decorator to show/hide or enable/disable property widget based on the session. More...
#include <pqSessionTypeDecorator.h>
| pqSessionTypeDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent) | |
| ~pqSessionTypeDecorator () override | |
| bool | canShowWidget (bool show_advanced) const override |
| Methods overridden from pqPropertyWidget. More... | |
| bool | enableWidget () const override |
Public Member Functions inherited from pqPropertyWidgetDecorator | |
| pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
| Constructor. More... | |
| ~pqPropertyWidgetDecorator () override | |
| pqPropertyWidget * | parentWidget () const |
| Returns the pqPropertyWidget parent. More... | |
Signals inherited from pqPropertyWidgetDecorator | |
| void | visibilityChanged () |
| This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
| void | enableStateChanged () |
Static Public Member Functions inherited from pqPropertyWidgetDecorator | |
| static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
| Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
Protected Member Functions inherited from pqPropertyWidgetDecorator | |
| vtkPVXMLElement * | xml () const |
pqSessionTypeDecorator is a pqPropertyWidgetDecorator subclass that can be used to show/hide or enable/disable a pqPropertyWidget based on the current session.
The XML config for this decorate takes two attributes 'requires' and 'mode'. 'mode' can have values 'visibility' or 'enabled_state' which dictates whether the decorator shows/hides or enables/disables the widget respectively.
'requires' can have values 'remote', 'parallel', 'parallel_data_server', or 'parallel_render_server' indicating if the session must be remote, or parallel with either data server or render server having more than 1 rank, or parallel data-server, or parallel render-server respectively.
Definition at line 29 of file pqSessionTypeDecorator.h.
| pqSessionTypeDecorator::pqSessionTypeDecorator | ( | vtkPVXMLElement * | config, |
| pqPropertyWidget * | parent | ||
Reimplemented from pqPropertyWidgetDecorator.
