize ( )
This may trigger a pipeline update to obtain correct data sizes.
◆ getRepresentationForUpstreamSource()
pqDataRepresentation* pqDataRepresentation::getRepresentationForUpstreamSource ( ) const
This is only applicable, if this representation is connected to a data-filter which has a valid input.
◆ dataUpdated
void pqDataRepresentation::dataUpdated ( )
signal
◆ colorTransferFunctionModified
void pqDataRepresentation::colorTransferFunctionModified ( )
signal
◆ blockColorTransferFunctionModified
void pqDataRepresentation::blockColorTransferFunctionModified ( )
signal
◆ colorArrayNameModified
void pqDataRepresentation::colorArrayNameModified ( )
signal
This property controls the scalar coloring settings on the representation.
◆ blockColorArrayNameModified
void pqDataRepresentation::blockColorArrayNameModified ( )
signal
◆ attrArrayNameModified
void pqDataRepresentation::attrArrayNameModified ( )
signal
These properties control the shading and texture mapping.
◆ representationTypeModified
void pqDataRepresentation::representationTypeModified ( )
signal
("Volume", "Surface", ..)
◆ useSeparateOpacityArrayModified
void pqDataRepresentation::useSeparateOpacityArrayModified ( )
signal
◆ useTransfer2DModified
void pqDataRepresentation::useTransfer2DModified ( )
signal
◆ updateLookupTable
virtual void pqDataRepresentation::updateLookupTable ( )
virtualslot
◆ resetAllTransferFunctionRangesUsingCurrentData
virtual void pqDataRepresentation::resetAllTransferFunctionRangesUsingCurrentData ( )
virtualslot
◆ onVisibilityChanged
void pqDataRepresentation::onVisibilityChanged ( )
overrideslot
◆ onInputChanged
virtual void pqDataRepresentation::onInputChanged ( )
protectedvirtualslot
We must detect if (and when) the display is connected to a new proxy.
◆ initialize()
void pqDataRepresentation::initialize ( )
inlineoverrideprotectedvirtual
This needs to be done only once, after the object has been created.
Reimplemented from pqProxy.
Definition at line 187 of file pqDataRepresentation.h.
