pqServerConnectReaction Class Reference
#include <pqServerConnectReaction.h>
Inheritance diagram for pqServerConnectReaction:
Collaboration diagram for pqServerConnectReaction:
 pqServerConnectReaction (QAction *parent)
 Constructor. More...
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static void connectToServerWithWarning ()
 Creates a server connection using the server connection dialog. More...
static void connectToServer ()
static bool connectToServerUsingConfigurationName (const char *config_name, bool showConnectionDialog=true)
 ParaView names server configurations (in pvsc files). More...
static bool connectToServerUsingConfiguration (const pqServerConfiguration &config, bool showConnectionDialog=true)
 To connect to a server given a configuration, use this API. More...
static bool connectToServer (const pqServerResource &resource, bool showConnectionDialog=true)
 Connect to server using the resource. More...
void onTriggered () override
 Called when the action is triggered. More...
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
Reaction for connecting to a server.
Definition at line 16 of file pqServerConnectReaction.h.
◆ pqServerConnectReaction()
pqServerConnectReaction::pqServerConnectReaction ( QAction *  parent)
Constructor.
Parent cannot be nullptr.
◆ connectToServerWithWarning()
static void pqServerConnectReaction::connectToServerWithWarning ( )
Note that this method is static. Applications can simply use this without having to create a reaction instance.
◆ connectToServer() [1/2]
static void pqServerConnectReaction::connectToServer ( )
◆ connectToServerUsingConfigurationName()
static bool pqServerConnectReaction::connectToServerUsingConfigurationName ( const char *  config_name,
bool  showConnectionDialog = true
To connect to a server using the configuration specified, use this API.
◆ connectToServerUsingConfiguration()
static bool pqServerConnectReaction::connectToServerUsingConfiguration ( const pqServerConfiguration &  config,
◆ connectToServer() [2/2]
static bool pqServerConnectReaction::connectToServer ( const pqServerResource &  resource,
This will create a temporary configuration for the resource.
◆ onTriggered()
void pqServerConnectReaction::onTriggered ( )
inlineoverrideprotectedvirtual
Definition at line 58 of file pqServerConnectReaction.h.
