Signals | Public Member Functions | Properties | List of all members
pqScalarValueListPropertyWidget Class Reference
pqScalarValueListPropertyWidget provides a table widget to which users are add values e.g. More...
#include <pqScalarValueListPropertyWidget.h>
Inheritance diagram for pqScalarValueListPropertyWidget:
Collaboration diagram for pqScalarValueListPropertyWidget:
Signals
void scalarsChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqScalarValueListPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqScalarValueListPropertyWidget () override
void setScalars (const QVariantList &scalars)
QVariantList scalars () const
void setShowLabels (bool)
void setLabels (const std::vector< std::string > &labels)
void setRangeDomain (vtkSMDoubleRangeDomain *smRangeDomain)
 Sets range domain that will be used to initialize the scalar range. More...
void setRangeDomain (vtkSMIntRangeDomain *smRangeDomain)
void setRangeDomain (vtkSMTimeStepsDomain *timestepsDomain)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
for IsoValues for the Contour filter.
This widget supports the AllowRestoreDefaults hints, which adds a button that allow users to restore the default value of the property.
Definition at line 26 of file pqScalarValueListPropertyWidget.h.
◆ pqScalarValueListPropertyWidget()
pqScalarValueListPropertyWidget::pqScalarValueListPropertyWidget ( vtkSMProperty property,
vtkSMProxy proxy,
QWidget *  parent = nullptr
◆ ~pqScalarValueListPropertyWidget()
pqScalarValueListPropertyWidget::~pqScalarValueListPropertyWidget ( )
override
◆ setScalars()
void pqScalarValueListPropertyWidget::setScalars ( const QVariantList &  scalars)
◆ scalars()
QVariantList pqScalarValueListPropertyWidget::scalars ( ) const
◆ setRangeDomain() [1/3]
void pqScalarValueListPropertyWidget::setRangeDomain ( vtkSMDoubleRangeDomain smRangeDomain)
vtkSMTimeStepsDomain does have a concept of min and max that can be used as a range.
◆ setRangeDomain() [2/3]
void pqScalarValueListPropertyWidget::setRangeDomain ( vtkSMIntRangeDomain smRangeDomain)
◆ setRangeDomain() [3/3]
void pqScalarValueListPropertyWidget::setRangeDomain ( vtkSMTimeStepsDomain timestepsDomain)
◆ setShowLabels()
void pqScalarValueListPropertyWidget::setShowLabels ( bool  )
◆ setLabels()
void pqScalarValueListPropertyWidget::setLabels ( const std::vector< std::string > &  labels)
◆ scalarsChanged
void pqScalarValueListPropertyWidget::scalarsChanged ( )
signal
Property Documentation
◆ scalars
readwrite
Definition at line 29 of file pqScalarValueListPropertyWidget.h.
