Public Member Functions | Protected Member Functions | List of all members
pqPythonCalculatorCompleter Class Reference
Completer to be used for the Python calculator expression field. More...
#include <pqPythonCalculatorCompleter.h>
Inheritance diagram for pqPythonCalculatorCompleter:
Collaboration diagram for pqPythonCalculatorCompleter:
 pqPythonCalculatorCompleter (QWidget *parent, vtkSMSourceProxy *input)
- Public Member Functions inherited from pqPythonCompleter
 pqPythonCompleter (QWidget *parent)
- Public Member Functions inherited from pqWidgetCompleter
 pqWidgetCompleter (QWidget *parent)
virtual void updateCompletionModel (const QString &prompt)
 This method is called by the client to request an update on the internal completion model, given a text prompt. More...
bool getCompleteEmptyPrompts ()
 get/set CompleteEmptyPrompts, indicating whether or not the completer should show anything if an empty prompt is given. More...
void setCompleteEmptyPrompts (bool newValue)
QStringList getPythonCompletions (const QString &pythonObjectName) override
 Given a text prompt, return a list of possible completions. More...
void AddArrayNamesToResults (const vtkPVDataSetAttributesInformation *attributesInformation, QStringList &results)
 Append the names of arrays of the dataset attributes information object at the end of the results list. More...
- Protected Member Functions inherited from pqPythonCompleter
QStringList getCompletions (const QString &prompt) override
 Return a list of strings that could match the given prompt. More...
QString getCompletionPrefix (const QString &prompt) override
 Return the part of the prompt that can be completed. More...
QString getVariableToComplete (const QString &prompt)
 From a prompt string that can contain multiple tokens, retrieve the last (possibly incomplete) variable name. More...
void appendPyObjectAttributes (PyObject *object, QStringList &results)
 Given a PyObject, append all of its attributes in the results list. More...
PyObject * derivePyObject (const QString &pythonObjectName, PyObject *locals)
 Given pythonObjectName string in the form "X.Y.Z.T" and script locals, return the most derived PyObject that matches the string. More...
Looks up attributes of Python objects, static calculator-specific variables and data set field names.
Definition at line 16 of file pqPythonCalculatorCompleter.h.
◆ pqPythonCalculatorCompleter()
pqPythonCalculatorCompleter::pqPythonCalculatorCompleter ( QWidget *  parent,
vtkSMSourceProxy *  input
inline
Definition at line 19 of file pqPythonCalculatorCompleter.h.
◆ getPythonCompletions()
QStringList pqPythonCalculatorCompleter::getPythonCompletions ( const QString &  pythonObjectName)
overrideprotectedvirtual
This method must be implemented in concrete classes.
Implements pqPythonCompleter.
◆ AddArrayNamesToResults()
void pqPythonCalculatorCompleter::AddArrayNamesToResults ( const vtkPVDataSetAttributesInformation *  attributesInformation,
QStringList &  results
