property-widget for creating selection queries. More...
#include <pqSelectionQueryPropertyWidget.h>
Signals | |
| void | queryChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqSelectionQueryPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqSelectionQueryPropertyWidget () override | |
| void | setQuery (const QString &) |
| Get/Set the query string. More... | |
| const QString & | query () const |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Properties | |
| QString | query |
Friends | |
| class | pqInternals |
| class | pqValueWidget |
| class | pqQueryWidget |
| template<class T > | |
pqSelectionQueryPropertyWidget is a pqPropertyWidget subclass that can be used for a property accepting a string representing a selection query. The widget allows users to build selection queries easily.
To use this widget on a property with vtkSMSelectionQueryDomain, set the panel_widget to selection_query (
Currently, this widget can faithfully present GUI for query strings that follow a specific form that is generated by this property itself. Any other forms, though valid queries, will not be represented properly in the GUI.
Definition at line 30 of file pqSelectionQueryPropertyWidget.h.
| pqSelectionQueryPropertyWidget::pqSelectionQueryPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
| void pqSelectionQueryPropertyWidget::setQuery | ( | const QString & | ) |
| const QString& pqSelectionQueryPropertyWidget::query | ( | ) | const |
signal |
friend |
Definition at line 60 of file pqSelectionQueryPropertyWidget.h.
friend |
Definition at line 63 of file pqSelectionQueryPropertyWidget.h.
friend |
Definition at line 64 of file pqSelectionQueryPropertyWidget.h.
readwrite |
Definition at line 35 of file pqSelectionQueryPropertyWidget.h.
