vtkTimestepsAnimationPlayer Class Reference
vtkAnimationPlayer subclass that plays through a discrete set of time values. More...
#include <vtkTimestepsAnimationPlayer.h>
Inheritance diagram for vtkTimestepsAnimationPlayer:
Collaboration diagram for vtkTimestepsAnimationPlayer:
typedef vtkAnimationPlayer Superclass
- Public Types inherited from vtkAnimationPlayer
void RemoveAllTimeSteps ()
 Remove all timesteps. More...
unsigned int GetNumberOfTimeSteps ()
 Get number of timesteps. More...
double GetNextTimeStep (double time)
 Returns the timestep value after the given timestep. More...
void AddTimeStep (double time)
 Add/Remove timesteps. More...
void RemoveTimeStep (double time)
virtual void SetFramesPerTimestep (unsigned long)
 Get/Set the number of frames per timstep. More...
virtual unsigned long GetFramesPerTimestep ()
- Public Member Functions inherited from vtkAnimationPlayer
void Play (int dir=1)
 Start playing the animation. More...
void Stop ()
 Stop playing the animation. More...
int IsInPlay ()
 Returns if the animation is currently playing. More...
virtual bool GetInPlay ()
void GoToNext ()
 Take the animation scene to next frame. More...
void GoToPrevious ()
 Take animation scene to previous frame. More...
void GoToFirst ()
 Take animation scene to first frame. More...
void GoToLast ()
 Take animation scene to last frame. More...
virtual void SetAnimationScene (vtkSMAnimationScene *)
 Set the animation scene that is to be played by this player. More...
vtkSMAnimationScene * GetAnimationScene ()
virtual void SetLoop (bool)
 Set to true to play the animation in a loop. More...
virtual bool GetLoop ()
virtual int GetStride ()
 Get/Set the stride value fot the animation player. More...
virtual void SetStride (int)
static vtkTimestepsAnimationPlayer * New ()
static vtkTimestepsAnimationPlayer * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAnimationPlayer
static vtkAnimationPlayer * SafeDownCast (vtkObject *o)
double GoToNext (double, double, double currenttime) override
 Return next/previous time knowing start, end and current. More...
double GoToPrevious (double, double, double currenttime) override
void StartLoop (double, double, double, double *playbackWindow) override
 Manage loop inside playbackwindow. More...
void EndLoop () override
double GetNextTime (double currentime) override
double GetPreviousTime (double currenttime) override
- Protected Member Functions inherited from vtkAnimationPlayer
 vtkAnimationPlayer ()
 ~vtkAnimationPlayer () override
double PlaybackWindow [2]
unsigned long FramesPerTimestep
unsigned long Count
double GetPreviousTimeStep (double time)
 Returns the timestep value before the given timestep. More...
 vtkTimestepsAnimationPlayer ()
 ~vtkTimestepsAnimationPlayer () override
Player to play an animation scene through a discrete set of time values. FramesPerTimestep controls how many frames are generated for each time value.
Definition at line 20 of file vtkTimestepsAnimationPlayer.h.
Definition at line 24 of file vtkTimestepsAnimationPlayer.h.
◆ vtkTimestepsAnimationPlayer()
vtkTimestepsAnimationPlayer::vtkTimestepsAnimationPlayer ( )
If no value exists, returns the argument time itself.
◆ ~vtkTimestepsAnimationPlayer()
vtkTimestepsAnimationPlayer::~vtkTimestepsAnimationPlayer ( )
static vtkTimestepsAnimationPlayer* vtkTimestepsAnimationPlayer::New ( )
virtual const char* vtkTimestepsAnimationPlayer::GetClassName ( )
Reimplemented from vtkAnimationPlayer.
static int vtkTimestepsAnimationPlayer::IsTypeOf ( const char *  type)
virtual int vtkTimestepsAnimationPlayer::IsA ( const char *  type)
static vtkTimestepsAnimationPlayer* vtkTimestepsAnimationPlayer::SafeDownCast ( vtkObject *  o)
void vtkTimestepsAnimationPlayer::PrintSelf ( ostream &  os,
◆ AddTimeStep()
void vtkTimestepsAnimationPlayer::AddTimeStep ( double  time)
◆ RemoveTimeStep()
void vtkTimestepsAnimationPlayer::RemoveTimeStep ( double  time)
◆ RemoveAllTimeSteps()
void vtkTimestepsAnimationPlayer::RemoveAllTimeSteps ( )
◆ GetNumberOfTimeSteps()
unsigned int vtkTimestepsAnimationPlayer::GetNumberOfTimeSteps ( )
◆ SetFramesPerTimestep()
virtual void vtkTimestepsAnimationPlayer::SetFramesPerTimestep ( unsigned long  )
◆ GetFramesPerTimestep()
virtual unsigned long vtkTimestepsAnimationPlayer::GetFramesPerTimestep ( )
◆ GetNextTimeStep()
double vtkTimestepsAnimationPlayer::GetNextTimeStep ( double  time)
◆ GetPreviousTimeStep()
double vtkTimestepsAnimationPlayer::GetPreviousTimeStep ( double  time)
◆ StartLoop()
void vtkTimestepsAnimationPlayer::StartLoop ( double  ,
double  ,
double  ,
double *  playbackWindow
overrideprotectedvirtual
Implements vtkAnimationPlayer.
◆ EndLoop()
void vtkTimestepsAnimationPlayer::EndLoop ( )
inlineoverrideprotectedvirtual
Definition at line 77 of file vtkTimestepsAnimationPlayer.h.
◆ GetNextTime()
double vtkTimestepsAnimationPlayer::GetNextTime ( double  currentime)
◆ GetPreviousTime()
double vtkTimestepsAnimationPlayer::GetPreviousTime ( double  currenttime)
◆ GoToNext()
double vtkTimestepsAnimationPlayer::GoToNext ( double  start,
double  end,
double  currenttime
Definition at line 84 of file vtkTimestepsAnimationPlayer.h.
◆ GoToPrevious()
double vtkTimestepsAnimationPlayer::GoToPrevious ( double  start,
double  end,
double  currenttime
Definition at line 89 of file vtkTimestepsAnimationPlayer.h.
◆ PlaybackWindow
double vtkTimestepsAnimationPlayer::PlaybackWindow[2]
Definition at line 94 of file vtkTimestepsAnimationPlayer.h.
◆ FramesPerTimestep
unsigned long vtkTimestepsAnimationPlayer::FramesPerTimestep
Definition at line 95 of file vtkTimestepsAnimationPlayer.h.
◆ Count
unsigned long vtkTimestepsAnimationPlayer::Count
Definition at line 96 of file vtkTimestepsAnimationPlayer.h.
