pqServerConnectDialog is a dialog that can be used to show the user a selection of server configurations to connect to a server.
#include <pqServerConnectDialog.h>
Inherits QDialog.
This dialog can show all the server-configurations known to pqApplicationCore or show only a subset of those depending on whether a selector was specified in the constructor.
On successful completion, this dialog provides access to the server-configuration selected by the user. It does not make an real attempts to connect to that server.
Definition at line 29 of file pqServerConnectDialog.h.
◆ pqServerConnectDialog()
If selector is specified, only those server-configurations that match the selector's scheme and hostname are shown.
◆ ~pqServerConnectDialog()
| pqServerConnectDialog::~pqServerConnectDialog |
◆ configurationToConnect()
returns the configuration to connect to.
This returns a valid response only when pqServerConnectDialog::exec() returns QDialog::Accepted.
◆ selectServer()
convenience method to determine which server to connect.
If the selector is specified and matches a single server, then the user is not presented with a dialog, otherwise the user can choose the configuration to use to connect to the server. When the method returns true, selected_configuration will be set to the chosen configuration.
◆ serverAdded
| void pqServerConnectDialog::serverAdded |
signal |
Emitted when a server is added.
◆ serverDeleted
| void pqServerConnectDialog::serverDeleted |
signal |
Emitted when a server is deleted.
◆ updateConfigurations
| void pqServerConnectDialog::updateConfigurations |
protectedslot |
called to update the shown server configurations.
◆ onServerSelected
| void pqServerConnectDialog::onServerSelected |
protectedslot |
called when user selects a server.
◆ editServer
| void pqServerConnectDialog::editServer |
protectedslot |
called when user clicks "edit-server"
◆ addServer
| void pqServerConnectDialog::addServer |
protectedslot |
called when user clicks "add-server"
◆ updateButtons
| void pqServerConnectDialog::updateButtons |
protectedslot |
Called when a server has been added or deleted.
◆ updateServerType
| void pqServerConnectDialog::updateServerType |
protectedslot |
called when user changes the server-type.
◆ goToFirstPage
| void pqServerConnectDialog::goToFirstPage |
protectedslot |
◆ acceptConfigurationPage1
| void pqServerConnectDialog::acceptConfigurationPage1 |
protectedslot |
called when user accepts the configuration page #1.
◆ acceptConfigurationPage2
| void pqServerConnectDialog::acceptConfigurationPage2 |
protectedslot |
called when user accepts the configuration page #2.
◆ editServerStartup
| void pqServerConnectDialog::editServerStartup |
protectedslot |
called to proceed to page that allows the user to edit the startup.
◆ onNameChanged
| void pqServerConnectDialog::onNameChanged |
protectedslot |
◆ deleteServer
| void pqServerConnectDialog::deleteServer |
protectedslot |
called to delete one or all servers.
◆ deleteAllServers
| void pqServerConnectDialog::deleteAllServers |
protectedslot |
◆ loadServers
| void pqServerConnectDialog::loadServers |
protectedslot |
called to load/save servers.
◆ saveServers
| void pqServerConnectDialog::saveServers |
protectedslot |
◆ connect
| void pqServerConnectDialog::connect |
protectedslot |
called to connect to selected server.
◆ updateDialogTitle
| void pqServerConnectDialog::updateDialogTitle |
int |
page_number | ) |
protectedslot |
called when the main-stacked widget's active page changes.
We update the dialog;s title text to match the page being displayed.
◆ fetchServers
| void pqServerConnectDialog::fetchServers |
protectedslot |
called when user clicks "Fetch Servers".
◆ authenticationRequired
| void pqServerConnectDialog::authenticationRequired |
QNetworkReply * |
QAuthenticator * |
protectedslot |
called when the importer needs authentication from the user.
◆ updateImportableConfigurations
| void pqServerConnectDialog::updateImportableConfigurations |
protectedslot |
called update importable configs.
◆ importError
| void pqServerConnectDialog::importError |
const QString & |
message | ) |
protectedslot |
called to report error from importer.
◆ importServersSelectionChanged
| void pqServerConnectDialog::importServersSelectionChanged |
protectedslot |
called when user selects some servers to import.
◆ importServers
| void pqServerConnectDialog::importServers |
protectedslot |
called to import selected configurations.
◆ editSources
| void pqServerConnectDialog::editSources |
protectedslot |
called to edit the sources url.
◆ saveSourcesList
| void pqServerConnectDialog::saveSourcesList |
protectedslot |
◆ cancelEditSources
| void pqServerConnectDialog::cancelEditSources |
protectedslot |
◆ editConfiguration()
◆ serverNameExists()
| bool pqServerConnectDialog::serverNameExists |
const QString & |
name | ) |
