vtkPVGeneralSettings Class Reference
object for general options. More...
#include <vtkPVGeneralSettings.h>
Inheritance diagram for vtkPVGeneralSettings:
Collaboration diagram for vtkPVGeneralSettings:
enum  { DEFAULT_TIME_STEP_UNCHANGED, DEFAULT_TIME_STEP_FIRST, DEFAULT_TIME_STEP_LAST }
 Enum for DefaultTimeStep. More...
enum  RealNumberNotation { MIXED = 0, SCIENTIFIC, FIXED, FULL }
enum  { ALL_IN_ONE = 0, SEPARATE_DISPLAY_PROPERTIES = 1, SEPARATE_VIEW_PROPERTIES = 2, ALL_SEPARATE = 3 }
void SetInheritRepresentationProperties (bool val)
 Forwarded for vtkSMParaViewPipelineControllerWithRendering. More...
void SetIgnoreNegativeLogAxisWarning (bool val)
bool GetIgnoreNegativeLogAxisWarning ()
void SetAutoConvertProperties (bool val)
 Automatically convert data arrays as needed by filters including converting cell arrays to point arrays, or vice versa, and extracting single components from multi-component arrays. More...
bool GetAutoConvertProperties ()
virtual int GetBlockColorsDistinctValues ()
 Determines the number of distinct values in vtkBlockColors. More...
virtual void SetBlockColorsDistinctValues (int)
virtual bool GetAutoApply ()
 Automatically apply changes in the 'Properties' panel. More...
virtual void SetAutoApply (bool)
virtual int GetAutoApplyDelay ()
 Get/Set delay for auto apply. More...
virtual void SetAutoApplyDelay (int)
virtual bool GetAutoApplyActiveOnly ()
virtual void SetAutoApplyActiveOnly (bool)
virtual std::string GetDefaultViewType ()
 Get/Set the default view type. More...
virtual void SetDefaultViewType (std::string)
virtual std::string GetInterfaceLanguage ()
 Get/Set the default interface language. More...
virtual void SetInterfaceLanguage (std::string)
void SetCacheGeometryForAnimation (bool val)
 Set when animation geometry caching is enabled. More...
bool GetCacheGeometryForAnimation ()
void SetAnimationGeometryCacheLimit (unsigned long val)
 Set the animation cache limit in KBs. More...
virtual unsigned long GetAnimationGeometryCacheLimit ()
virtual void SetAnimationTimeNotation (int)
 Set the notation for the animation time toolbar. More...
virtual int GetAnimationTimeNotation ()
virtual void SetAnimationTimeShortestAccuratePrecision (bool)
 Get/Set the usage of shortest accurate precision instead of actual precision for animation time. More...
virtual bool GetAnimationTimeShortestAccuratePrecision ()
virtual void SetAnimationTimePrecision (int)
 Set the precision of the animation time toolbar. More...
virtual int GetAnimationTimePrecision ()
virtual void SetShowAnimationShortcuts (bool)
 Set when animation shortcuts are shown. More...
virtual bool GetShowAnimationShortcuts ()
virtual void ShowAnimationShortcutsOn ()
virtual void ShowAnimationShortcutsOff ()
virtual void SetResetDisplayEmptyViews (bool)
 Set whether to reset display when showing a representation in an empty view. More...
virtual bool GetResetDisplayEmptyViews ()
virtual void ResetDisplayEmptyViewsOn ()
virtual void ResetDisplayEmptyViewsOff ()
virtual void SetRealNumberDisplayedNotation (int)
 Get/Set the notation of real number displayed in widgets or views. More...
virtual int GetRealNumberDisplayedNotation ()
virtual void SetRealNumberDisplayedShortestAccuratePrecision (bool)
 Get/Set the usage of shortest accurate precision instead of actual precision for real numbers. More...
virtual bool GetRealNumberDisplayedShortestAccuratePrecision ()
virtual void SetRealNumberDisplayedPrecision (int)
 Get/Set the precision of real number displayed in widgets or views. More...
virtual int GetRealNumberDisplayedPrecision ()
virtual void SetFullNotationLowExponent (int)
 Get/Set the low exponent used with full notation. More...
virtual int GetFullNotationLowExponent ()
virtual void SetFullNotationHighExponent (int)
 Get/Set the high exponent used with full notation. More...
virtual int GetFullNotationHighExponent ()
virtual void SetPropertiesPanelMode (int)
 Properties panel configuration. More...
virtual int GetPropertiesPanelMode ()
virtual void SetLockPanels (bool)
 Set whether to dock widgets into place. More...
virtual bool GetLockPanels ()
void SetLoadAllVariables (bool val)
 Load all variables when loading a data set. More...
bool GetLoadAllVariables ()
void SetLoadNoChartVariables (bool val)
 Load no variables when showing a 2D chart. More...
bool GetLoadNoChartVariables ()
virtual void SetGUIFontSize (int)
 Get/Set the GUI font size. More...
virtual int GetGUIFontSize ()
virtual void SetGUIOverrideFont (bool)
 Get/Set whether the GUIFontSize should be used. More...
virtual bool GetGUIOverrideFont ()
void SetConsoleFontSize (int vtkNotUsed(val))
 This method has no effect and should not be used. More...
int GetConsoleFontSize ()
virtual void SetColorByBlockColorsOnApply (bool)
 Automatically color by vtkBlockColors if array is present on Apply. More...
virtual bool GetColorByBlockColorsOnApply ()
void SetEnableStreaming (bool)
 Turn on streamed rendering. More...
virtual bool GetEnableStreaming ()
virtual void EnableStreamingOn ()
virtual void EnableStreamingOff ()
void SetUseAcceleratedFilters (bool)
 Enable use of accelerated filters where available. More...
bool GetUseAcceleratedFilters ()
virtual void UseAcceleratedFiltersOn ()
virtual void UseAcceleratedFiltersOff ()
virtual bool GetSelectOnClickMultiBlockInspector ()
 ActiveSelection is hooked up in the MultiBlock Inspector such that a click on a/multiple block(s) selects it/them. More...
virtual void SetSelectOnClickMultiBlockInspector (bool)
static vtkPVGeneralSettings * New ()
static vtkPVGeneralSettings * SafeDownCast (vtkObject *o)
static vtkPVGeneralSettings * GetInstance ()
 Access the singleton. More...
static int GetNumberOfCallbackThreads ()
 Sets the number of threads that are used for vtkPVSession::ThreadedCallbackQueue. More...
static void SetNumberOfCallbackThreads (int)
 vtkPVGeneralSettings ()=default
 ~vtkPVGeneralSettings () override=default
int BlockColorsDistinctValues = 7
bool AutoApply = false
int AutoApplyDelay = 0
bool AutoApplyActiveOnly = false
std::string DefaultViewType = "RenderView"
std::string InterfaceLanguage = "en"
int ScalarBarMode = AUTOMATICALLY_HIDE_SCALAR_BARS
bool CacheGeometryForAnimation = false
unsigned long AnimationGeometryCacheLimit = 0
int AnimationTimeNotation = MIXED
bool AnimationTimeShortestAccuratePrecision = false
int AnimationTimePrecision = 6
bool ShowAnimationShortcuts = false
int RealNumberDisplayedNotation = MIXED
bool RealNumberDisplayedShortestAccuratePrecision = false
int RealNumberDisplayedPrecision = 6
int FullNotationLowExponent = -6
int FullNotationHighExponent = 20
bool ResetDisplayEmptyViews = false
int PropertiesPanelMode = ALL_IN_ONE
bool LockPanels = false
int GUIFontSize = 0
bool GUIOverrideFont = false
bool ColorByBlockColorsOnApply = true
bool EnableStreaming = false
bool SelectOnClickMultiBlockInspector = true
enum  { AUTOMATICALLY_SHOW_AND_HIDE_SCALAR_BARS = 0, AUTOMATICALLY_HIDE_SCALAR_BARS = 1, MANUAL_SCALAR_BARS = 2 }
 Enum for ScalarBarMode. More...
virtual int GetScalarBarMode ()
void SetScalarBarMode (int)
vtkPVGeneralSettings keeps track of general options in a ParaView application. This is a singleton. All calls to vtkPVGeneralSettings::New() return a pointer to the same global instance (with reference count incremented as expected).
Definition at line 24 of file vtkPVGeneralSettings.h.
Definition at line 28 of file vtkPVGeneralSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 106 of file vtkPVGeneralSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
MANUAL_SCALAR_BARS
Definition at line 117 of file vtkPVGeneralSettings.h.
◆ RealNumberNotation
Enumerator
MIXED
SCIENTIFIC
FIXED
FULL
Definition at line 143 of file vtkPVGeneralSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
ALL_IN_ONE
ALL_SEPARATE
Definition at line 246 of file vtkPVGeneralSettings.h.
◆ vtkPVGeneralSettings()
vtkPVGeneralSettings::vtkPVGeneralSettings ( )
protecteddefault
◆ ~vtkPVGeneralSettings()
vtkPVGeneralSettings::~vtkPVGeneralSettings ( )
overrideprotecteddefault
static vtkPVGeneralSettings* vtkPVGeneralSettings::New ( )
virtual const char* vtkPVGeneralSettings::GetClassName ( )
static int vtkPVGeneralSettings::IsTypeOf ( const char *  type)
virtual int vtkPVGeneralSettings::IsA ( const char *  type)
static vtkPVGeneralSettings* vtkPVGeneralSettings::SafeDownCast ( vtkObject *  o)
void vtkPVGeneralSettings::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkPVGeneralSettings* vtkPVGeneralSettings::GetInstance ( )
◆ SetAutoConvertProperties()
void vtkPVGeneralSettings::SetAutoConvertProperties ( bool  val)
Forwards the call to vtkSMInputArrayDomain::SetAutomaticPropertyConversion.
◆ GetAutoConvertProperties()
bool vtkPVGeneralSettings::GetAutoConvertProperties ( )
◆ GetBlockColorsDistinctValues()
virtual int vtkPVGeneralSettings::GetBlockColorsDistinctValues ( )
This array is added to each block if the dataset is a composite dataset. The array has one value set to (blockIndex % BlockColorsDistinctValues)
◆ SetBlockColorsDistinctValues()
virtual void vtkPVGeneralSettings::SetBlockColorsDistinctValues ( int  )
◆ GetAutoApply()
virtual bool vtkPVGeneralSettings::GetAutoApply ( )
Default is false.
◆ SetAutoApply()
virtual void vtkPVGeneralSettings::SetAutoApply ( bool  )
Default is false.
◆ GetAutoApplyDelay()
virtual int vtkPVGeneralSettings::GetAutoApplyDelay ( )
Not exposed in the UI. Default is 0.
◆ SetAutoApplyDelay()
virtual void vtkPVGeneralSettings::SetAutoApplyDelay ( int  )
◆ GetAutoApplyActiveOnly()
virtual bool vtkPVGeneralSettings::GetAutoApplyActiveOnly ( )
Default is false.
◆ SetAutoApplyActiveOnly()
virtual void vtkPVGeneralSettings::SetAutoApplyActiveOnly ( bool  )
Default is false.
◆ GetDefaultViewType()
virtual std::string vtkPVGeneralSettings::GetDefaultViewType ( )
◆ SetDefaultViewType()
virtual void vtkPVGeneralSettings::SetDefaultViewType ( std::string  )
◆ GetInterfaceLanguage()
virtual std::string vtkPVGeneralSettings::GetInterfaceLanguage ( )
Default is en
◆ SetInterfaceLanguage()
virtual void vtkPVGeneralSettings::SetInterfaceLanguage ( std::string  )
Default is en
◆ GetScalarBarMode()
virtual int vtkPVGeneralSettings::GetScalarBarMode ( )
◆ SetScalarBarMode()
void vtkPVGeneralSettings::SetScalarBarMode ( int  )
◆ SetCacheGeometryForAnimation()
void vtkPVGeneralSettings::SetCacheGeometryForAnimation ( bool  val)
◆ GetCacheGeometryForAnimation()
bool vtkPVGeneralSettings::GetCacheGeometryForAnimation ( )
◆ SetAnimationGeometryCacheLimit()
void vtkPVGeneralSettings::SetAnimationGeometryCacheLimit ( unsigned long  val)
◆ GetAnimationGeometryCacheLimit()
virtual unsigned long vtkPVGeneralSettings::GetAnimationGeometryCacheLimit ( )
◆ SetAnimationTimeNotation()
virtual void vtkPVGeneralSettings::SetAnimationTimeNotation ( int  )
Accepted values are MIXED, SCIENTIFIC, and FIXED.
◆ GetAnimationTimeNotation()
virtual int vtkPVGeneralSettings::GetAnimationTimeNotation ( )
◆ SetAnimationTimeShortestAccuratePrecision()
virtual void vtkPVGeneralSettings::SetAnimationTimeShortestAccuratePrecision ( bool  )
◆ GetAnimationTimeShortestAccuratePrecision()
virtual bool vtkPVGeneralSettings::GetAnimationTimeShortestAccuratePrecision ( )
◆ SetAnimationTimePrecision()
virtual void vtkPVGeneralSettings::SetAnimationTimePrecision ( int  )
◆ GetAnimationTimePrecision()
virtual int vtkPVGeneralSettings::GetAnimationTimePrecision ( )
◆ SetShowAnimationShortcuts()
virtual void vtkPVGeneralSettings::SetShowAnimationShortcuts ( bool  )
◆ GetShowAnimationShortcuts()
virtual bool vtkPVGeneralSettings::GetShowAnimationShortcuts ( )
◆ ShowAnimationShortcutsOn()
virtual void vtkPVGeneralSettings::ShowAnimationShortcutsOn ( )
◆ ShowAnimationShortcutsOff()
virtual void vtkPVGeneralSettings::ShowAnimationShortcutsOff ( )
◆ SetResetDisplayEmptyViews()
virtual void vtkPVGeneralSettings::SetResetDisplayEmptyViews ( bool  )
◆ GetResetDisplayEmptyViews()
virtual bool vtkPVGeneralSettings::GetResetDisplayEmptyViews ( )
◆ ResetDisplayEmptyViewsOn()
virtual void vtkPVGeneralSettings::ResetDisplayEmptyViewsOn ( )
◆ ResetDisplayEmptyViewsOff()
virtual void vtkPVGeneralSettings::ResetDisplayEmptyViewsOff ( )
◆ SetRealNumberDisplayedNotation()
virtual void vtkPVGeneralSettings::SetRealNumberDisplayedNotation ( int  )
◆ GetRealNumberDisplayedNotation()
virtual int vtkPVGeneralSettings::GetRealNumberDisplayedNotation ( )
◆ SetRealNumberDisplayedShortestAccuratePrecision()
virtual void vtkPVGeneralSettings::SetRealNumberDisplayedShortestAccuratePrecision ( bool  )
◆ GetRealNumberDisplayedShortestAccuratePrecision()
virtual bool vtkPVGeneralSettings::GetRealNumberDisplayedShortestAccuratePrecision ( )
◆ SetRealNumberDisplayedPrecision()
virtual void vtkPVGeneralSettings::SetRealNumberDisplayedPrecision ( int  )
◆ GetRealNumberDisplayedPrecision()
virtual int vtkPVGeneralSettings::GetRealNumberDisplayedPrecision ( )
◆ SetFullNotationLowExponent()
virtual void vtkPVGeneralSettings::SetFullNotationLowExponent ( int  )
◆ GetFullNotationLowExponent()
virtual int vtkPVGeneralSettings::GetFullNotationLowExponent ( )
◆ SetFullNotationHighExponent()
virtual void vtkPVGeneralSettings::SetFullNotationHighExponent ( int  )
◆ GetFullNotationHighExponent()
virtual int vtkPVGeneralSettings::GetFullNotationHighExponent ( )
◆ SetInheritRepresentationProperties()
void vtkPVGeneralSettings::SetInheritRepresentationProperties ( bool  val)
◆ SetIgnoreNegativeLogAxisWarning()
void vtkPVGeneralSettings::SetIgnoreNegativeLogAxisWarning ( bool  val)
◆ GetIgnoreNegativeLogAxisWarning()
bool vtkPVGeneralSettings::GetIgnoreNegativeLogAxisWarning ( )
◆ SetPropertiesPanelMode()
virtual void vtkPVGeneralSettings::SetPropertiesPanelMode ( int  )
◆ GetPropertiesPanelMode()
virtual int vtkPVGeneralSettings::GetPropertiesPanelMode ( )
◆ SetLockPanels()
virtual void vtkPVGeneralSettings::SetLockPanels ( bool  )
◆ GetLockPanels()
virtual bool vtkPVGeneralSettings::GetLockPanels ( )
◆ SetLoadAllVariables()
void vtkPVGeneralSettings::SetLoadAllVariables ( bool  val)
◆ GetLoadAllVariables()
bool vtkPVGeneralSettings::GetLoadAllVariables ( )
◆ SetLoadNoChartVariables()
void vtkPVGeneralSettings::SetLoadNoChartVariables ( bool  val)
◆ GetLoadNoChartVariables()
bool vtkPVGeneralSettings::GetLoadNoChartVariables ( )
◆ SetGUIFontSize()
virtual void vtkPVGeneralSettings::SetGUIFontSize ( int  )
This is used only if GUIOverrideFont is true.
◆ GetGUIFontSize()
virtual int vtkPVGeneralSettings::GetGUIFontSize ( )
◆ SetGUIOverrideFont()
virtual void vtkPVGeneralSettings::SetGUIOverrideFont ( bool  )
◆ GetGUIOverrideFont()
virtual bool vtkPVGeneralSettings::GetGUIOverrideFont ( )
◆ SetConsoleFontSize()
void vtkPVGeneralSettings::SetConsoleFontSize ( int   vtkNotUsedval)
inline
Definition at line 306 of file vtkPVGeneralSettings.h.
◆ GetConsoleFontSize()
int vtkPVGeneralSettings::GetConsoleFontSize ( )
inline
Definition at line 308 of file vtkPVGeneralSettings.h.
◆ SetColorByBlockColorsOnApply()
virtual void vtkPVGeneralSettings::SetColorByBlockColorsOnApply ( bool  )
◆ GetColorByBlockColorsOnApply()
virtual bool vtkPVGeneralSettings::GetColorByBlockColorsOnApply ( )
◆ SetEnableStreaming()
void vtkPVGeneralSettings::SetEnableStreaming ( bool  )
◆ GetEnableStreaming()
virtual bool vtkPVGeneralSettings::GetEnableStreaming ( )
◆ EnableStreamingOn()
virtual void vtkPVGeneralSettings::EnableStreamingOn ( )
◆ EnableStreamingOff()
virtual void vtkPVGeneralSettings::EnableStreamingOff ( )
◆ SetUseAcceleratedFilters()
void vtkPVGeneralSettings::SetUseAcceleratedFilters ( bool  )
◆ GetUseAcceleratedFilters()
bool vtkPVGeneralSettings::GetUseAcceleratedFilters ( )
◆ UseAcceleratedFiltersOn()
virtual void vtkPVGeneralSettings::UseAcceleratedFiltersOn ( )
◆ UseAcceleratedFiltersOff()
virtual void vtkPVGeneralSettings::UseAcceleratedFiltersOff ( )
◆ GetSelectOnClickMultiBlockInspector()
virtual bool vtkPVGeneralSettings::GetSelectOnClickMultiBlockInspector ( )
Default is true.
◆ SetSelectOnClickMultiBlockInspector()
virtual void vtkPVGeneralSettings::SetSelectOnClickMultiBlockInspector ( bool  )
Default is true.
◆ GetNumberOfCallbackThreads()
static int vtkPVGeneralSettings::GetNumberOfCallbackThreads ( )
◆ SetNumberOfCallbackThreads()
static void vtkPVGeneralSettings::SetNumberOfCallbackThreads ( int  )
◆ BlockColorsDistinctValues
int vtkPVGeneralSettings::BlockColorsDistinctValues = 7
Definition at line 358 of file vtkPVGeneralSettings.h.
◆ AutoApply
bool vtkPVGeneralSettings::AutoApply = false
Definition at line 359 of file vtkPVGeneralSettings.h.
◆ AutoApplyDelay
int vtkPVGeneralSettings::AutoApplyDelay = 0
Definition at line 360 of file vtkPVGeneralSettings.h.
◆ AutoApplyActiveOnly
bool vtkPVGeneralSettings::AutoApplyActiveOnly = false
Definition at line 361 of file vtkPVGeneralSettings.h.
◆ DefaultViewType
std::string vtkPVGeneralSettings::DefaultViewType = "RenderView"
Definition at line 362 of file vtkPVGeneralSettings.h.
◆ InterfaceLanguage
std::string vtkPVGeneralSettings::InterfaceLanguage = "en"
Definition at line 363 of file vtkPVGeneralSettings.h.
◆ ScalarBarMode
int vtkPVGeneralSettings::ScalarBarMode = AUTOMATICALLY_HIDE_SCALAR_BARS
Definition at line 364 of file vtkPVGeneralSettings.h.
◆ CacheGeometryForAnimation
bool vtkPVGeneralSettings::CacheGeometryForAnimation = false
Definition at line 365 of file vtkPVGeneralSettings.h.
◆ AnimationGeometryCacheLimit
unsigned long vtkPVGeneralSettings::AnimationGeometryCacheLimit = 0
Definition at line 366 of file vtkPVGeneralSettings.h.
◆ AnimationTimeNotation
int vtkPVGeneralSettings::AnimationTimeNotation = MIXED
Definition at line 367 of file vtkPVGeneralSettings.h.
◆ AnimationTimeShortestAccuratePrecision
bool vtkPVGeneralSettings::AnimationTimeShortestAccuratePrecision = false
Definition at line 368 of file vtkPVGeneralSettings.h.
◆ AnimationTimePrecision
int vtkPVGeneralSettings::AnimationTimePrecision = 6
Definition at line 369 of file vtkPVGeneralSettings.h.
bool vtkPVGeneralSettings::ShowAnimationShortcuts = false
Definition at line 370 of file vtkPVGeneralSettings.h.
◆ RealNumberDisplayedNotation
int vtkPVGeneralSettings::RealNumberDisplayedNotation = MIXED
Definition at line 371 of file vtkPVGeneralSettings.h.
◆ RealNumberDisplayedShortestAccuratePrecision
bool vtkPVGeneralSettings::RealNumberDisplayedShortestAccuratePrecision = false
Definition at line 372 of file vtkPVGeneralSettings.h.
◆ RealNumberDisplayedPrecision
int vtkPVGeneralSettings::RealNumberDisplayedPrecision = 6
Definition at line 373 of file vtkPVGeneralSettings.h.
◆ FullNotationLowExponent
int vtkPVGeneralSettings::FullNotationLowExponent = -6
Definition at line 374 of file vtkPVGeneralSettings.h.
◆ FullNotationHighExponent
int vtkPVGeneralSettings::FullNotationHighExponent = 20
Definition at line 375 of file vtkPVGeneralSettings.h.
bool vtkPVGeneralSettings::ResetDisplayEmptyViews = false
Definition at line 376 of file vtkPVGeneralSettings.h.
◆ PropertiesPanelMode
int vtkPVGeneralSettings::PropertiesPanelMode = ALL_IN_ONE
Definition at line 377 of file vtkPVGeneralSettings.h.
◆ LockPanels
bool vtkPVGeneralSettings::LockPanels = false
Definition at line 378 of file vtkPVGeneralSettings.h.
◆ GUIFontSize
int vtkPVGeneralSettings::GUIFontSize = 0
Definition at line 379 of file vtkPVGeneralSettings.h.
◆ GUIOverrideFont
bool vtkPVGeneralSettings::GUIOverrideFont = false
Definition at line 380 of file vtkPVGeneralSettings.h.
◆ ColorByBlockColorsOnApply
bool vtkPVGeneralSettings::ColorByBlockColorsOnApply = true
Definition at line 381 of file vtkPVGeneralSettings.h.
◆ EnableStreaming
bool vtkPVGeneralSettings::EnableStreaming = false
Definition at line 382 of file vtkPVGeneralSettings.h.
◆ SelectOnClickMultiBlockInspector
bool vtkPVGeneralSettings::SelectOnClickMultiBlockInspector = true
Definition at line 383 of file vtkPVGeneralSettings.h.
