pqViewTypePropertyWidget is a property widget that shows a combo-box with values equal to the currently available types of views. More...
#include <pqViewTypePropertyWidget.h>
Public Slots | |
| void | setValue (const QString &value) |
| set the value for the widget. More... | |
Signals | |
| void | valueChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqViewTypePropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqViewTypePropertyWidget () override | |
| QString | value () const |
| get the current value in the widget More... | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Properties | |
| QString | value |
| template<class T > | |
This could have been implemented as a domain, but I was being lazy :).
Definition at line 18 of file pqViewTypePropertyWidget.h.
| pqViewTypePropertyWidget::pqViewTypePropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
| QString pqViewTypePropertyWidget::value | ( | ) | const |
slot |
signal |
readwrite |
Definition at line 22 of file pqViewTypePropertyWidget.h.
