vtkPVOptionsXMLParser Class Reference
ParaView options storage. More...
#include <vtkPVOptionsXMLParser.h>
Inheritance diagram for vtkPVOptionsXMLParser:
Collaboration diagram for vtkPVOptionsXMLParser:
typedef vtkCommandOptionsXMLParser Superclass
- Public Types inherited from vtkCommandOptionsXMLParser
typedef vtkXMLParser Superclass
- Public Types inherited from vtkXMLParser
- Public Member Functions inherited from vtkCommandOptionsXMLParser
void AddBooleanArgument (const char *longarg, int *var, int type=0)
 Add arguments to the xml parser. More...
void AddArgument (const char *longarg, int *var, int type=0)
void AddArgument (const char *longarg, char **var, int type=0)
void SetPVOptions (vtkCommandOptions *o)
- Public Member Functions inherited from vtkXMLParser
vtkXMLParser * NewInstance () const
virtual int Parse ()
virtual void SetStream (istream *)
virtual istream * GetStream ()
vtkTypeInt64 TellG ()
void SeekG (vtkTypeInt64 position)
virtual int Parse (const char *inputString)
virtual int Parse (const char *inputString, unsigned int length)
virtual int InitializeParser ()
virtual int ParseChunk (const char *inputString, unsigned int length)
virtual int CleanupParser ()
virtual char * GetFileName ()
virtual void SetIgnoreCharacterData (int)
virtual int GetIgnoreCharacterData ()
virtual void SetEncoding (const char *)
virtual char * GetEncoding ()
static vtkPVOptionsXMLParser * New ()
static vtkPVOptionsXMLParser * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCommandOptionsXMLParser
static vtkCommandOptionsXMLParser * New ()
static vtkCommandOptionsXMLParser * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkXMLParser
static vtkXMLParser * SafeDownCast (vtkObjectBase *o)
static vtkXMLParser * New ()
 vtkPVOptionsXMLParser ()=default
 ~vtkPVOptionsXMLParser () override=default
void SetProcessType (const char *ptype) override
- Protected Member Functions inherited from vtkCommandOptionsXMLParser
 vtkCommandOptionsXMLParser ()
 Default constructor. More...
 ~vtkCommandOptionsXMLParser () override
 Destructor. More...
void StartElement (const char *name, const char **atts) override
void EndElement (const char *name) override
void HandleOption (const char **atts)
void HandleProcessType (const char **atts)
void SetProcessTypeInt (int ptype)
- Protected Member Functions inherited from vtkXMLParser
 vtkXMLParser ()
 ~vtkXMLParser ()
virtual int CreateParser ()
virtual int ParseXML ()
virtual int ParsingComplete ()
virtual void CharacterDataHandler (const char *data, int length)
virtual void ReportStrayAttribute (const char *element, const char *attr, const char *value)
virtual void ReportMissingAttribute (const char *element, const char *attr)
virtual void ReportBadAttribute (const char *element, const char *attr, const char *value)
virtual void ReportUnknownElement (const char *element)
virtual void ReportXmlParseError ()
vtkTypeInt64 GetXMLByteIndex ()
virtual int ParseBuffer (const char *buffer, unsigned int count)
int ParseBuffer (const char *buffer)
- Static Protected Member Functions inherited from vtkXMLParser
static int IsSpace (char c)
- Protected Attributes inherited from vtkXMLParser
istream * Stream
char * FileName
char * Encoding
int ParseError
const char * InputString
int InputStringLength
void * Parser
int IgnoreCharacterData
An object of this class represents a storage for ParaView options
These options can be retrieved during run-time, set using configuration file or using Command Line Arguments.
Deprecated:
in ParaView 5.12.0. See vtkCLIOptions instead. See https://gitlab.kitware.com/paraview/paraview/-/merge_requests/4951 for developer guidelines.
Definition at line 26 of file vtkPVOptionsXMLParser.h.
Definition at line 31 of file vtkPVOptionsXMLParser.h.
◆ vtkPVOptionsXMLParser()
vtkPVOptionsXMLParser::vtkPVOptionsXMLParser ( )
protecteddefault
◆ ~vtkPVOptionsXMLParser()
vtkPVOptionsXMLParser::~vtkPVOptionsXMLParser ( )
overrideprotecteddefault
static vtkPVOptionsXMLParser* vtkPVOptionsXMLParser::New ( )
virtual const char* vtkPVOptionsXMLParser::GetClassName ( )
Reimplemented from vtkCommandOptionsXMLParser.
static int vtkPVOptionsXMLParser::IsTypeOf ( const char *  type)
virtual int vtkPVOptionsXMLParser::IsA ( const char *  type)
static vtkPVOptionsXMLParser* vtkPVOptionsXMLParser::SafeDownCast ( vtkObject *  o)
void vtkPVOptionsXMLParser::PrintSelf ( ostream &  os,
Reimplemented from vtkXMLParser.
◆ SetProcessType()
void vtkPVOptionsXMLParser::SetProcessType ( const char *  ptype)
overrideprotectedvirtual
