pqListPropertyWidget is a pqPropertyWidget that is used to show an editable list of elements. More...
#include <pqListPropertyWidget.h>
Signals | |
| void | valueChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqListPropertyWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqListPropertyWidget () override | |
| QList< QVariant > | value () const |
| Methods used to set/get the value for the widget. More... | |
| void | setValue (const QList< QVariant > &value) |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Properties | |
| QList< QVariant > | value |
| template<class T > | |
This is suitable for int/idtype/double/string vector properties with multiple elements, useful for allowing the user to change a range of values without adding or removing entries from it.
Definition at line 20 of file pqListPropertyWidget.h.
explicit |
| QList<QVariant> pqListPropertyWidget::value | ( | ) | const |
| void pqListPropertyWidget::setValue | ( | const QList< QVariant > & | value | ) |
signal |
readwrite |
Definition at line 24 of file pqListPropertyWidget.h.
