vtkCompositeAnimationPlayer Class Reference
#include <vtkCompositeAnimationPlayer.h>
Inheritance diagram for vtkCompositeAnimationPlayer:
Collaboration diagram for vtkCompositeAnimationPlayer:
enum  Modes { SEQUENCE = 0, SNAP_TO_TIMESTEPS = 2 }
typedef vtkAnimationPlayer Superclass
- Public Types inherited from vtkAnimationPlayer
void SetNumberOfFrames (int val)
 Forwarded to vtkSequenceAnimationPlayer. More...
void SetDuration (int val)
 Forwarded to vtkRealtimeAnimationPlayer. More...
virtual void SetPlayMode (int)
 Get/Set the play mode. More...
virtual int GetPlayMode ()
void AddTimeStep (double val)
 Forwarded to vtkTimestepsAnimationPlayer. More...
void RemoveAllTimeSteps ()
void SetFramesPerTimestep (int val)
void SetStride (int _val) override
 Forwarded to vtkTimestepsAnimationPlayer.and vtkSequenceAnimationPlayer. More...
- Public Member Functions inherited from vtkAnimationPlayer
void Play (int dir=1)
 Start playing the animation. More...
void Stop ()
 Stop playing the animation. More...
int IsInPlay ()
 Returns if the animation is currently playing. More...
virtual bool GetInPlay ()
void GoToNext ()
 Take the animation scene to next frame. More...
void GoToPrevious ()
 Take animation scene to previous frame. More...
void GoToFirst ()
 Take animation scene to first frame. More...
void GoToLast ()
 Take animation scene to last frame. More...
virtual void SetAnimationScene (vtkSMAnimationScene *)
 Set the animation scene that is to be played by this player. More...
vtkSMAnimationScene * GetAnimationScene ()
virtual void SetLoop (bool)
 Set to true to play the animation in a loop. More...
virtual bool GetLoop ()
virtual int GetStride ()
 Get/Set the stride value fot the animation player. More...
static vtkCompositeAnimationPlayer * New ()
static vtkCompositeAnimationPlayer * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAnimationPlayer
static vtkAnimationPlayer * SafeDownCast (vtkObject *o)
 vtkCompositeAnimationPlayer ()
 ~vtkCompositeAnimationPlayer () override
vtkAnimationPlayer * GetActivePlayer ()
void StartLoop (double starttime, double endtime, double curtime, double *playbackWindow) override
 Delegated to the active animation player. More...
void EndLoop () override
double GetNextTime (double currentime) override
double GetPreviousTime (double currenttime) override
double GoToNext (double start, double end, double currenttime) override
double GoToPrevious (double start, double end, double currenttime) override
- Protected Member Functions inherited from vtkAnimationPlayer
 vtkAnimationPlayer ()
 ~vtkAnimationPlayer () override
vtkSequenceAnimationPlayer * SequenceAnimationPlayer
vtkTimestepsAnimationPlayer * TimestepsAnimationPlayer
int PlayMode
This is composite animation player that can me made to play an animation using the active player. It provides API to add animation players and then set one of them as the active one.
Definition at line 22 of file vtkCompositeAnimationPlayer.h.
Definition at line 26 of file vtkCompositeAnimationPlayer.h.
◆ Modes
Enumerator
SEQUENCE
SNAP_TO_TIMESTEPS
Definition at line 29 of file vtkCompositeAnimationPlayer.h.
◆ vtkCompositeAnimationPlayer()
vtkCompositeAnimationPlayer::vtkCompositeAnimationPlayer ( )
◆ ~vtkCompositeAnimationPlayer()
vtkCompositeAnimationPlayer::~vtkCompositeAnimationPlayer ( )
static vtkCompositeAnimationPlayer* vtkCompositeAnimationPlayer::New ( )
virtual const char* vtkCompositeAnimationPlayer::GetClassName ( )
Reimplemented from vtkAnimationPlayer.
static int vtkCompositeAnimationPlayer::IsTypeOf ( const char *  type)
virtual int vtkCompositeAnimationPlayer::IsA ( const char *  type)
static vtkCompositeAnimationPlayer* vtkCompositeAnimationPlayer::SafeDownCast ( vtkObject *  o)
void vtkCompositeAnimationPlayer::PrintSelf ( ostream &  os,
◆ SetPlayMode()
virtual void vtkCompositeAnimationPlayer::SetPlayMode ( int  )
◆ GetPlayMode()
virtual int vtkCompositeAnimationPlayer::GetPlayMode ( )
◆ SetNumberOfFrames()
void vtkCompositeAnimationPlayer::SetNumberOfFrames ( int  val)
◆ SetDuration()
void vtkCompositeAnimationPlayer::SetDuration ( int  val)
◆ AddTimeStep()
void vtkCompositeAnimationPlayer::AddTimeStep ( double  val)
◆ RemoveAllTimeSteps()
void vtkCompositeAnimationPlayer::RemoveAllTimeSteps ( )
◆ SetFramesPerTimestep()
void vtkCompositeAnimationPlayer::SetFramesPerTimestep ( int  val)
◆ SetStride()
void vtkCompositeAnimationPlayer::SetStride ( int  _val)
◆ StartLoop()
void vtkCompositeAnimationPlayer::StartLoop ( double  starttime,
double  endtime,
double  curtime,
double *  playbackWindow
overrideprotectedvirtual
Implements vtkAnimationPlayer.
◆ EndLoop()
void vtkCompositeAnimationPlayer::EndLoop ( )
◆ GetNextTime()
double vtkCompositeAnimationPlayer::GetNextTime ( double  currentime)
◆ GetPreviousTime()
double vtkCompositeAnimationPlayer::GetPreviousTime ( double  currenttime)
◆ GoToNext()
double vtkCompositeAnimationPlayer::GoToNext ( double  start,
double  end,
double  currenttime
◆ GoToPrevious()
double vtkCompositeAnimationPlayer::GoToPrevious ( double  start,
double  end,
double  currenttime
◆ GetActivePlayer()
vtkAnimationPlayer* vtkCompositeAnimationPlayer::GetActivePlayer ( )
◆ SequenceAnimationPlayer
vtkSequenceAnimationPlayer* vtkCompositeAnimationPlayer::SequenceAnimationPlayer
Definition at line 88 of file vtkCompositeAnimationPlayer.h.
◆ TimestepsAnimationPlayer
vtkTimestepsAnimationPlayer* vtkCompositeAnimationPlayer::TimestepsAnimationPlayer
Definition at line 89 of file vtkCompositeAnimationPlayer.h.
◆ PlayMode
int vtkCompositeAnimationPlayer::PlayMode
Definition at line 91 of file vtkCompositeAnimationPlayer.h.
