vtkPVPluginsInformation Class Reference
information about plugins tracked by vtkPVPluginTracker. More...
#include <vtkPVPluginsInformation.h>
Inheritance diagram for vtkPVPluginsInformation:
Collaboration diagram for vtkPVPluginsInformation:
typedef vtkPVInformation Superclass
- Public Types inherited from vtkPVInformation
void SetAutoLoad (unsigned int cc, bool)
 API to change auto-load status. More...
void SetAutoLoadAndForce (unsigned int cc, bool)
 This is a hack. More...
void CopyFromObject (vtkObject *) override
 Transfer information about a single object into this object. More...
void AddInformation (vtkPVInformation *) override
 Merge another information object. More...
void Update (vtkPVPluginsInformation *other)
 Updates the local information with elements from other without overriding auto-load state. More...
unsigned int GetNumberOfPlugins ()
 API to iterate over the information collected for each plugin. More...
const char * GetPluginName (unsigned int)
const char * GetPluginFileName (unsigned int)
const char * GetPluginVersion (unsigned int)
bool GetPluginLoaded (unsigned int)
const char * GetRequiredPlugins (unsigned int)
bool GetRequiredOnServer (unsigned int)
bool GetRequiredOnClient (unsigned int)
const char * GetDescription (unsigned int)
bool GetAutoLoad (unsigned int)
const char * GetPluginStatusMessage (unsigned int)
 Set/Get the plugin status message for a specific plugin. More...
void SetPluginStatusMessage (unsigned int, const char *)
void CopyToStream (vtkClientServerStream *) override
 Manage a serialized version of the information. More...
void CopyFromStream (const vtkClientServerStream *) override
virtual char * GetSearchPaths ()
 Get the plugin search path. More...
- Public Member Functions inherited from vtkPVInformation
virtual void CopyParametersToStream (vtkMultiProcessStream &)
 Serialize/Deserialize the parameters that control how/what information is gathered. More...
virtual void CopyParametersFromStream (vtkMultiProcessStream &)
virtual int GetRootOnly ()
 Set/get whether to gather information only from the root. More...
static vtkPVPluginsInformation * New ()
static vtkPVPluginsInformation * SafeDownCast (vtkObject *o)
static bool PluginRequirementsSatisfied (vtkPVPluginsInformation *client_plugins, vtkPVPluginsInformation *server_plugins)
 Method to validate if the plugin requirements are met across processes. More...
- Static Public Member Functions inherited from vtkPVInformation
static vtkPVInformation * SafeDownCast (vtkObject *o)
 vtkPVPluginsInformation ()
 ~vtkPVPluginsInformation () override
virtual void SetSearchPaths (const char *)
- Protected Member Functions inherited from vtkPVInformation
 vtkPVInformation ()
 ~vtkPVInformation () override
virtual void SetRootOnly (int)
 vtkPVInformation (const vtkPVInformation &)=delete
void operator= (const vtkPVInformation &)=delete
char * SearchPaths
- Protected Attributes inherited from vtkPVInformation
int RootOnly
vtkPVPluginsInformation is used to collect information about plugins tracked by vtkPVPluginTracker.
Definition at line 19 of file vtkPVPluginsInformation.h.
Definition at line 23 of file vtkPVPluginsInformation.h.
◆ vtkPVPluginsInformation()
vtkPVPluginsInformation::vtkPVPluginsInformation ( )
◆ ~vtkPVPluginsInformation()
vtkPVPluginsInformation::~vtkPVPluginsInformation ( )
static vtkPVPluginsInformation* vtkPVPluginsInformation::New ( )
virtual const char* vtkPVPluginsInformation::GetClassName ( )
Reimplemented from vtkPVInformation.
static int vtkPVPluginsInformation::IsTypeOf ( const char *  type)
virtual int vtkPVPluginsInformation::IsA ( const char *  type)
static vtkPVPluginsInformation* vtkPVPluginsInformation::SafeDownCast ( vtkObject *  o)
void vtkPVPluginsInformation::PrintSelf ( ostream &  os,
◆ GetNumberOfPlugins()
unsigned int vtkPVPluginsInformation::GetNumberOfPlugins ( )
◆ GetPluginName()
const char* vtkPVPluginsInformation::GetPluginName ( unsigned int  )
◆ GetPluginFileName()
const char* vtkPVPluginsInformation::GetPluginFileName ( unsigned int  )
◆ GetPluginVersion()
const char* vtkPVPluginsInformation::GetPluginVersion ( unsigned int  )
◆ GetPluginLoaded()
bool vtkPVPluginsInformation::GetPluginLoaded ( unsigned int  )
◆ GetRequiredPlugins()
const char* vtkPVPluginsInformation::GetRequiredPlugins ( unsigned int  )
◆ GetRequiredOnServer()
bool vtkPVPluginsInformation::GetRequiredOnServer ( unsigned int  )
◆ GetRequiredOnClient()
bool vtkPVPluginsInformation::GetRequiredOnClient ( unsigned int  )
◆ GetDescription()
const char* vtkPVPluginsInformation::GetDescription ( unsigned int  )
◆ GetAutoLoad()
bool vtkPVPluginsInformation::GetAutoLoad ( unsigned int  )
◆ GetPluginStatusMessage()
const char* vtkPVPluginsInformation::GetPluginStatusMessage ( unsigned int  )
◆ SetPluginStatusMessage()
void vtkPVPluginsInformation::SetPluginStatusMessage ( unsigned int  ,
const char *
◆ SetAutoLoad()
void vtkPVPluginsInformation::SetAutoLoad ( unsigned int  cc,
bool
◆ SetAutoLoadAndForce()
void vtkPVPluginsInformation::SetAutoLoadAndForce ( unsigned int  cc,
bool
This is a hack.
When the user sets an auto-load option from the GUI to avoid that choice being overwritten as the information object is updated over time as new plugins are loaded/unloaded, the pqPluginDialog uses this method to set the auto-load flag. This flag is not communicated across processes, but when called, GetAutoLoad() will return the value set using this method.
◆ CopyFromObject()
void vtkPVPluginsInformation::CopyFromObject ( vtkObject *  )
◆ AddInformation()
void vtkPVPluginsInformation::AddInformation ( vtkPVInformation *  )
◆ Update()
void vtkPVPluginsInformation::Update ( vtkPVPluginsInformation *  other)
◆ CopyToStream()
void vtkPVPluginsInformation::CopyToStream ( vtkClientServerStream *  )
Implements vtkPVInformation.
◆ CopyFromStream()
void vtkPVPluginsInformation::CopyFromStream ( const vtkClientServerStream *  )
◆ GetSearchPaths()
virtual char* vtkPVPluginsInformation::GetSearchPaths ( )
◆ PluginRequirementsSatisfied()
static bool vtkPVPluginsInformation::PluginRequirementsSatisfied ( vtkPVPluginsInformation *  client_plugins,
vtkPVPluginsInformation *  server_plugins
This also updated the "StatusMessage" for all the plugins. If StatusMessage is empty for a loaded plugin, it implies that everything is fine. If some requirement is not met, the StatusMessage includes the error message.
◆ SetSearchPaths()
virtual void vtkPVPluginsInformation::SetSearchPaths ( const char *  )
protectedvirtual
◆ SearchPaths
char* vtkPVPluginsInformation::SearchPaths
Definition at line 110 of file vtkPVPluginsInformation.h.
