a multiplexer proxy More...
#include <vtkSMMultiplexerSourceProxy.h>
| typedef vtkSMSourceProxy | Superclass |
Public Types inherited from vtkSMSourceProxy | |
| enum | ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH } |
| typedef vtkSMProxy | Superclass |
Public Types inherited from vtkSMProxy | |
| enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
| enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
| Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
| vtkPVXMLElement * | SaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override |
| The iterator is use to filter the property available on the given proxy. More... | |
| int | LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override |
| Loads the proxy state from the XML element. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
Public Member Functions inherited from vtkSMSourceProxy | |
| void | UpdatePipelineInformation () override |
| Calls UpdateInformation() on all sources. More... | |
| virtual void | UpdatePipeline () |
| Calls Update() on all sources. More... | |
| virtual void | UpdatePipeline (double time) |
| Calls Update() on all sources with the given time request. More... | |
| virtual unsigned int | GetNumberOfOutputPorts () |
| Return the number of output ports. More... | |
| virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| Return an output port. More... | |
| virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| Return an output port, given the name for the port. More... | |
| virtual unsigned int | GetOutputPortIndex (const char *portname) |
| Returns the port index, given the name of an output port. More... | |
| virtual const char * | GetOutputPortName (unsigned int index) |
| Returns the output port name given its index. More... | |
| virtual void | CreateOutputPorts () |
| Creates the output port proxies for this filter. More... | |
| vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex) |
A GetSubsetDataInformation overload that uses composite index. More... | |
| virtual void | CreateSelectionProxies () |
| Creates extract selection proxies for each output port if not already created. More... | |
| void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| Set/Get the selection input. More... | |
| void | CleanSelectionInputs (unsigned int portIndex) |
| Clean all selection inputs for the given port. More... | |
| vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| Returns the source proxy which provides the selected data from the given output port. More... | |
| unsigned int | GetNumberOfAlgorithmOutputPorts () |
| Returns the number of output ports provided by the algorithm. More... | |
| virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| Returns the number of non-optional input ports required by the algorithm. More... | |
| vtkTypeUInt32 | GetGlobalID () override |
| Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More... | |
| void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| Marks the selection proxies dirty as well as chain to superclass. More... | |
| virtual int | GetOutputPortsCreated () |
| Returns if the output port proxies have been created. More... | |
| vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| It is possible to provide some documentation for each output port in the configuration xml. More... | |
| vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
| vtkPVDataInformation * | GetDataInformation () |
| DataInformation is used by the source proxy to obtain information on the output(s) from the server. More... | |
| vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
| vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr) |
For composite datasets, GetDataInformation returns summary data information for all blocks combined. More... | |
| vtkPVDataInformation * | GetRankDataInformation (int rank) |
| Get rank-specific data information. More... | |
| vtkPVDataInformation * | GetRankDataInformation (unsigned int outputIdx, int rank) |
| vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| API to query selection input set using SetSelectionInput. More... | |
| unsigned int | GetSelectionInputPort (unsigned int portIndex) |
| virtual int | GetProcessSupport () |
| This returns information about whether the VTK algorithm supports multiple processes or not. More... | |
| virtual bool | GetMPIRequired () |
| This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More... | |
Public Member Functions inherited from vtkSMProxy | |
| Retrieve an annotation with a given key. More... | |
| Remove a given annotation based on its key to the proxy. More... | |
| Remove all proxy annotations. More... | |
| Return true if a given annotation exists. More... | |
| Return the number of available annotations. More... | |
| Return the nth key of the available annotations. More... | |
| Return the property with the given name. More... | |
| Return a property of the given name from self or one of the sub-proxies. More... | |
| Given a property pointer, returns the name that was used to add it to the proxy. More... | |
| Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
| Recreate the VTK object for this proxy. More... | |
| Convenience method equivalent to UpdateProperty(name, 1). More... | |
| Returns a new (initialized) iterator of the properties. More... | |
| Returns the number of consumers. More... | |
| Returns the consumer of given index. More... | |
| Returns the corresponding property of the consumer of given index. More... | |
| Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
| Returns a proxy this proxy depends on, given index. More... | |
| Returns the property holding a producer proxy given an index. More... | |
| Updates all property information by calling UpdateInformation() and populating the values. More... | |
| Similar to UpdatePropertyInformation() but updates only the given property. More... | |
| Marks all properties as modified. More... | |
| Use this method to set all properties on this proxy to their default values. More... | |
| Use this method to set all properties on this proxy to their default domains. More... | |
| Use this method to set all properties on this proxy to their default domain or values. More... | |
| Calls MarkDirty() and invokes ModifiedEvent. More... | |
| bool | IsDeprecated () |
| Returns true if the proxy has a deprecation tag. More... | |
| Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
| Returns the client side object associated with the VTKObjectID (if any). More... | |
| Saves the state of the proxy. More... | |
| This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
| bool | GetIsSubProxy () |
| A proxy instance can be a sub-proxy for some other proxy. More... | |
| If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
| Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
| This method return the full object state that can be used to create that object from scratch. More... | |
| Returns the number of property groups that the proxy contains. More... | |
| Return the property names that have values different from the otherProxy argument. More... | |
| Update the value of one property (pushed to the server) if it is modified. More... | |
| Returns the type of object managed by the proxy. More... | |
| the type of object created by the proxy. More... | |
| Copies values of all the properties and sub-proxies from src. More... | |
| Returns if the VTK objects for this proxy have been created. More... | |
| Gathers information about this proxy. More... | |
| Log name is a name for this proxy that will be used when logging status messages. More... | |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| static vtkSMMultiplexerSourceProxy * | New () |
| static vtkSMMultiplexerSourceProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMSourceProxy | |
| static vtkSMSourceProxy * | New () |
| static vtkSMSourceProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMProxy | |
| static vtkSMProxy * | New () |
| static vtkSMProxy * | SafeDownCast (vtkObject *o) |
| vtkSMMultiplexerSourceProxy () | |
| ~vtkSMMultiplexerSourceProxy () override | |
| void | CreateVTKObjects () override |
| Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
| int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| int | IsInDomain (vtkSMInputProperty *property) |
| void | Select (vtkSMProxy *) |
Protected Member Functions inherited from vtkSMSourceProxy | |
| vtkSMSourceProxy () | |
| ~vtkSMSourceProxy () override | |
| virtual void | InvalidateDataInformation () |
| Mark the data information as invalid. More... | |
| Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More... | |
| virtual void | SetExecutiveName (const char *) |
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| Read attributes from an XML element. More... | |
| void | PostUpdateData (bool) override |
| Overwritten from superclass to invoke. More... | |
| void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override |
| Overridden to pass the logname to the internal ExtractSelection proxies. More... | |
| void | SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc) |
| Method to set an output port at the given index. More... | |
| void | RemoveAllOutputPorts () |
| void | SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy) |
| void | RemoveAllExtractSelectionProxies () |
Protected Member Functions inherited from vtkSMProxy | |
| vtkSMProxy () | |
| ~vtkSMProxy () override | |
| Invoke that takes a vtkClientServerStream as the argument. More... | |
| Add a property with the given key (name). More... | |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
| Cleanup code. More... | |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
| Add a sub-proxy. More... | |
| Remove a sub-proxy. More... | |
| Returns a sub-proxy. More... | |
| Returns the name used to store sub-proxy. More... | |
| Returns the number of sub-proxies. More... | |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
| Remove the property,proxy pair from the list of consumers. More... | |
| Remove all consumers. More... | |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
| Remove the property,proxy pair from the list of producers. More... | |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
| If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
| Parses the XML to create a new property group. More... | |
| Adds a property groups. More... | |
| Expose a subproxy property from the base proxy. More... | |
| Handle events fired by subproxies. More... | |
| Called to update the property information on the property. More... | |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
| Indicates if any properties are modified. More... | |
| Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
| vtkSMProxy (const vtkSMProxy &)=delete | |
| Get the last result. More... | |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
| SIClassName identifies the classname for the helper on the server side. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Friends | |
| class | vtkSMMultiplexerInputDomain |
a multiplexer proxy
vtkSMMultiplexerSourceProxy is a multiplexer that can pick and act as one of the internal proxies (called multiplexed proxies). Once a choice is made, for all intents and purposes the multiplexer behaves like the chosen proxy.
For original motivation and design, refer to paraview/paraview#19936.
A multiplexer proxy can be defined in the ServerManager XML configuration as follows:
It's similar to other proxy definitions, except a few key differences:
classname attribute is generally not specified. The implementation internally creates a vtkPassThroughFilter.InputProperty must have MultiplexerInputDomain as the domain. This is essential to ensure that IsInDomain checks take into consideration input domains for all available multiplexed proxies.Defining proxies that should be included as the available multiplexed proxies is done by adding the <MultiplexerSourceProxy /> hint as follows:
The proxygroup and proxyname on the MultiplexerSourceProxy hint element refer to the group and name of the multiplexed proxy. If the proxy can be part of multiple multiplexers, then multiple MultiplexerSourceProxy elements can be added to the hints.
When a vtkSMMultiplexerSourceProxy is instantiated, it looks for all available proxy definitions that have a matching MultiplexerSourceProxy hint. The optional LinkProperties nested element defines how the properties on this proxy map to properties on the multiplexer proxy. If not specified, they are matched by name.
In vtkSMMultiplexerSourceProxy::CreateVTKObjects, based on the values set on the multiplexer's properties, one (or more) of the available multiplexed proxies are chosen and rest are discarded. Selecting a proxy implies that it will be added as subproxies, and its properties (those that are not linked with properties on the multiplexer) exposed from the multiplexer so that they are available for users to check and set.
The check to see if one of the available multiplexed proxy can be chosen is as follows: for each property on the multiplexed proxy that is linked with a property on the multiplexer, we copy the current value from the multiplexer property and then check if the value is in domain (vtkSMProperty::IsInDomains); if it succeeds for all linked properties, then that multiplexed property is chosen, else it's not and is discarded.
Current implementation is intended for at most 1 proxy to be chosen. If multiple proxies succeed at this test, current implementation only selects the first one.
While the implementation has some initial plumbing to support multiple multiplexed proxies, currently we only support exactly one. In future, the plan is to add a user-settable property to choose between multiple proxies if multiple of them match.
When multiple proxies are chosen, we need to add a mechanism to share properties with same names between the chosen proxies since we cannot expose a property with same name multiple times.
vtkSMMultiplexerSourceProxy currently suffers from lack of Python support. ParaView's Python infrastructure is not capable of supporting different instances of the same proxy with different set of properties. Consequently, do not use this unless you don't need Python support. See paraview/paraview#20187.
Definition at line 132 of file vtkSMMultiplexerSourceProxy.h.
Definition at line 136 of file vtkSMMultiplexerSourceProxy.h.
Reimplemented from vtkSMSourceProxy.
Returns 0 on failure. locator is used to locate other proxies that may be referred to in the state XML (which happens in case of properties of type vtkSMProxyProperty or subclasses). If locator is nullptr, then such properties are left unchanged.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented from vtkSMRemoteObject.
overrideprotectedvirtual |
friend |
Definition at line 159 of file vtkSMMultiplexerSourceProxy.h.
