Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkCommandOptions Class Reference
ParaView options storage. More...
#include <vtkCommandOptions.h>
Inheritance diagram for vtkCommandOptions:
Collaboration diagram for vtkCommandOptions:
enum  { EVERYBODY = 0, XMLONLY = 0x1 }
int Parse (int argc, const char *const argv[])
void GetRemainingArguments (int *argc, char **argv[])
const char * GetHelp ()
int GetProcessType ()
 Set/Get the type of the process for this set of options. More...
void SetProcessType (int p)
const char * GetArgv0 ()
 Get argv[0]. More...
int GetLastArgument ()
 Get the index of the last argument parsed. More...
virtual int ParseExtraXMLTag (const char *, const char **)
 Pass in the name and the attributes for all tags that are not Options. More...
virtual int GetHelpSelected ()
 Was help selected? More...
virtual void SetHelpSelected (int)
virtual char * GetUnknownArgument ()
 In case of unknown argument, set this variable with the unknown argument. More...
virtual char * GetErrorMessage ()
 Get the error message if Parse returned 0. More...
virtual char * GetApplicationPath ()
 Get full path of executable (based on Argv0) More...
static vtkCommandOptions * New ()
static vtkCommandOptions * SafeDownCast (vtkObject *o)
Protected Types
typedef int(* CallbackType) (const char *argument, const char *value, void *call_data)
 Prototype for callbacks. More...
 vtkCommandOptions ()
 Default constructor. More...
 ~vtkCommandOptions () override
 Destructor. More...
void AddCallback (const char *longarg, const char *shortarg, CallbackType callback, void *call_data, const char *help, int type=EVERYBODY)
virtual void Initialize ()
 Initialize arguments. More...
virtual int PostProcess (int argc, const char *const *argv)
 After parsing, process extra option dependencies. More...
virtual int WrongArgument (const char *argument)
 This method is called when wrong argument is found. More...
virtual int DeprecatedArgument (const char *argument)
 This method is called when a deprecated argument is found. More...
int LoadXMLConfigFile (const char *)
 This method loads the paraview config file. More...
virtual void SetUnknownArgument (const char *)
virtual void SetErrorMessage (const char *)
virtual void SetXMLConfigFile (const char *)
void CleanArgcArgv ()
virtual void SetApplicationPath (const char *)
void ComputeApplicationPath ()
void AddBooleanArgument (const char *longarg, const char *shortarg, int *var, const char *help, int type=EVERYBODY)
 Add a command line option. More...
void AddDeprecatedArgument (const char *longarg, const char *shortarg, const char *help, int type=EVERYBODY)
void AddArgument (const char *longarg, const char *shortarg, int *var, const char *help, int type=EVERYBODY)
void AddArgument (const char *longarg, const char *shortarg, char **var, const char *help, int type=EVERYBODY)
vtkCommandOptionsXMLParser * XMLParser
An object of this class represents a storage for ParaView options
These options can be retrieved during run-time, set using configuration file or using Command Line Arguments.
Deprecated:
in ParaView 5.12.0. See vtkCLIOptions instead. See https://gitlab.kitware.com/paraview/paraview/-/merge_requests/4951 for developer guidelines.
Definition at line 27 of file vtkCommandOptions.h.
Definition at line 32 of file vtkCommandOptions.h.
◆ CallbackType
typedef int(* vtkCommandOptions::CallbackType) (const char *argument, const char *value, void *call_data)
Definition at line 112 of file vtkCommandOptions.h.
◆ anonymous enum
anonymous enum
Enumerator
EVERYBODY
XMLONLY
Definition at line 38 of file vtkCommandOptions.h.
◆ vtkCommandOptions()
vtkCommandOptions::vtkCommandOptions ( )
◆ ~vtkCommandOptions()
vtkCommandOptions::~vtkCommandOptions ( )
Destructor.
static vtkCommandOptions* vtkCommandOptions::New ( )
virtual const char* vtkCommandOptions::GetClassName ( )
Reimplemented in vtkPVOptions.
static int vtkCommandOptions::IsTypeOf ( const char *  type)
virtual int vtkCommandOptions::IsA ( const char *  type)
static vtkCommandOptions* vtkCommandOptions::SafeDownCast ( vtkObject *  o)
void vtkCommandOptions::PrintSelf ( ostream &  os,
◆ Parse()
int vtkCommandOptions::Parse ( int  argc,
◆ GetRemainingArguments()
void vtkCommandOptions::GetRemainingArguments ( int *  argc,
char **  argv[]
◆ GetHelp()
const char* vtkCommandOptions::GetHelp ( )
◆ GetHelpSelected()
virtual int vtkCommandOptions::GetHelpSelected ( )
Was help selected?
◆ SetHelpSelected()
virtual void vtkCommandOptions::SetHelpSelected ( int  )
Was help selected?
◆ GetProcessType()
int vtkCommandOptions::GetProcessType ( )
inline
data-server, render-server, combined-server or client.
Definition at line 58 of file vtkCommandOptions.h.
◆ SetProcessType()
void vtkCommandOptions::SetProcessType ( int  p)
inline
Definition at line 59 of file vtkCommandOptions.h.
◆ GetUnknownArgument()
virtual char* vtkCommandOptions::GetUnknownArgument ( )
◆ GetErrorMessage()
virtual char* vtkCommandOptions::GetErrorMessage ( )
◆ GetArgv0()
const char* vtkCommandOptions::GetArgv0 ( )
Get argv[0].
◆ GetApplicationPath()
virtual char* vtkCommandOptions::GetApplicationPath ( )
◆ GetLastArgument()
int vtkCommandOptions::GetLastArgument ( )
◆ ParseExtraXMLTag()
virtual int vtkCommandOptions::ParseExtraXMLTag ( const char *  ,
const char **
inlinevirtual
If it returns 1, then it is successful, and 0 if it failed.
Definition at line 96 of file vtkCommandOptions.h.
◆ AddBooleanArgument()
void vtkCommandOptions::AddBooleanArgument ( const char *  longarg,
const char *  shortarg,
int *  var,
const char *  help,
int  type = EVERYBODY
For each argument added there is a long version –long and a short version -l, a help string, and a variable that is set to the value of the option. The types can be int, char*, or boolean (set to 1 of option is present). Also deprecated arguments can be added with only a help string. The help string should say that the argument is deprecated and suggest the alternative argument to use. Each option can specify in a bit flag int the processes that the option is valid for, the default is to be valid for all paraview processes.
◆ AddDeprecatedArgument()
void vtkCommandOptions::AddDeprecatedArgument ( const char *  longarg,
const char *  help,
◆ AddArgument() [1/2]
void vtkCommandOptions::AddArgument ( const char *  longarg,
int *  var,
const char *  help,
◆ AddArgument() [2/2]
char **  var,
const char *  help,
◆ AddCallback()
void vtkCommandOptions::AddCallback ( const char *  longarg,
void *  call_data,
const char *  help,
◆ Initialize()
virtual void vtkCommandOptions::Initialize ( )
protectedvirtual
◆ PostProcess()
virtual int vtkCommandOptions::PostProcess ( int  argc,
const char *const *  argv
protectedvirtual
◆ WrongArgument()
virtual int vtkCommandOptions::WrongArgument ( const char *  argument)
protectedvirtual
If it returns 0, then the parsing will fail.
◆ DeprecatedArgument()
virtual int vtkCommandOptions::DeprecatedArgument ( const char *  argument)
protectedvirtual
◆ LoadXMLConfigFile()
int vtkCommandOptions::LoadXMLConfigFile ( const char *  )
The command line will override any of the values in this file, but all options can be in the file.
◆ SetUnknownArgument()
virtual void vtkCommandOptions::SetUnknownArgument ( const char *  )
protectedvirtual
◆ SetErrorMessage()
virtual void vtkCommandOptions::SetErrorMessage ( const char *  )
protectedvirtual
◆ SetXMLConfigFile()
virtual void vtkCommandOptions::SetXMLConfigFile ( const char *  )
protectedvirtual
◆ CleanArgcArgv()
void vtkCommandOptions::CleanArgcArgv ( )
◆ SetApplicationPath()
virtual void vtkCommandOptions::SetApplicationPath ( const char *  )
protectedvirtual
◆ ComputeApplicationPath()
void vtkCommandOptions::ComputeApplicationPath ( )
◆ XMLParser
vtkCommandOptionsXMLParser* vtkCommandOptions::XMLParser
Definition at line 178 of file vtkCommandOptions.h.
