Public Types | Public Member Functions | Protected Slots | Protected Member Functions | Friends | List of all members
pqMaterialEditor Class Reference
pqMaterialEditor is a widget that can be used to edit the OSPRay materials. More...
#include <pqMaterialEditor.h>
Inherits QWidget.
enum  ExtendedItemDataRole { ExtendedItemDataRole::PropertyValue = Qt::UserRole + 1 }
 Strong type extension of the existing Qt::ItemDataRole. More...
 pqMaterialEditor (QWidget *parent=nullptr, QDockWidget *dockWidget=nullptr)
 ~pqMaterialEditor () override
void updateMaterialList ()
 Clear the editor and fill the editor with the current created materials. More...
QString currentMaterialName ()
 Return the name of the current selected material. More...
std::vector< std::string > availableParameters ()
 Return the list of the available OSPRay parameters for the current material. More...
Protected Slots
void updateCurrentMaterial (const std::string &)
void updateCurrentMaterialWithIndex (int index)
void loadMaterials ()
void addMaterial ()
void removeMaterial ()
void attachMaterial ()
void saveMaterials ()
void addProperty ()
void propertyChanged (const QModelIndex &topLeft, const QModelIndex &bottomRight)
std::string generateValidMaterialName (const std::string &name)
 Return a unique material name given a desired name. More...
void showEvent (QShowEvent *event) override
 Overriden to warn user when material editor is not usable. More...
Friends
class pqInternals
This widget allows you to create or remove an OSPRay material. Then, you can customize this material by adding or removing properties, such as the color, the roughness, the textures... depending on the available properties that you can see in vtkOSPRayMaterialLibrary. Texture format supported are *.png, *.jpg, *.bmp and *.ppm.
Definition at line 26 of file pqMaterialEditor.h.
◆ ExtendedItemDataRole
This is used to store the QVariant value for the properties
Enumerator
PropertyValue
Definition at line 54 of file pqMaterialEditor.h.
◆ pqMaterialEditor()
pqMaterialEditor::pqMaterialEditor ( QWidget *  parent = nullptr,
QDockWidget *  dockWidget = nullptr
◆ ~pqMaterialEditor()
pqMaterialEditor::~pqMaterialEditor ( )
override
◆ updateMaterialList()
void pqMaterialEditor::updateMaterialList ( )
◆ currentMaterialName()
QString pqMaterialEditor::currentMaterialName ( )
◆ availableParameters()
std::vector<std::string> pqMaterialEditor::availableParameters ( )
◆ updateCurrentMaterial
void pqMaterialEditor::updateCurrentMaterial ( const std::string &  )
protectedslot
◆ updateCurrentMaterialWithIndex
void pqMaterialEditor::updateCurrentMaterialWithIndex ( int  index)
protectedslot
◆ loadMaterials
void pqMaterialEditor::loadMaterials ( )
protectedslot
◆ addMaterial
void pqMaterialEditor::addMaterial ( )
protectedslot
◆ removeMaterial
void pqMaterialEditor::removeMaterial ( )
protectedslot
◆ attachMaterial
void pqMaterialEditor::attachMaterial ( )
protectedslot
◆ saveMaterials
void pqMaterialEditor::saveMaterials ( )
protectedslot
◆ addProperty
void pqMaterialEditor::addProperty ( )
protectedslot
◆ propertyChanged
void pqMaterialEditor::propertyChanged ( const QModelIndex &  topLeft,
const QModelIndex &  bottomRight
protectedslot
◆ generateValidMaterialName()
std::string pqMaterialEditor::generateValidMaterialName ( const std::string &  name)
Checks for all the already existing materials and if one has the same name, this function appends the suffix _X where X is the next unique integer identifier.
◆ showEvent()
void pqMaterialEditor::showEvent ( QShowEvent *  event)
◆ pqInternals
friend class pqInternals
friend
Definition at line 93 of file pqMaterialEditor.h.
