vtkSMProxySelectionModel Class Reference
selects proxies. More...
#include <vtkSMProxySelectionModel.h>
Inheritance diagram for vtkSMProxySelectionModel:
Collaboration diagram for vtkSMProxySelectionModel:
enum  ProxySelectionFlag {
  NO_UPDATE = 0, CLEAR = 1, SELECT = 2, DESELECT = 4,
  CLEAR_AND_SELECT = CLEAR | SELECT
typedef std::list< vtkSmartPointer< vtkSMProxy > > SelectionType
 Type for selection. More...
 Override the set session, so we can attach an observer to the Collaboration manager in order to monitor master/slave changes. More...
vtkSMProxy * GetCurrentProxy ()
 Returns the proxy that is current, nullptr if there is no current. More...
void SetCurrentProxy (vtkSMProxy *proxy, int command)
 Sets the current proxy. More...
bool IsSelected (vtkSMProxy *proxy)
 Returns true if the proxy is selected. More...
unsigned int GetNumberOfSelectedProxies ()
vtkSMProxy * GetSelectedProxy (unsigned int index)
 Returns the selected proxy at the given index. More...
const SelectionType & GetSelection ()
 Returns the selection set. More...
void Select (const SelectionType &proxies, int command)
 Update the selected set of proxies. More...
void Select (vtkSMProxy *proxy, int command)
void Clear ()
 Wrapper friendly methods to doing what Select() can do. More...
void Select (vtkSMProxy *proxy)
void Deselect (vtkSMProxy *proxy)
void ClearAndSelect (vtkSMProxy *proxy)
bool GetSelectionDataBounds (double bounds[6])
 Utility method to get the data bounds for the currently selected items. More...
void SetFollowingMaster (bool following)
 Allow to synchronize the active object with master or just keep remote object out-of-synch. More...
bool IsFollowingMaster ()
bool HasGlobalID ()
virtual void EnableLocalPushOnly ()
virtual void DisableLocalPushOnly ()
virtual void SetLocation (vtkTypeUInt32)
virtual void PrototypeOn ()
virtual void PrototypeOff ()
bool IsPrototype ()
virtual void SetPrototype (bool)
static vtkSMProxySelectionModel * New ()
static vtkSMProxySelectionModel * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProxySelectionModel ()
 ~vtkSMProxySelectionModel () override
void InvokeCurrentChanged (vtkSMProxy *proxy)
void InvokeSelectionChanged ()
void PushStateToSession ()
 When the state has changed we call that method so the state can be shared is any collaboration is involved. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSmartPointer< vtkSMProxy > Current
SelectionType Selection
vtkSMMessage * State
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Friends
class vtkInternal
selects proxies.
vtkSMProxySelectionModel is used to select proxies. vtkSMProxyManager uses two instances of vtkSMProxySelectionModel for keeping track of the selected/active sources/filters and the active view.
See also
vtkSMProxyManager
Definition at line 28 of file vtkSMProxySelectionModel.h.
Definition at line 32 of file vtkSMProxySelectionModel.h.
◆ SelectionType
Type for selection.
Definition at line 53 of file vtkSMProxySelectionModel.h.
◆ ProxySelectionFlag
Enumerator
NO_UPDATE
CLEAR
SELECT
DESELECT
CLEAR_AND_SELECT
Definition at line 56 of file vtkSMProxySelectionModel.h.
◆ vtkSMProxySelectionModel()
vtkSMProxySelectionModel::vtkSMProxySelectionModel ( )
◆ ~vtkSMProxySelectionModel()
vtkSMProxySelectionModel::~vtkSMProxySelectionModel ( )
static vtkSMProxySelectionModel* vtkSMProxySelectionModel::New ( )
virtual const char* vtkSMProxySelectionModel::GetClassName ( )
Reimplemented from vtkSMRemoteObject.
static int vtkSMProxySelectionModel::IsTypeOf ( const char *  type)
virtual int vtkSMProxySelectionModel::IsA ( const char *  type)
static vtkSMProxySelectionModel* vtkSMProxySelectionModel::SafeDownCast ( vtkObject *  o)
void vtkSMProxySelectionModel::PrintSelf ( ostream &  os,
◆ SetSession()
void vtkSMProxySelectionModel::SetSession ( vtkSMSession *  )
Reimplemented from vtkSMSessionObject.
◆ SetFollowingMaster()
void vtkSMProxySelectionModel::SetFollowingMaster ( bool  following)
Only the state from the master will be loaded.
◆ IsFollowingMaster()
bool vtkSMProxySelectionModel::IsFollowingMaster ( )
◆ GetCurrentProxy()
vtkSMProxy* vtkSMProxySelectionModel::GetCurrentProxy ( )
◆ SetCurrentProxy()
void vtkSMProxySelectionModel::SetCurrentProxy ( vtkSMProxy *  proxy,
int  command
command is used to control how the current selection is affected.
  • NO_UPDATE: change the current without affecting the selected set of proxies.
  • CLEAR: clear current selection
  • SELECT: also select the proxy being set as current
  • DESELECT: deselect the proxy being set as current.
◆ IsSelected()
bool vtkSMProxySelectionModel::IsSelected ( vtkSMProxy *  proxy)
◆ GetNumberOfSelectedProxies()
unsigned int vtkSMProxySelectionModel::GetNumberOfSelectedProxies ( )
◆ GetSelectedProxy()
vtkSMProxy* vtkSMProxySelectionModel::GetSelectedProxy ( unsigned int  index)
◆ GetSelection()
const SelectionType& vtkSMProxySelectionModel::GetSelection ( )
inline
Definition at line 97 of file vtkSMProxySelectionModel.h.
◆ Select() [1/3]
void vtkSMProxySelectionModel::Select ( const SelectionType &  proxies,
int  command
command affects how the selection is updated.
  • NO_UPDATE: don't affect the selected set of proxies.
  • CLEAR: clear selection
  • SELECT: add the proxies to selection
  • DESELECT: deselect the proxies
  • CLEAR_AND_SELECT: clear selection and then add the specified proxies as the selection.
◆ Select() [2/3]
void vtkSMProxySelectionModel::Select ( vtkSMProxy *  proxy,
int  command
◆ Clear()
void vtkSMProxySelectionModel::Clear ( )
inline
Definition at line 117 of file vtkSMProxySelectionModel.h.
◆ Select() [3/3]
void vtkSMProxySelectionModel::Select ( vtkSMProxy *  proxy)
inline
Definition at line 118 of file vtkSMProxySelectionModel.h.
◆ Deselect()
void vtkSMProxySelectionModel::Deselect ( vtkSMProxy *  proxy)
inline
Definition at line 119 of file vtkSMProxySelectionModel.h.
◆ ClearAndSelect()
void vtkSMProxySelectionModel::ClearAndSelect ( vtkSMProxy *  proxy)
inline
Definition at line 120 of file vtkSMProxySelectionModel.h.
◆ GetSelectionDataBounds()
bool vtkSMProxySelectionModel::GetSelectionDataBounds ( double  bounds[6])
This only makes sense for selections comprising of source-proxies or output-port proxies. Returns true is the bounds are valid.
◆ GetFullState()
const vtkSMMessage* vtkSMProxySelectionModel::GetFullState ( )
This method return the full object state that can be used to create that object from scratch.
This method will be used to fill the undo stack. If not overridden this will return nullptr.
◆ LoadState()
void vtkSMProxySelectionModel::LoadState ( const vtkSMMessage *  msg,
vtkSMProxyLocator *  locator
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
◆ InvokeCurrentChanged()
void vtkSMProxySelectionModel::InvokeCurrentChanged ( vtkSMProxy *  proxy)
◆ InvokeSelectionChanged()
void vtkSMProxySelectionModel::InvokeSelectionChanged ( )
◆ PushStateToSession()
void vtkSMProxySelectionModel::PushStateToSession ( )
◆ vtkInternal
friend class vtkInternal
friend
Definition at line 170 of file vtkSMProxySelectionModel.h.
◆ Current
vtkSmartPointer<vtkSMProxy> vtkSMProxySelectionModel::Current
Definition at line 154 of file vtkSMProxySelectionModel.h.
◆ Selection
SelectionType vtkSMProxySelectionModel::Selection
Definition at line 155 of file vtkSMProxySelectionModel.h.
◆ State
vtkSMMessage* vtkSMProxySelectionModel::State
Definition at line 164 of file vtkSMProxySelectionModel.h.
