vtkSMViewLayoutProxy is used by ParaView to layout multiple views in a 2D KD-Tree layout. More...
#include <vtkSMViewLayoutProxy.h>
| enum | Direction { NONE, VERTICAL, HORIZONTAL } |
| typedef vtkSMProxy | Superclass |
Public Types inherited from vtkSMProxy | |
| enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
| enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
| Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
| int | Split (int location, int direction, double fraction) |
Split a frame at the given location. More... | |
| int | SplitVertical (int location, double fraction) |
| int | SplitHorizontal (int location, double fraction) |
| bool | AssignView (int location, vtkSMViewProxy *view) |
| Assign a view at a particular location. More... | |
| int | AssignViewToAnyCell (vtkSMViewProxy *view, int location_hint) |
| Similar to AssignView() except that is location specified is not available, then this method treats the location merely as a hint and tries to find a suitable place. More... | |
| bool | Collapse (int location) |
| Collapses a cell. More... | |
| bool | SwapCells (int location1, int location2) |
| Swaps the cells at the two locations. More... | |
| bool | SetSplitFraction (int location, double fraction) |
| Update the split fraction for a split cell. More... | |
| bool | EqualizeViews () |
| Equalize views so they appear evenly sized. More... | |
| bool | EqualizeViews (Direction direction) |
| Equalize views so they appear evenly sized along direction. More... | |
| bool | MaximizeCell (int location) |
| One can maximize a particular (non-split) cell. More... | |
| void | RestoreMaximizedState () |
| Restores the maximized state. More... | |
| bool | IsSplitCell (int location) |
| Returns true if the cell identified by the location is a split cell. More... | |
| Direction | GetSplitDirection (int location) |
| Returns the split direction for a split cell at the given location. More... | |
| double | GetSplitFraction (int location) |
| Returns the split-fraction for a split cell at the given location. More... | |
| vtkSMViewProxy * | GetView (int location) |
| Returns the view, if any, assigned to the given cell location. More... | |
| int | GetViewLocation (vtkSMViewProxy *) |
| Returns the location for the view, of any. More... | |
| void | UpdateViewPositions () |
| Updates positions for all views using the layout and current sizes. More... | |
| void | ShowViewsOnTileDisplay () |
| When in tile-display configuration, only 1 view-layout is shown on the tile-display (for obvious reasons). More... | |
| vtkPVXMLElement * | SaveXMLState (vtkPVXMLElement *root) override |
| Overridden to save custom XML state. More... | |
| vtkPVXMLElement * | SaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override |
| The iterator is use to filter the property available on the given proxy. More... | |
| int | LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override |
| Overridden to load custom XML state. More... | |
| void | Reset () |
| Resets the layout. More... | |
| void | GetLayoutExtent (int extent[4]) |
| Returns the extents for all views in the layout. More... | |
| vtkVector2i | GetSize () |
| Returns the current size. More... | |
| std::vector< vtkSMViewProxy * > | GetViews () |
| Returns a vector of the view proxies added to his layout. More... | |
| int | RemoveView (vtkSMViewProxy *view) |
| Removes a view. More... | |
| bool | RemoveView (int index) |
| virtual int | GetMaximizedCell () |
| Returns the maximized cell, if any. More... | |
| bool | ContainsView (vtkSMViewProxy *view) |
| Returns if a view is contained in this layout. More... | |
| bool | ContainsView (vtkSMProxy *view) |
| vtkImageData * | CaptureWindow (int magnification) |
| Captures an image from the layout (including all the views in the layout. More... | |
| vtkImageData * | CaptureWindow (int magnificationX, int magnificationY) |
| void | SetSize (const int size[2]) |
| Update the size for all the views in the layout assuming the new size provided for the whole layout. More... | |
| void | SetSize (int width, int height) |
| void | SaveAsPNG (int rank, const char *fname) |
| This is only meant for testing and debugging purposes. More... | |
Public Member Functions inherited from vtkSMProxy | |
| Retrieve an annotation with a given key. More... | |
| Remove a given annotation based on its key to the proxy. More... | |
| Remove all proxy annotations. More... | |
| Return true if a given annotation exists. More... | |
| Return the number of available annotations. More... | |
| Return the nth key of the available annotations. More... | |
| Return the property with the given name. More... | |
| Return a property of the given name from self or one of the sub-proxies. More... | |
| Given a property pointer, returns the name that was used to add it to the proxy. More... | |
| Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
| Recreate the VTK object for this proxy. More... | |
| Convenience method equivalent to UpdateProperty(name, 1). More... | |
| Returns a new (initialized) iterator of the properties. More... | |
| Returns the number of consumers. More... | |
| Returns the consumer of given index. More... | |
| Returns the corresponding property of the consumer of given index. More... | |
| Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
| Returns a proxy this proxy depends on, given index. More... | |
| Returns the property holding a producer proxy given an index. More... | |
| Updates all property information by calling UpdateInformation() and populating the values. More... | |
| Similar to UpdatePropertyInformation() but updates only the given property. More... | |
| Marks all properties as modified. More... | |
| Use this method to set all properties on this proxy to their default values. More... | |
| Use this method to set all properties on this proxy to their default domains. More... | |
| Use this method to set all properties on this proxy to their default domain or values. More... | |
| Calls MarkDirty() and invokes ModifiedEvent. More... | |
| bool | IsDeprecated () |
| Returns true if the proxy has a deprecation tag. More... | |
| Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
| Dirty means this algorithm will execute during next update. More... | |
| Returns the client side object associated with the VTKObjectID (if any). More... | |
| This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
| bool | GetIsSubProxy () |
| A proxy instance can be a sub-proxy for some other proxy. More... | |
| If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
| Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
| This method return the full object state that can be used to create that object from scratch. More... | |
| Returns the number of property groups that the proxy contains. More... | |
| Return the property names that have values different from the otherProxy argument. More... | |
| Update the value of one property (pushed to the server) if it is modified. More... | |
| Returns the type of object managed by the proxy. More... | |
| the type of object created by the proxy. More... | |
| Copies values of all the properties and sub-proxies from src. More... | |
| Returns if the VTK objects for this proxy have been created. More... | |
| Gathers information about this proxy. More... | |
| Log name is a name for this proxy that will be used when logging status messages. More... | |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| static vtkSMViewLayoutProxy * | New () |
| static vtkSMViewLayoutProxy * | SafeDownCast (vtkObject *o) |
| static int | GetFirstChild (int location) |
| Returns the index for the first child of the given location. More... | |
| static int | GetSecondChild (int location) |
| Returns the index for the second child of the given location. More... | |
| static int | GetParent (int location) |
| Returns the parent index. More... | |
| static vtkSMViewLayoutProxy * | FindLayout (vtkSMViewProxy *, const char *reggroup="layouts") |
| Helper method to locate a layout, if any that contains the specified view proxy. More... | |
Static Public Member Functions inherited from vtkSMProxy | |
| static vtkSMProxy * | New () |
| static vtkSMProxy * | SafeDownCast (vtkObject *o) |
| vtkSMViewLayoutProxy () | |
| ~vtkSMViewLayoutProxy () override | |
| void | LoadState (const vtkSMMessage *message, vtkSMProxyLocator *locator) override |
| Called to load state from protobuf message. More... | |
| virtual void | UpdateState () |
| Although this class is a proxy, it's not really a proxy in the traditional sense. More... | |
| int | GetEmptyCell (int root) |
| Starting with the cell-index, tries to find an empty cell in the sub-tree. More... | |
| int | GetSplittableCell (int root, Direction &suggested_direction) |
| Starting with the root, finds a splittable cell. More... | |
| int | ComputeSteadySplitFraction (int location, Direction direction) |
| Recompute SplitFraction recursively so cells appears evenly sized along direction. More... | |
Protected Member Functions inherited from vtkSMProxy | |
| vtkSMProxy () | |
| ~vtkSMProxy () override | |
| Invoke that takes a vtkClientServerStream as the argument. More... | |
| Add a property with the given key (name). More... | |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
| Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
| Cleanup code. More... | |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
| Add a sub-proxy. More... | |
| Remove a sub-proxy. More... | |
| Returns a sub-proxy. More... | |
| Returns the name used to store sub-proxy. More... | |
| Returns the number of sub-proxies. More... | |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
| Remove the property,proxy pair from the list of consumers. More... | |
| Remove all consumers. More... | |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
| Remove the property,proxy pair from the list of producers. More... | |
| This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
| If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
| This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
| Parses the XML to create a new property group. More... | |
| Adds a property groups. More... | |
| Expose a subproxy property from the base proxy. More... | |
| Handle events fired by subproxies. More... | |
| Called to update the property information on the property. More... | |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
Internal method used by SetLogName More... | |
| Indicates if any properties are modified. More... | |
| Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
| vtkSMProxy (const vtkSMProxy &)=delete | |
| Get the last result. More... | |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
| Read attributes from an XML element. More... | |
| SIClassName identifies the classname for the helper on the server side. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
vtkSMViewLayoutProxy is used by ParaView to layout multiple views in a 2D KD-Tree layout. This is proxy, hence can be registered with the proxy manager just like other regular proxies; participates in xml state saving/restoring, undo-redo, etc. Users can affects the GUI layout using this proxy instance from Python as well.
Every time the vtkSMViewLayoutProxy changes so that it would affect the UI, this class fires vtkCommand::ConfigureEvent.
View proxies that are to laid out in an layout should be "assigned" to a particular cell in a vtkSMViewLayoutProxy instance. vtkSMViewLayoutProxy takes over the responsibility of updating the view's Position property correctly.
Although, currently, there are no safe guards against assigning a view to more than one layout, this is strictly prohibited and can cause unexpected problems at run-time.
Definition at line 39 of file vtkSMViewLayoutProxy.h.
Definition at line 43 of file vtkSMViewLayoutProxy.h.
| Enumerator | |
| NONE | |
| VERTICAL | |
| HORIZONTAL | |
Definition at line 46 of file vtkSMViewLayoutProxy.h.
Location must point to an existing cell that's not split. If the location does not exist or is already split, then returns -1, to indicate failure. Otherwise returns the index of the left (or top) child node. The index for the sibling can be computed as (ret_val + 1). fraction indicates a value in the range [0.0, 1.0] at which the cell is split. If a View is set at the given location, it will be moved to the left (or top) child after the split.
Definition at line 63 of file vtkSMViewLayoutProxy.h.
Definition at line 67 of file vtkSMViewLayoutProxy.h.
| bool vtkSMViewLayoutProxy::AssignView | ( | int | location, |
| vtkSMViewProxy * | view | ||
Note that the view's position may be changed by Split() calls. Returns true on success.
| int vtkSMViewLayoutProxy::AssignViewToAnyCell | ( | vtkSMViewProxy * | view, |
| int | location_hint | ||
First, if any empty cell is available, then that is used. Second, if no empty cell is available and location is a valid cell, then we either split the cell or traverse down the sub-tree from the cell and split a cell to make room for the view. Thus, this method will always assign the view to a frame. Returns the assigned location.
| int vtkSMViewLayoutProxy::RemoveView | ( | vtkSMViewProxy * | view | ) |
Removes a view.
Returns the location of the cell emptied by the view, if any, otherwise -1.
| bool vtkSMViewLayoutProxy::RemoveView | ( | int | index | ) |
Removes a view.
| bool vtkSMViewLayoutProxy::Collapse | ( | int | location | ) |
Collapses a cell.
Only leaf cells without any assigned views can be collapsed. If the cell has a sibling, then that sibling is assigned to the parent node and the sibling cell is destroyed as well. Returns true on success, else false.
Both locations must be leaf locations i.e. cannot be split-cells.
If IsSplitCell(location) returns false, this method does not update the fraction.
| bool vtkSMViewLayoutProxy::EqualizeViews | ( | ) |
| bool vtkSMViewLayoutProxy::EqualizeViews | ( | Direction | direction | ) |
| bool vtkSMViewLayoutProxy::MaximizeCell | ( | int | location | ) |
Note the maximized state is restored as soon as the layout is changed or when RestoreMaximizedState() is called. Returns false if the cell at the location cannot be maximized since it's a split cell or invalid cell, true otherwise.
| void vtkSMViewLayoutProxy::RestoreMaximizedState | ( | ) |
Returns -1 if no cell is currently maximized.
| bool vtkSMViewLayoutProxy::IsSplitCell | ( | int | location | ) |
This does not do any validity checks for the location, nor that of the child.
Definition at line 168 of file vtkSMViewLayoutProxy.h.
Definition at line 174 of file vtkSMViewLayoutProxy.h.
Definition at line 179 of file vtkSMViewLayoutProxy.h.
| vtkSMViewProxy* vtkSMViewLayoutProxy::GetView | ( | int | location | ) |
| int vtkSMViewLayoutProxy::GetViewLocation | ( | vtkSMViewProxy * | ) |
Returns -1 if the view is not found.
Definition at line 196 of file vtkSMViewLayoutProxy.h.
| bool vtkSMViewLayoutProxy::ContainsView | ( | vtkSMProxy * | view | ) |
| void vtkSMViewLayoutProxy::UpdateViewPositions | ( | ) |
This method is called automatically when the layout changes or the "ViewSize" property on the assigned views changes.
| void vtkSMViewLayoutProxy::ShowViewsOnTileDisplay | ( | ) |
To show any particular layout on the tile display, simply call this method.
Definition at line 218 of file vtkSMViewLayoutProxy.h.
| vtkImageData* vtkSMViewLayoutProxy::CaptureWindow | ( | int | magnificationX, |
| int | magnificationY | ||
inlineoverridevirtual |
Definition at line 228 of file vtkSMViewLayoutProxy.h.
| void vtkSMViewLayoutProxy::Reset | ( | ) |
Resets the layout.
| void vtkSMViewLayoutProxy::GetLayoutExtent | ( | int | extent[4] | ) |
This resizes and repositions each view based the recursive split ratios for all the cells in the layout.
Definition at line 256 of file vtkSMViewLayoutProxy.h.
Definition at line 266 of file vtkSMViewLayoutProxy.h.
| std::vector<vtkSMViewProxy*> vtkSMViewLayoutProxy::GetViews | ( | ) |
This allows the application to save the image rendered on the server side in certain configurations (tile display and cave) to a png file for regression testing.
overrideprotectedvirtual |
protectedvirtual |
So instead of using UpdateVTKObjects() to push state changes to the server (or undo-redo stack), this new method is provided.
Returns -1 if none found. May return root, if root is indeed an empty cell. Note this assumes that root is valid.
Assumes root is valid.
return the weight of the cell at location, i.e. the number of impacted children.
Definition at line 328 of file vtkSMViewLayoutProxy.h.
