Abstract class for SIProperty that hold an array of values. More...
#include <vtkSIVectorProperty.h>
| virtual bool | GetUseIndex () |
| static vtkSIVectorProperty * | SafeDownCast (vtkObject *o) |
| vtkSIVectorProperty () | |
| ~vtkSIVectorProperty () override | |
| bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
| vtkSIProperty () | |
| virtual bool | Push (vtkSMMessage *, int) |
| virtual bool | Pull (vtkSMMessage *) |
Protected Attributes | |
| char * | SetNumberCommand |
| char * | CleanCommand |
| bool | UseIndex |
| int | NumberOfElementsPerCommand |
| char * | InitialString |
| char * | XMLName |
| char * | Command |
| bool | InformationOnly |
| bool | Repeatable |
| bool | IsInternal |
Define the array management API
Definition at line 16 of file vtkSIVectorProperty.h.
Definition at line 19 of file vtkSIVectorProperty.h.
Reimplemented in vtkSIDoubleVectorProperty, vtkSIIdTypeVectorProperty, vtkSIIntVectorProperty, vtkSIStringVectorProperty, and vtkSIVectorPropertyTemplate< T, force_idtype >.
Reimplemented in vtkSIVectorPropertyTemplate< T, force_idtype >.
If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values.
For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo 1 2 * * Invoke obj SetFoo 3 4 * * Invoke obj SetFoo 5 6 *
If UseIndex and RepeatCommand are true, the property will add an index integer before each command.
For example, if UseIndex and RepeatCommand are true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 5 6 7 8 9 10, the resulting stream will have:
* * Invoke obj SetFoo 0 5 6 * * Invoke obj SetFoo 1 7 8 * * Invoke obj SetFoo 2 9 10 *
Command that can be used to remove all values.
Typically used when RepeatCommand = 1. If set, the clean command is called before the main Command.
If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter.
protectedvirtual |
protectedvirtual |
protectedvirtual |
overrideprotectedvirtual |
Definition at line 78 of file vtkSIVectorProperty.h.
Definition at line 81 of file vtkSIVectorProperty.h.
Definition at line 82 of file vtkSIVectorProperty.h.
Definition at line 83 of file vtkSIVectorProperty.h.
Definition at line 84 of file vtkSIVectorProperty.h.
