#include <pqIntVectorPropertyWidget.h>
| pqIntVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr) | |
| ~pqIntVectorPropertyWidget () override | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
| static pqPropertyWidget * | createWidget (vtkSMIntVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent) |
| Creates known pqPropertyWidget subclasses for vtkSMIntVectorProperty property. More... | |
| template<class T > | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
Definition at line 12 of file pqIntVectorPropertyWidget.h.
| pqIntVectorPropertyWidget::pqIntVectorPropertyWidget | ( | vtkSMProperty * | property, |
| vtkSMProxy * | proxy, | ||
