Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | List of all members
pqServerConfiguration Class Reference
pqServerConfiguration corresponds to a server connection configuration. More...
#include <pqServerConfiguration.h>
enum  StartupType { INVALID, MANUAL, COMMAND }
 Types of start. More...
 pqServerConfiguration ()
 Create an empty server configuration with the default name. More...
 ~pqServerConfiguration ()
 Default destructor. More...
 pqServerConfiguration (const QString &name)
 Create an empty server configuration with a provided name. More...
 pqServerConfiguration (vtkPVXMLElement *xml)
 Create a server configuration with the provided xml. More...
bool isMutable () const
 Get/Set whether the configuration is mutable. More...
void setMutable (bool val)
void setName (const QString &name)
 Get/Set the name for the configuration. More...
QString name () const
bool isNameDefault () const
 Returns true if the name for this configuration is the default one i.e. More...
pqServerResource resource () const
 Get/Set the resource that describes the server scheme, hostname(s) and port(s). More...
void setResource (const QString &)
void setResource (const pqServerResource &)
pqServerResource actualResource ()
 Get the actual resource that describes the server scheme, hostname(s) and port(s). More...
QString URI () const
 get the resource URI, does not contain the server name More...
int connectionTimeout (int defaultTimeout=60) const
 Get/Set the timeout in seconds that will be used when connecting 0 means no retry and -1 means infinite retries. More...
void setConnectionTimeout (int connectionTimeout)
StartupType startupType () const
 returns the startup type for this configuration. More...
QString command (double &processWait, double &delay) const
 If startupType() == COMMAND, then this method can be used to obtain the command for the startup, from the client side. More...
QString execCommand (double &processWait, double &delay) const
 If startupType() == COMMAND, then this method can be used to obtain the command for the startup, on the remote server, contained in the exec attributes. More...
void setStartupToManual ()
 changes the startup type to manual. More...
void setStartupToCommand (double processWait, double delay, const QString &command)
 changes the startup type to command. More...
QString toString (vtkIndent indent) const
 serialize to a string. More...
pqServerConfiguration clone () const
 Create a new clone (deep copying the vtkPVXMLElement). More...
vtkPVXMLElement * optionsXML () const
 returns the <Options> element, if any. More...
vtkPVXMLElement * hintsXML () const
 returns the <Hints> element, if any. More...
bool isPortForwarding () const
 Get if this is a port forwarding configuration. More...
QString portForwardingLocalPort () const
 Get the port forwarding local port. More...
static QString defaultName ()
 Returns the default name of a server configuration. More...
vtkPVXMLElement * startupXML () const
void parseSshPortForwardingXML ()
QString sshFullCommand (QString sshCommand, vtkPVXMLElement *sshConfigXML) const
static QString termCommand ()
static QString sshCommand ()
static QString lookForCommand (QString command)
These are typically read from pvsc files.
Definition at line 21 of file pqServerConfiguration.h.
◆ StartupType
Types of start.
Enumerator
INVALID
MANUAL
COMMAND
Definition at line 103 of file pqServerConfiguration.h.
◆ pqServerConfiguration() [1/3]
pqServerConfiguration::pqServerConfiguration ( )
◆ ~pqServerConfiguration()
pqServerConfiguration::~pqServerConfiguration ( )
Default destructor.
◆ pqServerConfiguration() [2/3]
pqServerConfiguration::pqServerConfiguration ( const QString &  name)
◆ pqServerConfiguration() [3/3]
pqServerConfiguration::pqServerConfiguration ( vtkPVXMLElement *  xml)
◆ isMutable()
bool pqServerConfiguration::isMutable ( ) const
inline
This variable is not serialized.
Definition at line 48 of file pqServerConfiguration.h.
◆ setMutable()
void pqServerConfiguration::setMutable ( bool  val)
inline
Definition at line 49 of file pqServerConfiguration.h.
◆ setName()
void pqServerConfiguration::setName ( const QString &  name)
◆ name()
QString pqServerConfiguration::name ( ) const
◆ isNameDefault()
bool pqServerConfiguration::isNameDefault ( ) const
the one that gets set when none is specified. Useful to determine "empty" configurations.
◆ defaultName()
static QString pqServerConfiguration::defaultName ( )
◆ resource()
pqServerResource pqServerConfiguration::resource ( ) const
◆ setResource() [1/2]
void pqServerConfiguration::setResource ( const QString &  )
◆ setResource() [2/2]
void pqServerConfiguration::setResource ( const pqServerResource &  )
◆ actualResource()
pqServerResource pqServerConfiguration::actualResource ( )
Can be different from resource() when using SSH Port Forwarding as it will point to ip and port actually used for the tcp connection, which can be different than the server where the pvserver is running. eg. it will give you localhost:8080, instead of serverip:serverport when using port forwarding. Using this method is needed only when using low level tcp api. resource() method should be used in any other cases.
◆ URI()
QString pqServerConfiguration::URI ( ) const
◆ connectionTimeout()
int pqServerConfiguration::connectionTimeout ( int  defaultTimeout = 60) const
If not set in the XML, the defaultTimeout is retuned.
◆ setConnectionTimeout()
void pqServerConfiguration::setConnectionTimeout ( int  connectionTimeout)
◆ startupType()
StartupType pqServerConfiguration::startupType ( ) const
There are 3 types of startup: manual, simple-command and custom-command.
◆ command()
QString pqServerConfiguration::command ( double &  processWait,
double &  delay
) const
Note that this does not include any information options etc. that may be specified in the startup. This is the full command to be executed on the client, which includes xterm, ssh... This also recovers processWait and delay attributes. processWait is the amount of time to wait for the process to start in seconds. delay is the amount of time wait for the process to finish, -1 means infinite wait.
◆ execCommand()
QString pqServerConfiguration::execCommand ( double &  processWait,
double &  delay
) const
Note that this does not include any information options etc. that may be specified in the startup. This also recovers processWait and delay attributes. processWait is the amount of time to wait for the process to start in seconds. delay is the amount of time wait for the process to finish, -1 means infinite wait.
◆ setStartupToManual()
void pqServerConfiguration::setStartupToManual ( )
◆ setStartupToCommand()
void pqServerConfiguration::setStartupToCommand ( double  processWait,
double  delay,
const QString &  command
◆ toString()
QString pqServerConfiguration::toString ( vtkIndent  indent) const
◆ clone()
pqServerConfiguration pqServerConfiguration::clone ( ) const
◆ optionsXML()
vtkPVXMLElement* pqServerConfiguration::optionsXML ( ) const
◆ hintsXML()
vtkPVXMLElement* pqServerConfiguration::hintsXML ( ) const
◆ isPortForwarding()
bool pqServerConfiguration::isPortForwarding ( ) const
inline
PortForwardingConfiguration uses SSH tunneling and is configured directly in xml server file
Definition at line 176 of file pqServerConfiguration.h.
◆ portForwardingLocalPort()
QString pqServerConfiguration::portForwardingLocalPort ( ) const
Initialized by the server xml if port forwarding is used. Equal to the resource port if port forwarding is not used.
◆ startupXML()
vtkPVXMLElement* pqServerConfiguration::startupXML ( ) const
◆ parseSshPortForwardingXML()
void pqServerConfiguration::parseSshPortForwardingXML ( )
◆ sshFullCommand()
QString pqServerConfiguration::sshFullCommand ( QString  sshCommand,
vtkPVXMLElement *  sshConfigXML
) const
◆ termCommand()
static QString pqServerConfiguration::termCommand ( )
staticprotected
◆ sshCommand()
static QString pqServerConfiguration::sshCommand ( )
staticprotected
◆ lookForCommand()
static QString pqServerConfiguration::lookForCommand ( QString  command)
staticprotected
