vtkSIIntVectorProperty Class Reference
#include <vtkSIIntVectorProperty.h>
Inheritance diagram for vtkSIIntVectorProperty:
Collaboration diagram for vtkSIIntVectorProperty:
typedef vtkSIVectorProperty Superclass
- Public Types inherited from vtkSIVectorProperty
typedef vtkSIProperty Superclass
- Public Types inherited from vtkSIProperty
- Public Member Functions inherited from vtkSIVectorProperty
virtual char * GetInitialString ()
virtual int GetNumberOfElementsPerCommand ()
 If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More...
virtual bool GetUseIndex ()
 If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More...
virtual char * GetCleanCommand ()
 Command that can be used to remove all values. More...
virtual char * GetSetNumberCommand ()
 If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More...
- Public Member Functions inherited from vtkSIProperty
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual char * GetCommand ()
 The command name used to set the value on the server object. More...
virtual bool GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
virtual void SetIsInternal (bool)
 This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool GetIsInternal ()
static vtkSIIntVectorProperty * New ()
static vtkSIIntVectorProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIVectorProperty
static vtkSIVectorProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProperty
static vtkSIProperty * New ()
static vtkSIProperty * SafeDownCast (vtkObject *o)
 vtkSIIntVectorProperty ()
 ~vtkSIIntVectorProperty () override
- Protected Member Functions inherited from vtkSIVectorProperty
 vtkSIVectorProperty ()
 ~vtkSIVectorProperty () override
virtual void SetCleanCommand (const char *)
virtual void SetSetNumberCommand (const char *)
virtual void SetInitialString (const char *)
bool ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override
- Protected Member Functions inherited from vtkSIProperty
 vtkSIProperty ()
 ~vtkSIProperty () override
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
virtual bool Push (vtkSMMessage *, int)
 Push a new state to the underneath implementation. More...
virtual bool Pull (vtkSMMessage *)
 Pull the current state of the underneath implementation. More...
virtual void SetCommand (const char *)
void SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset)
bool ProcessMessage (vtkClientServerStream &stream)
 Interprets the message. More...
const vtkClientServerStream & GetLastResult ()
vtkObjectBase * GetVTKObject ()
- Protected Attributes inherited from vtkSIVectorProperty
char * SetNumberCommand
char * CleanCommand
bool UseIndex
int NumberOfElementsPerCommand
char * InitialString
- Protected Attributes inherited from vtkSIProperty
char * XMLName
char * Command
bool InformationOnly
bool Repeatable
bool IsInternal
vtkWeakPointer< vtkSIProxy > SIProxyObject
ServerSide Property use to set int array as method argument.
Definition at line 19 of file vtkSIIntVectorProperty.h.
Definition at line 26 of file vtkSIIntVectorProperty.h.
◆ vtkSIIntVectorProperty()
vtkSIIntVectorProperty::vtkSIIntVectorProperty ( )
◆ ~vtkSIIntVectorProperty()
vtkSIIntVectorProperty::~vtkSIIntVectorProperty ( )
static vtkSIIntVectorProperty* vtkSIIntVectorProperty::New ( )
virtual const char* vtkSIIntVectorProperty::GetClassName ( )
Reimplemented from vtkSIVectorProperty.
static int vtkSIIntVectorProperty::IsTypeOf ( const char *  type)
virtual int vtkSIIntVectorProperty::IsA ( const char *  type)
static vtkSIIntVectorProperty* vtkSIIntVectorProperty::SafeDownCast ( vtkObject *  o)
void vtkSIIntVectorProperty::PrintSelf ( ostream &  os,
