vtkCommandOptionsXMLParser Class Reference
ParaView options storage. More...
#include <vtkCommandOptionsXMLParser.h>
Inheritance diagram for vtkCommandOptionsXMLParser:
Collaboration diagram for vtkCommandOptionsXMLParser:
typedef vtkXMLParser Superclass
- Public Types inherited from vtkXMLParser
void AddBooleanArgument (const char *longarg, int *var, int type=0)
 Add arguments to the xml parser. More...
void AddArgument (const char *longarg, int *var, int type=0)
void AddArgument (const char *longarg, char **var, int type=0)
void SetPVOptions (vtkCommandOptions *o)
- Public Member Functions inherited from vtkXMLParser
vtkXMLParser * NewInstance () const
virtual int Parse ()
virtual void SetStream (istream *)
virtual istream * GetStream ()
vtkTypeInt64 TellG ()
void SeekG (vtkTypeInt64 position)
virtual int Parse (const char *inputString)
virtual int Parse (const char *inputString, unsigned int length)
virtual int InitializeParser ()
virtual int ParseChunk (const char *inputString, unsigned int length)
virtual int CleanupParser ()
virtual char * GetFileName ()
virtual void SetIgnoreCharacterData (int)
virtual int GetIgnoreCharacterData ()
virtual void SetEncoding (const char *)
virtual char * GetEncoding ()
static vtkCommandOptionsXMLParser * New ()
static vtkCommandOptionsXMLParser * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkXMLParser
static vtkXMLParser * SafeDownCast (vtkObjectBase *o)
static vtkXMLParser * New ()
 vtkCommandOptionsXMLParser ()
 Default constructor. More...
 ~vtkCommandOptionsXMLParser () override
 Destructor. More...
void StartElement (const char *name, const char **atts) override
void EndElement (const char *name) override
void HandleOption (const char **atts)
void HandleProcessType (const char **atts)
virtual void SetProcessType (const char *ptype)
void SetProcessTypeInt (int ptype)
- Protected Member Functions inherited from vtkXMLParser
 vtkXMLParser ()
 ~vtkXMLParser ()
virtual int CreateParser ()
virtual int ParseXML ()
virtual int ParsingComplete ()
virtual void CharacterDataHandler (const char *data, int length)
virtual void ReportStrayAttribute (const char *element, const char *attr, const char *value)
virtual void ReportMissingAttribute (const char *element, const char *attr)
virtual void ReportBadAttribute (const char *element, const char *attr, const char *value)
virtual void ReportUnknownElement (const char *element)
virtual void ReportXmlParseError ()
vtkTypeInt64 GetXMLByteIndex ()
virtual int ParseBuffer (const char *buffer, unsigned int count)
int ParseBuffer (const char *buffer)
- Static Protected Member Functions inherited from vtkXMLParser
static int IsSpace (char c)
- Protected Attributes inherited from vtkXMLParser
istream * Stream
char * FileName
char * Encoding
int ParseError
const char * InputString
int InputStringLength
void * Parser
int IgnoreCharacterData
An object of this class represents a storage for ParaView options
These options can be retrieved during run-time, set using configuration file or using Command Line Arguments.
Deprecated:
in ParaView 5.12.0. See vtkCLIOptions instead. See https://gitlab.kitware.com/paraview/paraview/-/merge_requests/4951 for developer guidelines.
Definition at line 28 of file vtkCommandOptionsXMLParser.h.
Definition at line 33 of file vtkCommandOptionsXMLParser.h.
◆ vtkCommandOptionsXMLParser()
vtkCommandOptionsXMLParser::vtkCommandOptionsXMLParser ( )
◆ ~vtkCommandOptionsXMLParser()
vtkCommandOptionsXMLParser::~vtkCommandOptionsXMLParser ( )
Destructor.
static vtkCommandOptionsXMLParser* vtkCommandOptionsXMLParser::New ( )
virtual const char* vtkCommandOptionsXMLParser::GetClassName ( )
Reimplemented in vtkPVOptionsXMLParser.
static int vtkCommandOptionsXMLParser::IsTypeOf ( const char *  type)
virtual int vtkCommandOptionsXMLParser::IsA ( const char *  type)
Reimplemented from vtkXMLParser.
static vtkCommandOptionsXMLParser* vtkCommandOptionsXMLParser::SafeDownCast ( vtkObject *  o)
void vtkCommandOptionsXMLParser::PrintSelf ( ostream &  os,
◆ AddBooleanArgument()
void vtkCommandOptionsXMLParser::AddBooleanArgument ( const char *  longarg,
int *  var,
int  type = 0
These should be the long arguments from the vtkCommandOptions class of the form –foo, and pass in the variable that needs to be set with the value.
◆ AddArgument() [1/2]
void vtkCommandOptionsXMLParser::AddArgument ( const char *  longarg,
int *  var,
int  type = 0
◆ AddArgument() [2/2]
char **  var,
int  type = 0
◆ SetPVOptions()
void vtkCommandOptionsXMLParser::SetPVOptions ( vtkCommandOptions *  o)
inline
Definition at line 45 of file vtkCommandOptionsXMLParser.h.
◆ StartElement()
void vtkCommandOptionsXMLParser::StartElement ( const char *  name,
const char **  atts
overrideprotectedvirtual
◆ EndElement()
void vtkCommandOptionsXMLParser::EndElement ( const char *  name)
◆ HandleOption()
void vtkCommandOptionsXMLParser::HandleOption ( const char **  atts)
◆ HandleProcessType()
void vtkCommandOptionsXMLParser::HandleProcessType ( const char **  atts)
◆ SetProcessType()
virtual void vtkCommandOptionsXMLParser::SetProcessType ( const char *  ptype)
protectedvirtual
◆ SetProcessTypeInt()
void vtkCommandOptionsXMLParser::SetProcessTypeInt ( int  ptype)
