vtkSMPluginManager Class Reference
manages ParaView plugins. More...
#include <vtkSMPluginManager.h>
Inheritance diagram for vtkSMPluginManager:
Collaboration diagram for vtkSMPluginManager:
enum  { PluginLoadedEvent = 100000, LocalPluginLoadedEvent, RemotePluginLoadedEvent }
void LoadPluginConfigurationXMLFromString (const char *xmlcontents, vtkSMSession *session, bool remote)
 Plugin configuration XML is a simple XML that makes ParaView aware of the plugins available and may result in loading of those plugins that are marked for auto-loading. More...
bool FulfillPluginRequirements (vtkSMSession *session, bool onlyCheck=false)
 Method to load remote plugins in order to meet plugin requirement across processes. More...
void RegisterSession (vtkSMSession *)
 Register/Unregister a session. More...
void UnRegisterSession (vtkSMSession *)
virtual vtkPVPluginsInformation * GetLocalInformation ()
 vtkPVPluginsInformation provides information about plugins loaded/available. More...
vtkPVPluginsInformation * GetRemoteInformation (vtkSMSession *)
const char * GetLocalPluginSearchPaths ()
 Returns the plugin search paths used either locally or remotely. More...
const char * GetRemotePluginSearchPaths (vtkSMSession *)
bool LoadRemotePlugin (const char *filename, vtkSMSession *)
 Loads the plugin either locally or remotely. More...
bool LoadLocalPlugin (const char *filename)
static vtkSMPluginManager * New ()
static vtkSMPluginManager * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMPluginManager ()
 ~vtkSMPluginManager () override
void OnPluginRegistered ()
void OnPluginAvailable ()
void UpdateLocalPluginInformation ()
bool FulfillPluginClientServerRequirements (vtkSMSession *session, const std::map< std::string, unsigned int > &inputMap, vtkPVPluginsInformation *inputPluginInfo, const std::map< std::string, unsigned int > &outputMap, vtkPVPluginsInformation *outputPluginInfo, bool inputClient, bool onlyCheck)
 Protected method used by FulfillPluginRequirements to check and load client/server plugin requirements. More...
 vtkSMObject ()
 ~vtkSMObject () override
bool InLoadPlugin
vtkPVPluginsInformation * LocalInformation
vtkSMPluginManager is used to load plugins as well as discover information about currently loaded and available plugins.
vtkSMPluginManager supports multiple sessions. Every vtkSMSession registers itself with the vtkSMPluginManager during initialization.
Definition at line 23 of file vtkSMPluginManager.h.
Definition at line 27 of file vtkSMPluginManager.h.
◆ anonymous enum
anonymous enum
Enumerator
PluginLoadedEvent
Definition at line 94 of file vtkSMPluginManager.h.
◆ vtkSMPluginManager()
vtkSMPluginManager::vtkSMPluginManager ( )
◆ ~vtkSMPluginManager()
vtkSMPluginManager::~vtkSMPluginManager ( )
static vtkSMPluginManager* vtkSMPluginManager::New ( )
virtual const char* vtkSMPluginManager::GetClassName ( )
static int vtkSMPluginManager::IsTypeOf ( const char *  type)
virtual int vtkSMPluginManager::IsA ( const char *  type)
static vtkSMPluginManager* vtkSMPluginManager::SafeDownCast ( vtkObject *  o)
void vtkSMPluginManager::PrintSelf ( ostream &  os,
◆ RegisterSession()
void vtkSMPluginManager::RegisterSession ( vtkSMSession *  )
Every vtkSMSession must be registered with the vtkSMPluginManager. This is done automatically by vtkSMSession during the initialization stage. Note that the vtkSMSession is not reference counted.
◆ UnRegisterSession()
void vtkSMPluginManager::UnRegisterSession ( vtkSMSession *  )
◆ GetLocalInformation()
virtual vtkPVPluginsInformation* vtkSMPluginManager::GetLocalInformation ( )
LocalInformation corresponds to plugins loaded on the local process. For remote sessions i.e. those that connect to a remote server process, one can use GetRemoteInformation() to access information about plugins on the remote process.
◆ GetRemoteInformation()
vtkPVPluginsInformation* vtkSMPluginManager::GetRemoteInformation ( vtkSMSession *  )
◆ GetLocalPluginSearchPaths()
const char* vtkSMPluginManager::GetLocalPluginSearchPaths ( )
For non-remote sessions, GetRemotePluginSearchPaths() returns the same value as GetLocalPluginSearchPaths().
◆ GetRemotePluginSearchPaths()
const char* vtkSMPluginManager::GetRemotePluginSearchPaths ( vtkSMSession *  )
◆ LoadRemotePlugin()
bool vtkSMPluginManager::LoadRemotePlugin ( const char *  filename,
vtkSMSession *
◆ LoadLocalPlugin()
bool vtkSMPluginManager::LoadLocalPlugin ( const char *  filename)
◆ LoadPluginConfigurationXMLFromString()
void vtkSMPluginManager::LoadPluginConfigurationXMLFromString ( const char *  xmlcontents,
vtkSMSession *  session,
bool  remote
In ParaView application there are two uses for this:
  • .plugins - used to notify ParaView of the distributed plugins
  • session - used to save/restore the plugins loaded by the users.
This method loads the plugin configuration xml either on the local process or the remote server process(es). session is only used when remote==true and session itself is a remote session.
◆ FulfillPluginRequirements()
bool vtkSMPluginManager::FulfillPluginRequirements ( vtkSMSession *  session,
bool  onlyCheck = false
This also updates the "StatusMessage" for all the plugins. If StatusMessage is empty for a loaded plugin, it implies that everything is fine. If some requirement is not met, the StatusMessage includes the error message. Set onlyCheck to true to only check and set status without loading plugins.
◆ OnPluginRegistered()
void vtkSMPluginManager::OnPluginRegistered ( )
◆ OnPluginAvailable()
void vtkSMPluginManager::OnPluginAvailable ( )
◆ UpdateLocalPluginInformation()
void vtkSMPluginManager::UpdateLocalPluginInformation ( )
◆ FulfillPluginClientServerRequirements()
bool vtkSMPluginManager::FulfillPluginClientServerRequirements ( vtkSMSession *  session,
const std::map< std::string, unsigned int > &  inputMap,
vtkPVPluginsInformation *  inputPluginInfo,
const std::map< std::string, unsigned int > &  outputMap,
vtkPVPluginsInformation *  outputPluginInfo,
bool  inputClient,
bool  onlyCheck
◆ InLoadPlugin
bool vtkSMPluginManager::InLoadPlugin
Definition at line 105 of file vtkSMPluginManager.h.
◆ LocalInformation
vtkPVPluginsInformation* vtkSMPluginManager::LocalInformation
Definition at line 119 of file vtkSMPluginManager.h.
