pqImplicitPlanePropertyWidget.h
4 #ifndef pqImplicitPlanePropertyWidget_h
5 #define pqImplicitPlanePropertyWidget_h
6
23 class PQAPPLICATIONCOMPONENTS_EXPORT pqImplicitPlanePropertyWidget
25 {
26  Q_OBJECT
28
29 public:
31  vtkSMProxy* proxy, vtkSMPropertyGroup* smgroup, QWidget* parent = nullptr);
33
37  void apply() override;
38  void reset() override;
40 public Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
44  void showPlane() { this->setDrawPlane(true); }
45  void hidePlane() { this->setDrawPlane(false); }
46  void setDrawPlane(bool val);
47
51  void useXNormal() { this->setNormal(1, 0, 0); }
52
56  void useYNormal() { this->setNormal(0, 1, 0); }
57
61  void useZNormal() { this->setNormal(0, 0, 1); }
62
66  void resetToDataBounds();
67
71  void resetCameraToNormal();
72
76  void useCameraNormal();
77
78 protected Q_SLOTS:
82  void placeWidget() override;
83
84 private Q_SLOTS:
85  void setOrigin(double x, double y, double z);
86
87 private: // NOLINT(readability-redundant-access-specifiers)
88  Q_DISABLE_COPY(pqImplicitPlanePropertyWidget)
89
90  void setNormal(double x, double y, double z);
91 };
92
93 #endif
pqImplicitPlanePropertyWidget::useXNormal
void useXNormal()
Set the widget normal to be along the X axis.
Definition: pqImplicitPlanePropertyWidget.h:51
pqImplicitPlanePropertyWidget::hidePlane
void hidePlane()
Definition: pqImplicitPlanePropertyWidget.h:45
vtkSMProxy
Definition: vtkSMProxy.h:140
vtkSMPropertyGroup
Definition: vtkSMPropertyGroup.h:16
pqInteractivePropertyWidget.h
pqPropertyWidget::apply
virtual void apply()
pqImplicitPlanePropertyWidget::useZNormal
void useZNormal()
Set the widget normal to be along the Z axis.
Definition: pqImplicitPlanePropertyWidget.h:61
pqInteractivePropertyWidgetAbstract::placeWidget
virtual void placeWidget()=0
Places the interactive widget using current data source information.
pqImplicitPlanePropertyWidget is a custom property widget that uses "ImplicitPlaneWidgetRepresentatio...
Definition: pqImplicitPlanePropertyWidget.h:23
pqInteractivePropertyWidget is an abstract pqPropertyWidget subclass designed to serve as the supercl...
Definition: pqInteractivePropertyWidget.h:29
pqImplicitPlanePropertyWidget::useYNormal
void useYNormal()
Set the widget normal to be along the Y axis.
Definition: pqImplicitPlanePropertyWidget.h:56
pqInteractivePropertyWidgetAbstract::reset
Overridden to call this->render() to ensure that the widget is redrawn.
pqImplicitPlanePropertyWidget::showPlane
void showPlane()
Slots used to toggle the visibility of the translucent plane.
Definition: pqImplicitPlanePropertyWidget.h:44
