vtkInSituInitializationHelper Class Reference
initialization helper for in situ environments. More...
#include <vtkInSituInitializationHelper.h>
Inheritance diagram for vtkInSituInitializationHelper:
Collaboration diagram for vtkInSituInitializationHelper:
static vtkInSituInitializationHelper * SafeDownCast (vtkObject *o)
static void Initialize (vtkTypeUInt64 comm)
 Initializes the engine. More...
static void Finalize ()
 Finalizes the engine. More...
static vtkInSituPipeline * AddPipeline (const std::string &name, const std::string &path)
 Add Python analysis scripts or packages. More...
static void AddPipeline (vtkInSituPipeline *pipeline)
 Add a vtkInSituPipeline instance. More...
static void SetProducer (const std::string &channelName, vtkSMSourceProxy *producer)
 Specify the algorithm or data-producer proxy that produces the mesh for named catalyst channel. More...
static vtkSMSourceProxy * GetProducer (const std::string &channelName)
 Provides access to the producer proxy for a given channel, if any. More...
static void UpdateAllProducers (double time)
 Convenience method to call Update/UpdatePipeline on all known producers. More...
static bool ExecutePipelines (int timestep, double time, const conduit_node *pipelines, const std::vector< std::string > &parameters={})
 Executes pipelines. More...
static bool IsInitialized ()
 Returns true if vtkInSituInitializationHelper has been initialized; which means that ParaView is operating in in situ mode. More...
static bool IsPythonSupported ()
 Returns true if ParaView is built with Python support enabled. More...
static void GetSteerableProxies (std::vector< std::pair< std::string, vtkSMProxy * >> &proxies)
static void UpdateSteerableParameters (vtkSMProxy *steerableProxy, const char *steerableSourceName)
static void MarkProducerModified (const std::string &channelName)
 This is provided as a convenience to indicate a particular producer has been modified or has new data for current timestep. More...
static void MarkProducerModified (vtkSMSourceProxy *producer)
static int GetTimeStep ()
 Provides access to current time and timestep during ExecutePipelines call. More...
static double GetTime ()
 vtkInSituInitializationHelper ()
 ~vtkInSituInitializationHelper () override
vtkInSituInitializationHelper used by ParaView-Catalyst to initialize the ParaView engine. It simply setups up defaults for suitable for in situ use-cases. Internally, it relies on vtkInitializationHelper to do the actual initialization.
vtkInSituInitializationHelper is also intended to be used by other in situ codes includes custom Catalyst API implementations or other in situ frameworks.
See also
Definition at line 50 of file vtkInSituInitializationHelper.h.
Definition at line 53 of file vtkInSituInitializationHelper.h.
◆ vtkInSituInitializationHelper()
vtkInSituInitializationHelper::vtkInSituInitializationHelper ( )
◆ ~vtkInSituInitializationHelper()
vtkInSituInitializationHelper::~vtkInSituInitializationHelper ( )
virtual const char* vtkInSituInitializationHelper::GetClassName ( )
static int vtkInSituInitializationHelper::IsTypeOf ( const char *  type)
virtual int vtkInSituInitializationHelper::IsA ( const char *  type)
static vtkInSituInitializationHelper* vtkInSituInitializationHelper::SafeDownCast ( vtkObject *  o)
void vtkInSituInitializationHelper::PrintSelf ( ostream &  os,
◆ Initialize()
static void vtkInSituInitializationHelper::Initialize ( vtkTypeUInt64  comm)
This can only be called once in the lifetime of the process. Calling this after the first call has no effect.
'comm' is used to determine the 'MPI_Comm' handle to be used for ParaView. In non-MPI builds of ParaView, this argument is simply ignored. In MPI-enabled builds of ParaView, this argument must be 'MPI_Fint' that represents the Fortran handle for MPI_Comm to use. The Fortran handle is an integer and hence we use 'vtkTypeUInt64' as a wide-enough container for the Fortran handle without having to include 'mpi.h' in this public header. The Fortran MPI communicator handle can be obtained from a MPI_Comm using MPI_Comm_c2f(). Refer to MPI specification for details.
◆ Finalize()
static void vtkInSituInitializationHelper::Finalize ( )
This can be called only once in the lifetime of the progress, and that too only after Initialize has been called.
◆ AddPipeline() [1/2]
static vtkInSituPipeline* vtkInSituInitializationHelper::AddPipeline ( const std::string &  name,
const std::string &  path
This should be called after Initialize but before Finalize to add analysis pipelines. The path can point to a Python script, a directory containing a Python package or a zip-file which containing a Python package.
◆ AddPipeline() [2/2]
static void vtkInSituInitializationHelper::AddPipeline ( vtkInSituPipeline *  pipeline)
◆ SetProducer()
static void vtkInSituInitializationHelper::SetProducer ( const std::string &  channelName,
vtkSMSourceProxy *  producer
This cannot be changed once specified.
On success, this registers the producer with the session proxy manager using the same name as the channelName.
◆ GetProducer()
static vtkSMSourceProxy* vtkInSituInitializationHelper::GetProducer ( const std::string &  channelName)
◆ UpdateAllProducers()
static void vtkInSituInitializationHelper::UpdateAllProducers ( double  time)
◆ MarkProducerModified() [1/2]
static void vtkInSituInitializationHelper::MarkProducerModified ( const std::string &  channelName)
◆ MarkProducerModified() [2/2]
static void vtkInSituInitializationHelper::MarkProducerModified ( vtkSMSourceProxy *  producer)
◆ ExecutePipelines()
static bool vtkInSituInitializationHelper::ExecutePipelines ( int  timestep,
double  time,
const conduit_node *  pipelines,
const std::vector< std::string > &  parameters = {}
Executes pipelines.
◆ GetTimeStep()
static int vtkInSituInitializationHelper::GetTimeStep ( )
The value is not valid outside ExecutePipelines.
◆ GetTime()
static double vtkInSituInitializationHelper::GetTime ( )
◆ IsInitialized()
static bool vtkInSituInitializationHelper::IsInitialized ( )
inlinestatic
Definition at line 137 of file vtkInSituInitializationHelper.h.
◆ IsPythonSupported()
static bool vtkInSituInitializationHelper::IsPythonSupported ( )
◆ GetSteerableProxies()
static void vtkInSituInitializationHelper::GetSteerableProxies ( std::vector< std::pair< std::string, vtkSMProxy * >> &  proxies)
◆ UpdateSteerableParameters()
static void vtkInSituInitializationHelper::UpdateSteerableParameters ( vtkSMProxy *  steerableProxy,
const char *  steerableSourceName
