This is PQ representation for a single representation. More...
#include <pqRepresentation.h>
Public Slots | |
| void | renderView (bool force) |
| Renders the view to which this representation has been added if any. More... | |
| void | renderViewEventually () |
| Simply calls renderView(false);. More... | |
Signals | |
| void | visibilityChanged (bool visible) |
| Fired when the visibility property of the underlying display changes. More... | |
| void | updated () |
| Fired whenever Update() is called on the underlying display proxy. More... | |
Signals inherited from pqProxy | |
| void | nameChanged (pqServerManagerModelItem *) |
| Fired when the name of the proxy is changed. More... | |
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| Fired when the modified status changes for the proxy. More... | |
| pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=nullptr) | |
| ~pqRepresentation () override | |
| virtual bool | isVisible () const |
| Returns if the status of the visbility property of this display. More... | |
| virtual void | setVisible (bool visible) |
| Set the visibility. More... | |
| pqView * | getView () const |
| Returns the view to which this representation has been added, if any. More... | |
| vtkSMViewProxy * | getViewProxy () const |
| Returns the view proxy to which this representation has been added, if any. More... | |
Public Member Functions inherited from pqProxy | |
| pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
| ~pqProxy () override | |
| Get the server on which this proxy exists. More... | |
| This is a convenience method. More... | |
| Get the name with which this proxy is registered on the server manager. More... | |
| Get the vtkSMProxy this object stands for. More... | |
| Gets whether or not the source has been modified. More... | |
| Sets whether or not the source has been modified. More... | |
| Returns the hints for this proxy, if any. More... | |
| Returns a list of all helper proxies. More... | |
| Returns a list of all the helper proxies added with a given key. More... | |
| Returns the keys for helper proxies. More... | |
| Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
| Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
| Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
| Return whether or not the user has modified the GUI name of the source. More... | |
Public Member Functions inherited from pqServerManagerModelItem | |
| pqServerManagerModelItem (QObject *parent=nullptr) | |
| ~pqServerManagerModelItem () override | |
Protected Slots | |
| virtual void | onVisibilityChanged () |
| called when the display visibility property changes. More... | |
Protected Slots inherited from pqProxy | |
| void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
| Called by pqView when this representation gets added to / removed from the view. More... | |
Protected Member Functions inherited from pqProxy | |
| Make this pqProxy take on a new identity. More... | |
| virtual void | initialize () |
Protected Member Functions inherited from pqServerManagerModelItem | |
| All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
Friends | |
| class | pqView |
Public Types inherited from pqProxy | |
| enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
| The modification state of this proxy. More... | |
Static Public Member Functions inherited from pqProxy | |
| static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
| Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
| static std::string | rstToHtml (const char *rstStr) |
| convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
| static QString | rstToHtml (const QString &rstStr) |
This class provides API for the Qt layer to access representations.
Definition at line 19 of file pqRepresentation.h.
| pqRepresentation::pqRepresentation | ( | const QString & | group, |
| const QString & | name, | ||
| vtkSMProxy * | repr, | ||
| pqServer * | server, | ||
| QObject * | parent = nullptr |
Note that for a display to be visible in a view, it must be added to that view as well as visibility must be set to 1.
Set the visibility.
Note that this affects the visibility of the display in the view it has been added to, if any. This method does not call a re-render on the view, caller must call that explicitly.
| pqView* pqRepresentation::getView | ( | ) | const |
| vtkSMViewProxy* pqRepresentation::getViewProxy | ( | ) | const |
slot |
If force is true, then the render is triggered immediately, otherwise, it will be called on idle.
inlineslot |
Definition at line 71 of file pqRepresentation.h.
signal |
It must be noted that this is fired on the property change, the property is not pushed yet, hence the visibility of the underlying VTK prop hasn't changed.
signal |
protectedvirtualslot |
protectedvirtual |
Reimplemented in pqPipelineRepresentation.
friend |
Definition at line 93 of file pqRepresentation.h.
