Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
vtkDataLabelRepresentation Class Reference
representation for showing cell and point labels. More...
#include <vtkDataLabelRepresentation.h>
Inheritance diagram for vtkDataLabelRepresentation:
Collaboration diagram for vtkDataLabelRepresentation:
enum  DesiredOutputPrecision
void SetPointLabelVisibility (int)
void SetPointFieldDataArrayName (const char *)
void SetPointLabelMode (int)
void SetPointLabelColor (double r, double g, double b)
void SetPointLabelOpacity (double)
void SetPointLabelFontFamily (int)
void SetPointLabelFontFile (char *)
void SetPointLabelBold (int)
void SetPointLabelItalic (int)
void SetPointLabelShadow (int)
void SetPointLabelJustification (int)
void SetPointLabelFontSize (int)
void SetPointLabelFormat (const char *)
void SetCellLabelVisibility (int)
void SetCellFieldDataArrayName (const char *)
void SetCellLabelMode (int)
void SetCellLabelColor (double r, double g, double b)
void SetCellLabelOpacity (double)
void SetCellLabelFontFamily (int)
void SetCellLabelFontFile (char *)
void SetCellLabelBold (int)
void SetCellLabelItalic (int)
void SetCellLabelShadow (int)
void SetCellLabelJustification (int)
void SetCellLabelFontSize (int)
void SetCellLabelFormat (const char *)
void SetVisibility (bool val) override
bool GetVisibility () override
void SetMaximumNumberOfLabels (int numLabels)
 Get/Set the maximum number of points/cells that will be labeled. More...
int GetMaximumNumberOfLabels ()
void SetOrientation (double, double, double)
 Used to build the internal transform. More...
void SetOrigin (double, double, double)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetUserTransform (const double[16])
virtual void MarkModified ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkDataLabelRepresentation * New ()
static vtkDataLabelRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkDataLabelRepresentation ()
 ~vtkDataLabelRepresentation () override
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
void UpdateTransform ()
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
static void OnWarningEvent (vtkObject *source, unsigned long, void *clientdata, void *)
vtkMergeBlocks * MergeBlocks
vtkSmartPointer< vtkMaskPoints > PointMask
vtkLabeledDataMapper * PointLabelMapper
vtkTextProperty * PointLabelProperty
vtkActor2D * PointLabelActor
vtkCellCenters * CellCenters
vtkSmartPointer< vtkMaskPoints > CellMask
vtkLabeledDataMapper * CellLabelMapper
vtkTextProperty * CellLabelProperty
vtkActor2D * CellLabelActor
vtkProp3D * TransformHelperProp
vtkTransform * Transform
vtkSmartPointer< vtkDataObject > Dataset
vtkCallbackCommand * WarningObserver
int PointLabelVisibility
int CellLabelVisibility
int MaximumNumberOfLabels
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkDataLabelRepresentation is a representation for showing cell and/or point labels. This representation relies on all the data being cloned on all nodes hence beware of using this representation for large datasets.
Caveat:
Note that vtkDataLabelRepresentation adds the label props to the non-composited renderer.
The addition of a transformation matrix was supported by CEA/DIF Commissariat a l'Energie Atomique, Centre DAM Ile-De-France, Arpajon, France.
Definition at line 36 of file vtkDataLabelRepresentation.h.
Definition at line 40 of file vtkDataLabelRepresentation.h.
◆ vtkDataLabelRepresentation()
vtkDataLabelRepresentation::vtkDataLabelRepresentation ( )
◆ ~vtkDataLabelRepresentation()
vtkDataLabelRepresentation::~vtkDataLabelRepresentation ( )
static vtkDataLabelRepresentation* vtkDataLabelRepresentation::New ( )
virtual const char* vtkDataLabelRepresentation::GetClassName ( )
static int vtkDataLabelRepresentation::IsTypeOf ( const char *  type)
virtual int vtkDataLabelRepresentation::IsA ( const char *  type)
static vtkDataLabelRepresentation* vtkDataLabelRepresentation::SafeDownCast ( vtkObject *  o)
void vtkDataLabelRepresentation::PrintSelf ( ostream &  os,
◆ SetVisibility()
void vtkDataLabelRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ GetVisibility()
bool vtkDataLabelRepresentation::GetVisibility ( )
◆ SetMaximumNumberOfLabels()
void vtkDataLabelRepresentation::SetMaximumNumberOfLabels ( int  numLabels)
Too many labels is difficult to read so this may help with large datasets. Default: 100.
◆ GetMaximumNumberOfLabels()
int vtkDataLabelRepresentation::GetMaximumNumberOfLabels ( )
◆ SetPointLabelVisibility()
void vtkDataLabelRepresentation::SetPointLabelVisibility ( int  )
◆ SetPointFieldDataArrayName()
void vtkDataLabelRepresentation::SetPointFieldDataArrayName ( const char *  )
◆ SetPointLabelMode()
void vtkDataLabelRepresentation::SetPointLabelMode ( int  )
◆ SetPointLabelColor()
void vtkDataLabelRepresentation::SetPointLabelColor ( double  r,
double  g,
double  b
◆ SetPointLabelOpacity()
void vtkDataLabelRepresentation::SetPointLabelOpacity ( double  )
◆ SetPointLabelFontFamily()
void vtkDataLabelRepresentation::SetPointLabelFontFamily ( int  )
◆ SetPointLabelFontFile()
void vtkDataLabelRepresentation::SetPointLabelFontFile ( char *  )
◆ SetPointLabelBold()
void vtkDataLabelRepresentation::SetPointLabelBold ( int  )
◆ SetPointLabelItalic()
void vtkDataLabelRepresentation::SetPointLabelItalic ( int  )
◆ SetPointLabelShadow()
void vtkDataLabelRepresentation::SetPointLabelShadow ( int  )
◆ SetPointLabelJustification()
void vtkDataLabelRepresentation::SetPointLabelJustification ( int  )
◆ SetPointLabelFontSize()
void vtkDataLabelRepresentation::SetPointLabelFontSize ( int  )
◆ SetPointLabelFormat()
void vtkDataLabelRepresentation::SetPointLabelFormat ( const char *  )
◆ SetCellLabelVisibility()
void vtkDataLabelRepresentation::SetCellLabelVisibility ( int  )
◆ SetCellFieldDataArrayName()
void vtkDataLabelRepresentation::SetCellFieldDataArrayName ( const char *  )
◆ SetCellLabelMode()
void vtkDataLabelRepresentation::SetCellLabelMode ( int  )
◆ SetCellLabelColor()
void vtkDataLabelRepresentation::SetCellLabelColor ( double  r,
double  g,
double  b
◆ SetCellLabelOpacity()
void vtkDataLabelRepresentation::SetCellLabelOpacity ( double  )
◆ SetCellLabelFontFamily()
void vtkDataLabelRepresentation::SetCellLabelFontFamily ( int  )
◆ SetCellLabelFontFile()
void vtkDataLabelRepresentation::SetCellLabelFontFile ( char *  )
◆ SetCellLabelBold()
void vtkDataLabelRepresentation::SetCellLabelBold ( int  )
◆ SetCellLabelItalic()
void vtkDataLabelRepresentation::SetCellLabelItalic ( int  )
◆ SetCellLabelShadow()
void vtkDataLabelRepresentation::SetCellLabelShadow ( int  )
◆ SetCellLabelJustification()
void vtkDataLabelRepresentation::SetCellLabelJustification ( int  )
◆ SetCellLabelFontSize()
void vtkDataLabelRepresentation::SetCellLabelFontSize ( int  )
◆ SetCellLabelFormat()
void vtkDataLabelRepresentation::SetCellLabelFormat ( const char *  )
◆ SetOrientation()
void vtkDataLabelRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrigin()
void vtkDataLabelRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPosition()
void vtkDataLabelRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
void vtkDataLabelRepresentation::SetScale ( double  ,
double  ,
double
◆ SetUserTransform()
void vtkDataLabelRepresentation::SetUserTransform ( const double  [16])
◆ ProcessViewRequest()
int vtkDataLabelRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ AddToView()
bool vtkDataLabelRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkDataLabelRepresentation::RemoveFromView ( vtkView *  view)
◆ FillInputPortInformation()
int vtkDataLabelRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkDataLabelRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
◆ UpdateTransform()
void vtkDataLabelRepresentation::UpdateTransform ( )
◆ OnWarningEvent()
static void vtkDataLabelRepresentation::OnWarningEvent ( vtkObject *  source,
unsigned long  ,
void *  clientdata,
void *
staticprotected
◆ MergeBlocks
vtkMergeBlocks* vtkDataLabelRepresentation::MergeBlocks
Definition at line 148 of file vtkDataLabelRepresentation.h.
◆ PointMask
vtkSmartPointer<vtkMaskPoints> vtkDataLabelRepresentation::PointMask
Definition at line 150 of file vtkDataLabelRepresentation.h.
◆ PointLabelMapper
vtkLabeledDataMapper* vtkDataLabelRepresentation::PointLabelMapper
Definition at line 151 of file vtkDataLabelRepresentation.h.
◆ PointLabelProperty
vtkTextProperty* vtkDataLabelRepresentation::PointLabelProperty
Definition at line 152 of file vtkDataLabelRepresentation.h.
◆ PointLabelActor
vtkActor2D* vtkDataLabelRepresentation::PointLabelActor
Definition at line 153 of file vtkDataLabelRepresentation.h.
◆ CellCenters
vtkCellCenters* vtkDataLabelRepresentation::CellCenters
Definition at line 155 of file vtkDataLabelRepresentation.h.
◆ CellMask
vtkSmartPointer<vtkMaskPoints> vtkDataLabelRepresentation::CellMask
Definition at line 156 of file vtkDataLabelRepresentation.h.
◆ CellLabelMapper
vtkLabeledDataMapper* vtkDataLabelRepresentation::CellLabelMapper
Definition at line 157 of file vtkDataLabelRepresentation.h.
◆ CellLabelProperty
vtkTextProperty* vtkDataLabelRepresentation::CellLabelProperty
Definition at line 158 of file vtkDataLabelRepresentation.h.
◆ CellLabelActor
vtkActor2D* vtkDataLabelRepresentation::CellLabelActor
Definition at line 159 of file vtkDataLabelRepresentation.h.
◆ TransformHelperProp
vtkProp3D* vtkDataLabelRepresentation::TransformHelperProp
Definition at line 161 of file vtkDataLabelRepresentation.h.
◆ Transform
vtkTransform* vtkDataLabelRepresentation::Transform
Definition at line 162 of file vtkDataLabelRepresentation.h.
◆ Dataset
vtkSmartPointer<vtkDataObject> vtkDataLabelRepresentation::Dataset
Definition at line 164 of file vtkDataLabelRepresentation.h.
◆ WarningObserver
vtkCallbackCommand* vtkDataLabelRepresentation::WarningObserver
Definition at line 167 of file vtkDataLabelRepresentation.h.
◆ PointLabelVisibility
int vtkDataLabelRepresentation::PointLabelVisibility
Definition at line 170 of file vtkDataLabelRepresentation.h.
◆ CellLabelVisibility
int vtkDataLabelRepresentation::CellLabelVisibility
Definition at line 171 of file vtkDataLabelRepresentation.h.
◆ MaximumNumberOfLabels
int vtkDataLabelRepresentation::MaximumNumberOfLabels
Definition at line 172 of file vtkDataLabelRepresentation.h.
