Extract bottom left axis range into a property. More...
#include <pqXYChartViewBoundsPropertyWidget.h>
Signals | |
| void | boundsChanged () |
| Signal fired whenever the bounds are changed. More... | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqXYChartViewBoundsPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqXYChartViewBoundsPropertyWidget () override | |
| QList< QVariant > | bounds () |
| Get/Set the chart bounds. More... | |
| void | setBounds (const QList< QVariant > &bounds) |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Protected Slots | |
| void | resetBounds () |
| Extract bounds from the current pqXYChartView if any. More... | |
| void | onTextChanged () |
| Called when the text is changed in order to update the internally stored bounds. More... | |
| void | updateTextFromBounds () |
| Called when the bounds are changed externally to update the texts. More... | |
| void | showEvent (QShowEvent *event) override |
| Initialize the bounds on the first show. More... | |
| void | connectToView (pqView *view) |
| Called whenever the active view change Keep track of the active view and connect to pqXYChartView axis range property to manage the reset button. More... | |
Properties | |
| QList< QVariant > | bounds |
| template<class T > | |
A property widget that extract bottom and left axis range from a pqXYChartView if it is the current active view into a 4 component double vector property.
A reset button is added in order to actually perform the extraction.
Definition at line 23 of file pqXYChartViewBoundsPropertyWidget.h.
explicit |
| QList<QVariant> pqXYChartViewBoundsPropertyWidget::bounds | ( | ) |
Size should always be 4.
| void pqXYChartViewBoundsPropertyWidget::setBounds | ( | const QList< QVariant > & | bounds | ) |
signal |
protectedslot |
protectedslot |
protectedslot |
overrideprotectedslot |
protectedslot |
readwrite |
Definition at line 26 of file pqXYChartViewBoundsPropertyWidget.h.
