list of strings corresponding to the names of the arrays in the required input dataset that can be used as a series in a chart.
| | Update self checking the "unchecked" values of all required properties. More...
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Set the default values for the property. More...
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| | Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| | vtkSMChartSeriesListDomain () |
| | ~vtkSMChartSeriesListDomain () override |
| vtkPVDataInformation * | GetInputInformation () |
| | Returns the datainformation from the current input, if possible. More...
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| virtual void | PopulateArrayComponents (vtkPVArrayInformation *, std::vector< std::string > &) |
Protected Member Functions inherited from vtkSMStringListDomain |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
vtkSMChartSeriesListDomain is designed to be used for the X-axis array name property on chart representations. This is similar to vtkSMArrayListDomain, however, it simplifies the logic that is uses to determine the available arrays and at the same time, uses custom logic to pick the default array for based on priorities for arrays.
Supported Required-Property functions:
Input : (required) refers to a property that provides the data-producer.
FieldDataSelection : (required) refers to a field-selection property used to select the data-association i.e. cell-data, point-data etc.
Supported XML attributes
- hide_partial_arrays : when set to 1, partial arrays will not be shown in the domain (default).
Definition at line 34 of file vtkSMChartSeriesListDomain.h.
