vtkSMProxyLink Class Reference
creates a link between two proxies. More...
#include <vtkSMProxyLink.h>
Inheritance diagram for vtkSMProxyLink:
Collaboration diagram for vtkSMProxyLink:
enum  ExceptionListBehavior : int { BLACKLIST = 0, WHITELIST }
typedef vtkSMLink Superclass
virtual void AddLinkedProxy (vtkSMProxy *proxy, int updateDir)
 Add a property to the link. More...
virtual void LinkProxies (vtkSMProxy *proxy1, vtkSMProxy *proxy2)
 Utility method to add 2 proxies, both as INPUT and OUTPUT. More...
virtual void LinkProxyPropertyProxies (vtkSMProxy *proxy1, vtkSMProxy *proxy2, const char *pname)
 Utility method to link the proxies stored as proxy property of input proxies. More...
virtual void RemoveLinkedProxy (vtkSMProxy *proxy)
 Remove a linked proxy. More...
vtkSMProxy * GetLinkedProxy (int index) override
 Get a proxy involved in this link. More...
void RemoveAllLinks () override
 Remove all links. More...
unsigned int GetNumberOfLinkedObjects () override
 Get the number of proxies that are involved in this link. More...
unsigned int GetNumberOfLinkedProxies ()
int GetLinkedObjectDirection (int index) override
 Get the direction of a proxy involved in this link (see vtkSMLink::UpdateDirections) More...
int GetLinkedProxyDirection (int index)
void AddException (const char *propertyname)
 It is possible to exclude certain properties from being synchronized by this link. More...
void RemoveException (const char *propertyname)
void ClearExceptions ()
virtual void SetExceptionBehavior (int)
 Set/Get exception behavior. More...
virtual int GetExceptionBehavior ()
void SetExceptionBehaviorToBlacklist ()
void SetExceptionBehaviorToWhitelist ()
bool HasGlobalID ()
virtual void EnableLocalPushOnly ()
virtual void DisableLocalPushOnly ()
virtual void SetLocation (vtkTypeUInt32)
virtual void PrototypeOn ()
virtual void PrototypeOff ()
bool IsPrototype ()
virtual void SetPrototype (bool)
static vtkSMProxyLink * New ()
static vtkSMProxyLink * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProxyLink ()
 ~vtkSMProxyLink () override
void UpdateVTKObjects (vtkSMProxy *proxy) override
 Called when an input proxy is updated (UpdateVTKObjects). More...
void PropertyModified (vtkSMProxy *proxy, const char *pname) override
 Called when a property of an input proxy is modified. More...
void UpdateProperty (vtkSMProxy *caller, const char *pname) override
 Called when a property is pushed. More...
virtual std::string GetXMLTagName ()
 Get tag name to use in statefile. More...
void SaveXMLState (const char *linkname, vtkPVXMLElement *parent) override
 Save the state of the link. More...
int LoadXMLState (vtkPVXMLElement *linkElement, vtkSMProxyLocator *locator) override
 Load the link state. More...
void UpdateState () override
 Update the internal protobuf state. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
When a link is created between proxy A->B, whenever any property on proxy A is modified, a property with the same name as the modified property (if any) on proxy B is also modified to be the same as the property on the proxy A. Similarly whenever proxy A->UpdateVTKObjects() is called, B->UpdateVTKObjects() is also fired.
Definition at line 24 of file vtkSMProxyLink.h.
Definition at line 28 of file vtkSMProxyLink.h.
◆ ExceptionListBehavior
Enumerator
BLACKLIST
WHITELIST
Definition at line 31 of file vtkSMProxyLink.h.
◆ vtkSMProxyLink()
vtkSMProxyLink::vtkSMProxyLink ( )
◆ ~vtkSMProxyLink()
vtkSMProxyLink::~vtkSMProxyLink ( )
static vtkSMProxyLink* vtkSMProxyLink::New ( )
virtual const char* vtkSMProxyLink::GetClassName ( )
Reimplemented from vtkSMLink.
Reimplemented in vtkSMViewLink, and vtkSMCameraLink.
static int vtkSMProxyLink::IsTypeOf ( const char *  type)
virtual int vtkSMProxyLink::IsA ( const char *  type)
static vtkSMProxyLink* vtkSMProxyLink::SafeDownCast ( vtkObject *  o)
void vtkSMProxyLink::PrintSelf ( ostream &  os,
◆ AddLinkedProxy()
virtual void vtkSMProxyLink::AddLinkedProxy ( vtkSMProxy *  proxy,
int  updateDir
updateDir determines whether a property of the proxy is read or written. When a property of an input proxy changes, it's value is pushed to all other output proxies in the link. A proxy can be set to be both input and output by adding 2 link, one to INPUT and the other to OUTPUT
Reimplemented in vtkSMCameraLink, and vtkSMViewLink.
◆ LinkProxies()
virtual void vtkSMProxyLink::LinkProxies ( vtkSMProxy *  proxy1,
vtkSMProxy *  proxy2
This is equivalent to call 4 times AddLinkedProxy() with each combination.
◆ LinkProxyPropertyProxies()
virtual void vtkSMProxyLink::LinkProxyPropertyProxies ( vtkSMProxy *  proxy1,
vtkSMProxy *  proxy2,
const char *  pname
◆ RemoveLinkedProxy()
virtual void vtkSMProxyLink::RemoveLinkedProxy ( vtkSMProxy *  proxy)
◆ GetNumberOfLinkedObjects()
unsigned int vtkSMProxyLink::GetNumberOfLinkedObjects ( )
Implements vtkSMLink.
◆ GetNumberOfLinkedProxies()
unsigned int vtkSMProxyLink::GetNumberOfLinkedProxies ( )
◆ GetLinkedProxy()
vtkSMProxy* vtkSMProxyLink::GetLinkedProxy ( int  index)
◆ GetLinkedObjectDirection()
int vtkSMProxyLink::GetLinkedObjectDirection ( int  index)
◆ GetLinkedProxyDirection()
int vtkSMProxyLink::GetLinkedProxyDirection ( int  index)
◆ AddException()
void vtkSMProxyLink::AddException ( const char *  propertyname)
This method can be used to add/remove the names for such exception properties. If ExceptionBehavior is set to BLACKLIST (default), exceptions are excluded from synchronization. If ExceptionBehavior is set to WHITELIST, exceptions are the only one synchronized.
◆ RemoveException()
void vtkSMProxyLink::RemoveException ( const char *  propertyname)
◆ ClearExceptions()
void vtkSMProxyLink::ClearExceptions ( )
◆ RemoveAllLinks()
void vtkSMProxyLink::RemoveAllLinks ( )
Remove all links.
◆ LoadState()
void vtkSMProxyLink::LoadState ( const vtkSMMessage *  msg,
vtkSMProxyLocator *  locator
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented in vtkSMCameraLink.
◆ SetExceptionBehavior()
virtual void vtkSMProxyLink::SetExceptionBehavior ( int  )
The list can be a blacklist or a whitelist of proxy properties. Properties in the list will not be linked if behavior is set to BLACKLIST, or they will be the only ones linked if behavior is set to WHITELIST. Default: BLACKLIST.
◆ GetExceptionBehavior()
virtual int vtkSMProxyLink::GetExceptionBehavior ( )
◆ SetExceptionBehaviorToBlacklist()
void vtkSMProxyLink::SetExceptionBehaviorToBlacklist ( )
inline
Definition at line 123 of file vtkSMProxyLink.h.
◆ SetExceptionBehaviorToWhitelist()
void vtkSMProxyLink::SetExceptionBehaviorToWhitelist ( )
inline
Definition at line 124 of file vtkSMProxyLink.h.
◆ UpdateVTKObjects()
void vtkSMProxyLink::UpdateVTKObjects ( vtkSMProxy *  proxy)
overrideprotectedvirtual
Argument is the input proxy.
◆ PropertyModified()
void vtkSMProxyLink::PropertyModified ( vtkSMProxy *  proxy,
const char *  pname
caller:- the input proxy. pname:- name of the property being modified.
◆ UpdateProperty()
void vtkSMProxyLink::UpdateProperty ( vtkSMProxy *  caller,
const char *  pname
caller :- the input proxy. pname :- name of property that was pushed.
◆ GetXMLTagName()
virtual std::string vtkSMProxyLink::GetXMLTagName ( )
inlineprotectedvirtual
This should match the class name without "vtkSM" prefix. see vtkSMStateLoader::HandleLinks
Definition at line 156 of file vtkSMProxyLink.h.
◆ SaveXMLState()
void vtkSMProxyLink::SaveXMLState ( const char *  linkname,
vtkPVXMLElement *  parent
◆ LoadXMLState()
int vtkSMProxyLink::LoadXMLState ( vtkPVXMLElement *  linkElement,
◆ UpdateState()
void vtkSMProxyLink::UpdateState ( )
