vtkShaderBallScene Class Reference
#include <vtkShaderBallScene.h>
Inheritance diagram for vtkShaderBallScene:
Collaboration diagram for vtkShaderBallScene:
virtual vtkGenericOpenGLRenderWindow * GetWindow ()
 Returns the render window where the scene is rendered. More...
virtual vtkRenderer * GetRenderer ()
 Returns the renderer for the simple scene. More...
void Render ()
 Renders the scene. More...
void ResetOSPrayPass ()
 Resets the vtkOSPRayPass of the scene. More...
void Modified () override
void SetMaterialName (const char *)
 Updates the sphere material with the given material name Default is empty. More...
const char * GetMaterialName () const
void SetNumberOfSamples (int numberOfSamples)
 Setup the number of samples to use in the Shader ball scene. More...
int GetNumberOfSamples () const
void SetVisible (bool visible)
 Set the value of visible and render the scene if value is true. More...
virtual bool GetVisible ()
virtual void VisibleOn ()
virtual void VisibleOff ()
static vtkShaderBallScene * New ()
static vtkShaderBallScene * SafeDownCast (vtkObject *o)
 vtkShaderBallScene ()
virtual ~vtkShaderBallScene ()
Used as part of the pqMaterialEditor to display the current selected material in a simple scene containing a sphere and a plane.
Definition at line 23 of file vtkShaderBallScene.h.
Definition at line 27 of file vtkShaderBallScene.h.
◆ vtkShaderBallScene()
vtkShaderBallScene::vtkShaderBallScene ( )
◆ ~vtkShaderBallScene()
virtual vtkShaderBallScene::~vtkShaderBallScene ( )
protectedvirtual
static vtkShaderBallScene* vtkShaderBallScene::New ( )
virtual const char* vtkShaderBallScene::GetClassName ( )
static int vtkShaderBallScene::IsTypeOf ( const char *  type)
virtual int vtkShaderBallScene::IsA ( const char *  type)
static vtkShaderBallScene* vtkShaderBallScene::SafeDownCast ( vtkObject *  o)
void vtkShaderBallScene::PrintSelf ( ostream &  os,
◆ GetWindow()
virtual vtkGenericOpenGLRenderWindow* vtkShaderBallScene::GetWindow ( )
◆ GetRenderer()
virtual vtkRenderer* vtkShaderBallScene::GetRenderer ( )
◆ SetMaterialName()
void vtkShaderBallScene::SetMaterialName ( const char *  )
◆ GetMaterialName()
const char* vtkShaderBallScene::GetMaterialName ( ) const
◆ SetNumberOfSamples()
void vtkShaderBallScene::SetNumberOfSamples ( int  numberOfSamples)
Default is 2.
◆ GetNumberOfSamples()
int vtkShaderBallScene::GetNumberOfSamples ( ) const
Default is 2.
◆ SetVisible()
void vtkShaderBallScene::SetVisible ( bool  visible)
Default is false.
◆ GetVisible()
virtual bool vtkShaderBallScene::GetVisible ( )
Default is false.
◆ VisibleOn()
virtual void vtkShaderBallScene::VisibleOn ( )
Default is false.
◆ VisibleOff()
virtual void vtkShaderBallScene::VisibleOff ( )
Default is false.
◆ Render()
void vtkShaderBallScene::Render ( )
Renders the scene.
◆ ResetOSPrayPass()
void vtkShaderBallScene::ResetOSPrayPass ( )
This must be called when the widget containing this class is pop upped, otherwise it crashes.
The problems comes from vtkOSPRayPass.cxx::RenderInternal where the shader is destroyed whenever the window is poped out
◆ Modified()
void vtkShaderBallScene::Modified ( )
