Basic ServerImplementation property used to call a method with no argument on a VTK object. More...
#include <vtkSIProperty.h>
| vtkSIProperty () | |
| virtual bool | Push (vtkSMMessage *, int) |
| virtual bool | Pull (vtkSMMessage *) |
| virtual bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) |
Protected Attributes | |
| char * | XMLName |
| char * | Command |
| bool | InformationOnly |
| bool | Repeatable |
| bool | IsInternal |
Friends | |
| class | vtkSIProxy |
If overridden, we naturally allow to call a method either to set or get a set of values.
Definition at line 24 of file vtkSIProperty.h.
| typedef vtkObject vtkSIProperty::Superclass |
Definition at line 28 of file vtkSIProperty.h.
Reimplemented in vtkSIDataArraySelectionProperty, vtkSIDoubleVectorProperty, vtkSIIdTypeVectorProperty, vtkSIIntVectorProperty, vtkSIIndexSelectionProperty, vtkSIProxyProperty, vtkSIXMLAnimationWriterRepresentationProperty, vtkSIArraySelectionProperty, vtkSIInputProperty, vtkSIDataArrayProperty, vtkSIDoubleMapProperty, vtkSIStringVectorProperty, vtkSITimeLabelProperty, vtkSITimeRangeProperty, vtkSITimeStepsProperty, vtkSIVectorProperty, and vtkSIVectorPropertyTemplate< T, force_idtype >.
Reimplemented in vtkSIProxyProperty, vtkSIStringVectorProperty, vtkSITimeLabelProperty, vtkSITimeRangeProperty, vtkSITimeStepsProperty, vtkSIVectorProperty, and vtkSIVectorPropertyTemplate< T, force_idtype >.
The name assigned by the xml parser.
Used to get the property from a proxy.
The command name used to set the value on the server object.
For example: SetThetaResolution
Is InformationOnly is set to true, this property is used to get information from server instead of setting values.
If repeatable, a property can have 1 or more values of the same kind.
This ivar is configured when the xml file is read and is mainly useful for information (for example from python).
This ivar is configured when the xml file is read and is mainly useful to trigger a method call.
Internal properties are not saved in state
Convenience method to obtain a vtkSIObject subclass given its global id.
protectedvirtual |
Reimplemented in vtkSIDataArraySelectionProperty, vtkSIProxyProperty, vtkSIVectorPropertyTemplate< T, force_idtype >, vtkSIInputProperty, vtkSIStringVectorProperty, vtkSIXMLAnimationWriterRepresentationProperty, and vtkSIDoubleMapProperty.
protectedvirtual |
Reimplemented in vtkSIDataArraySelectionProperty, vtkSIVectorPropertyTemplate< T, force_idtype >, vtkSIStringVectorProperty, vtkSIIndexSelectionProperty, vtkSIArraySelectionProperty, vtkSIDataArrayProperty, vtkSITimeLabelProperty, vtkSITimeRangeProperty, and vtkSITimeStepsProperty.
protectedvirtual |
Parse the xml for the property.
Reimplemented in vtkSIDataArraySelectionProperty, vtkSIVectorProperty, vtkSIProxyProperty, vtkSIVectorPropertyTemplate< T, force_idtype >, vtkSIStringVectorProperty, vtkSIInputProperty, and vtkSIDoubleMapProperty.
Interprets the message.
protectedvirtual |
protectedvirtual |
friend |
Definition at line 78 of file vtkSIProperty.h.
Definition at line 110 of file vtkSIProperty.h.
Definition at line 113 of file vtkSIProperty.h.
Definition at line 114 of file vtkSIProperty.h.
Definition at line 115 of file vtkSIProperty.h.
Definition at line 116 of file vtkSIProperty.h.
Definition at line 118 of file vtkSIProperty.h.
