vtkSMAnimationScene Class Reference
animation scene for ParaView. More...
#include <vtkSMAnimationScene.h>
Inheritance diagram for vtkSMAnimationScene:
Collaboration diagram for vtkSMAnimationScene:
enum  { UpdateStartEndTimesEvent = vtkCommand::UserEvent }
typedef vtkAnimationCue Superclass
- Public Types inherited from vtkAnimationCue
enum  TimeCodes
virtual double GetSceneTime ()
virtual void SetOverrideStillRender (bool)
 When set, we skip calling still render to render each frame. More...
virtual bool GetOverrideStillRender ()
void AddCue (vtkAnimationCue *cue)
 Add/Remove an AnimationCue to/from the Scene. More...
void RemoveCue (vtkAnimationCue *cue)
void RemoveAllCues ()
int GetNumberOfCues ()
void AddViewProxy (vtkSMViewProxy *proxy)
 Add view proxies that are involved in the animation generated by this scene. More...
void RemoveViewProxy (vtkSMViewProxy *proxy)
void RemoveAllViewProxies ()
unsigned int GetNumberOfViewProxies ()
 Access the view proxies. More...
vtkSMViewProxy * GetViewProxy (unsigned int cc)
void SetTimeKeeper (vtkSMProxy *)
 Set the time keeper. More...
virtual vtkSMProxy * GetTimeKeeper ()
virtual void SetLockStartTime (bool)
 Lock the start time. More...
virtual bool GetLockStartTime ()
virtual void LockStartTimeOn ()
virtual void LockStartTimeOff ()
virtual void SetLockEndTime (bool)
 Lock the end time. More...
virtual bool GetLockEndTime ()
virtual void LockEndTimeOn ()
virtual void LockEndTimeOff ()
void SetSceneTime (double time)
 Sets the current animation time. More...
virtual void SetPlaybackTimeWindow (double, double)
 Get/Set the Playback Window for this cue. More...
void SetPlaybackTimeWindow (double[2])
virtual double * GetPlaybackTimeWindow ()
virtual void GetPlaybackTimeWindow (double &, double &)
virtual void GetPlaybackTimeWindow (double[2])
void SetLoop (int val)
 Forwarded to vtkCompositeAnimationPlayer. More...
int GetLoop ()
void Play ()
void Reverse ()
void Stop ()
void GoToNext ()
void GoToPrevious ()
void GoToFirst ()
void GoToLast ()
void SetPlayMode (int val)
int GetPlayMode ()
void SetNumberOfFrames (int val)
void SetDuration (int val)
void SetFramesPerTimestep (int val)
void SetStride (int val)
virtual void SetForceDisableCaching (bool)
 Set to true to force caching to be disabled. More...
virtual bool GetForceDisableCaching ()
- Public Member Functions inherited from vtkAnimationCue
vtkAnimationCue * NewInstance () const
virtual void Tick (double currenttime, double deltatime, double clocktime)
virtual void Initialize ()
virtual void Finalize ()
virtual void SetTimeMode (int mode)
virtual int GetTimeMode ()
void SetTimeModeToRelative ()
void SetTimeModeToNormalized ()
virtual void SetStartTime (double)
virtual double GetStartTime ()
virtual void SetEndTime (double)
virtual double GetEndTime ()
virtual double GetAnimationTime ()
virtual double GetDeltaTime ()
virtual double GetClockTime ()
static vtkSMAnimationScene * New ()
static vtkSMAnimationScene * SafeDownCast (vtkObject *o)
static void SetGlobalUseGeometryCache (bool)
 Turn caching on/off globally. More...
static bool GetGlobalUseGeometryCache ()
- Static Public Member Functions inherited from vtkAnimationCue
static vtkAnimationCue * SafeDownCast (vtkObjectBase *o)
static vtkAnimationCue * New ()
 vtkSMAnimationScene ()
 ~vtkSMAnimationScene () override
void StartCueInternal () override
 Overridden to ensure that caching parameters are passed to the view correctly. More...
void TickInternal (double currenttime, double deltatime, double clocktime) override
void EndCueInternal () override
void TimeKeeperTimeRangeChanged ()
 Called when the timekeeper's time range changes. More...
void TimeKeeperTimestepsChanged ()
- Protected Member Functions inherited from vtkAnimationCue
 vtkAnimationCue ()
 ~vtkAnimationCue ()
bool LockStartTime
bool LockEndTime
bool InTick
double SceneTime
double PlaybackTimeWindow [2]
bool ForceDisableCaching
vtkSMProxy * TimeKeeper
vtkCompositeAnimationPlayer * AnimationPlayer
vtkEventForwarderCommand * Forwarder
bool OverrideStillRender
- Protected Attributes inherited from vtkAnimationCue
 UNINITIALIZED
 INACTIVE
 ACTIVE
double StartTime
double EndTime
int TimeMode
double AnimationTime
double DeltaTime
double ClockTime
int CueState
- Public Attributes inherited from vtkAnimationCue
 TIMEMODE_NORMALIZED
 TIMEMODE_RELATIVE
vtkSMAnimationScene extends vtkAnimationCue to add support for a scene in ParaView.
We don't use vtkAnimationScene since ParaView has more elaborate playback requirements. To support that, this class delegates playback responsibility to vtkAnimationPlayer and subclasses.
vtkSMAnimationScene also is proxy-aware and hence can work with proxies and views proxies for updating property values, rendering, etc.
vtkSMAnimationScene forwards the vtkCommand::StartEvent and vtkCommand::EndEvent from vtkCompositeAnimationPlayer to mark the start and end of animation playback.
Definition at line 34 of file vtkSMAnimationScene.h.
Definition at line 38 of file vtkSMAnimationScene.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 158 of file vtkSMAnimationScene.h.
◆ vtkSMAnimationScene()
vtkSMAnimationScene::vtkSMAnimationScene ( )
◆ ~vtkSMAnimationScene()
vtkSMAnimationScene::~vtkSMAnimationScene ( )
static vtkSMAnimationScene* vtkSMAnimationScene::New ( )
virtual const char* vtkSMAnimationScene::GetClassName ( )
static int vtkSMAnimationScene::IsTypeOf ( const char *  type)
virtual int vtkSMAnimationScene::IsA ( const char *  type)
Reimplemented from vtkAnimationCue.
static vtkSMAnimationScene* vtkSMAnimationScene::SafeDownCast ( vtkObject *  o)
void vtkSMAnimationScene::PrintSelf ( ostream &  os,
◆ AddCue()
void vtkSMAnimationScene::AddCue ( vtkAnimationCue *  cue)
It's an error to add a cue twice to the Scene.
◆ RemoveCue()
void vtkSMAnimationScene::RemoveCue ( vtkAnimationCue *  cue)
◆ RemoveAllCues()
void vtkSMAnimationScene::RemoveAllCues ( )
◆ GetNumberOfCues()
int vtkSMAnimationScene::GetNumberOfCues ( )
◆ AddViewProxy()
void vtkSMAnimationScene::AddViewProxy ( vtkSMViewProxy *  proxy)
When playing the animation, the scene will call StillRender() on the view proxies it is aware of, also updating any caching parameters.
◆ RemoveViewProxy()
void vtkSMAnimationScene::RemoveViewProxy ( vtkSMViewProxy *  proxy)
◆ RemoveAllViewProxies()
void vtkSMAnimationScene::RemoveAllViewProxies ( )
◆ GetNumberOfViewProxies()
unsigned int vtkSMAnimationScene::GetNumberOfViewProxies ( )
◆ GetViewProxy()
vtkSMViewProxy* vtkSMAnimationScene::GetViewProxy ( unsigned int  cc)
◆ SetTimeKeeper()
void vtkSMAnimationScene::SetTimeKeeper ( vtkSMProxy *  )
Time keeper is used to obtain the information about timesteps. This is required to play animation in "Snap To Timesteps" mode.
◆ GetTimeKeeper()
virtual vtkSMProxy* vtkSMAnimationScene::GetTimeKeeper ( )
◆ SetLockStartTime()
virtual void vtkSMAnimationScene::SetLockStartTime ( bool  )
When locked, the StartTime won't be automatically updated when data time changes.
◆ GetLockStartTime()
virtual bool vtkSMAnimationScene::GetLockStartTime ( )
◆ LockStartTimeOn()
virtual void vtkSMAnimationScene::LockStartTimeOn ( )
◆ LockStartTimeOff()
virtual void vtkSMAnimationScene::LockStartTimeOff ( )
◆ SetLockEndTime()
virtual void vtkSMAnimationScene::SetLockEndTime ( bool  )
Lock the end time.
When locked, the EndTime won't be automatically updated when the data time changes.
◆ GetLockEndTime()
virtual bool vtkSMAnimationScene::GetLockEndTime ( )
Lock the end time.
◆ LockEndTimeOn()
virtual void vtkSMAnimationScene::LockEndTimeOn ( )
Lock the end time.
◆ LockEndTimeOff()
virtual void vtkSMAnimationScene::LockEndTimeOff ( )
Lock the end time.
◆ SetSceneTime()
void vtkSMAnimationScene::SetSceneTime ( double  time)
inline
Definition at line 104 of file vtkSMAnimationScene.h.
◆ GetSceneTime()
virtual double vtkSMAnimationScene::GetSceneTime ( )
◆ SetPlaybackTimeWindow() [1/2]
virtual void vtkSMAnimationScene::SetPlaybackTimeWindow ( double  ,
double
The Playback Window is use to mask out time that belong to a given cue but that we don't want to play back. This is particularly useful when we want to export a subset of an animation without recomputing any start and end value relative to the cue and the number of frame associated to it. This is used by the Animation Player to only play a subset of the cue. To disable it just make the lower bound bigger than the upper one.
◆ SetPlaybackTimeWindow() [2/2]
void vtkSMAnimationScene::SetPlaybackTimeWindow ( double  [2])
◆ GetPlaybackTimeWindow() [1/3]
virtual double* vtkSMAnimationScene::GetPlaybackTimeWindow ( )
◆ GetPlaybackTimeWindow() [2/3]
virtual void vtkSMAnimationScene::GetPlaybackTimeWindow ( double &  ,
double &
◆ GetPlaybackTimeWindow() [3/3]
virtual void vtkSMAnimationScene::GetPlaybackTimeWindow ( double  [2])
◆ SetLoop()
void vtkSMAnimationScene::SetLoop ( int  val)
◆ GetLoop()
int vtkSMAnimationScene::GetLoop ( )
◆ Play()
void vtkSMAnimationScene::Play ( )
◆ Reverse()
void vtkSMAnimationScene::Reverse ( )
◆ Stop()
void vtkSMAnimationScene::Stop ( )
◆ GoToNext()
void vtkSMAnimationScene::GoToNext ( )
◆ GoToPrevious()
void vtkSMAnimationScene::GoToPrevious ( )
◆ GoToFirst()
void vtkSMAnimationScene::GoToFirst ( )
◆ GoToLast()
void vtkSMAnimationScene::GoToLast ( )
◆ SetPlayMode()
void vtkSMAnimationScene::SetPlayMode ( int  val)
◆ GetPlayMode()
int vtkSMAnimationScene::GetPlayMode ( )
◆ SetNumberOfFrames()
void vtkSMAnimationScene::SetNumberOfFrames ( int  val)
◆ SetDuration()
void vtkSMAnimationScene::SetDuration ( int  val)
◆ SetFramesPerTimestep()
void vtkSMAnimationScene::SetFramesPerTimestep ( int  val)
◆ SetStride()
void vtkSMAnimationScene::SetStride ( int  val)
◆ SetForceDisableCaching()
virtual void vtkSMAnimationScene::SetForceDisableCaching ( bool  )
When false (default), caching is determined based on the value from vtkPVGeneralSettings::GetInstance()->GetCacheGeometryForAnimation().
◆ GetForceDisableCaching()
virtual bool vtkSMAnimationScene::GetForceDisableCaching ( )
◆ SetOverrideStillRender()
virtual void vtkSMAnimationScene::SetOverrideStillRender ( bool  )
Useful to avoid updating screen when saving animations to disk, for example.
◆ GetOverrideStillRender()
virtual bool vtkSMAnimationScene::GetOverrideStillRender ( )
◆ SetGlobalUseGeometryCache()
static void vtkSMAnimationScene::SetGlobalUseGeometryCache ( bool  )
Typically, on uses vtkPVGeneralSettings to toggle cache settings rather than using this API directly.
◆ GetGlobalUseGeometryCache()
static bool vtkSMAnimationScene::GetGlobalUseGeometryCache ( )
◆ StartCueInternal()
void vtkSMAnimationScene::StartCueInternal ( )
overrideprotectedvirtual
◆ TickInternal()
void vtkSMAnimationScene::TickInternal ( double  currenttime,
double  deltatime,
double  clocktime
◆ EndCueInternal()
void vtkSMAnimationScene::EndCueInternal ( )
◆ TimeKeeperTimeRangeChanged()
void vtkSMAnimationScene::TimeKeeperTimeRangeChanged ( )
◆ TimeKeeperTimestepsChanged()
void vtkSMAnimationScene::TimeKeeperTimestepsChanged ( )
◆ LockStartTime
bool vtkSMAnimationScene::LockStartTime
Definition at line 215 of file vtkSMAnimationScene.h.
◆ LockEndTime
bool vtkSMAnimationScene::LockEndTime
Definition at line 216 of file vtkSMAnimationScene.h.
◆ InTick
bool vtkSMAnimationScene::InTick
Definition at line 217 of file vtkSMAnimationScene.h.
◆ SceneTime
double vtkSMAnimationScene::SceneTime
Definition at line 218 of file vtkSMAnimationScene.h.
◆ PlaybackTimeWindow
double vtkSMAnimationScene::PlaybackTimeWindow[2]
Definition at line 219 of file vtkSMAnimationScene.h.
◆ ForceDisableCaching
bool vtkSMAnimationScene::ForceDisableCaching
Definition at line 220 of file vtkSMAnimationScene.h.
◆ TimeKeeper
vtkSMProxy* vtkSMAnimationScene::TimeKeeper
Definition at line 221 of file vtkSMAnimationScene.h.
◆ AnimationPlayer
vtkCompositeAnimationPlayer* vtkSMAnimationScene::AnimationPlayer
Definition at line 222 of file vtkSMAnimationScene.h.
◆ Forwarder
vtkEventForwarderCommand* vtkSMAnimationScene::Forwarder
Definition at line 223 of file vtkSMAnimationScene.h.
◆ OverrideStillRender
bool vtkSMAnimationScene::OverrideStillRender
Definition at line 225 of file vtkSMAnimationScene.h.
